Sway Bar bushings
Old Mar 6, 2007 | 12:39 PM
IloveVQ's Avatar
Sway Bar bushings
I was looking at the suspension sticky and saw that instead of a rear sway bar you can get these rear trailing arm bushings that will help stiffen the rear end. i plan on autocrossing this summer and have a fstb and eibachs with tokicos and i was wondering if i should get either front sway bar bushings or these rear trailing arm bushings or both and the effect they would have separate or together/if they are worth it?
Any input would be greatly appreciated.
Old Mar 6, 2007 | 01:37 PM
IloveVQ's Avatar
Also, would it be more effective for handling if i got rear wheel spacers or these bushings?
Old Mar 6, 2007 | 01:40 PM
SoonerFan's Avatar
Cletus
the RSB (rear sway bar) will be your best bet if you plan on getting one thing.
the RSB + bushings would be best.
since you plan to auto-x, i would also suggest a LTB (lower tie bar) http://www.mattblehm.com/suspension.htm
Old Mar 6, 2007 | 01:43 PM
upstatemax's Avatar
Get every ES bushing you can and install them along with the rear swaybar....
/ thread.
Really though, poly bushings and Motormounts help stiffen the car a lot. The spacers are really just a cosmetic mod (unless they help clear a BBK).
Old Mar 6, 2007 | 01:45 PM
upstatemax's Avatar
Waiting on the Stage II that will clear headers...
Old Mar 6, 2007 | 01:48 PM
SoonerFan's Avatar
Cletus
i cant tell a diffirence between my stage 1 and josh's (irish) stage 2.
actually, neither stage will fit with headers. its the front bar thats the problem
Old Mar 6, 2007 | 01:59 PM
mist max2000's Avatar
not positive on what ur saying.... are you saying you cant feel a difference in the handling performance of the two because you drove both? just asking cuz i always wondered if there was a big difference between the two...
Old Mar 6, 2007 | 02:01 PM
IloveVQ's Avatar
do the front sway bar bushings make a good difference?
Will the Rear bushings by themselves stiffen the rear noticeably enough to make them worthwhile?
Old Mar 6, 2007 | 02:03 PM
IloveVQ's Avatar
Basically its like this. I cant put more than 100 max more into my car cause i need to save more for school. i just want a few or one more little things that would give me the best bang for my buck in the handeling department before i start the next auto-x season. I am a little worried about understeer which is why i was looking at rear end stiffness. with the tokico's set at 4 front 5 rear and eibachs will i have much of an issue?
Old Mar 6, 2007 | 07:14 PM
ColdSHO's Avatar
front sway bar bushings=not a huge difference but not to hard to install, or so im told
rear trailing arms=big difference, but a pita to install, i didn't install my own
rsb=huge difference and easy to install, did mine in about an hour without a life and with handtools.
all 3 ftw
Old Mar 6, 2007 | 08:07 PM
upstatemax's Avatar
all 3 ftw
I hope that is a typo... I think that should say "lift".
Old Mar 7, 2007 | 12:01 PM
IloveVQ's Avatar
I would get a rear sway bar but im afraid of the "snap oversteer" that ive heard it can create especially with lowered suspension. is this true and if so how bad is it?
Old Mar 7, 2007 | 12:22 PM
SoonerFan's Avatar
Cletus
the benefit far outweighs the drawback...if you are a good driver and are aware of how the car will act. never been as issue with me (lowered with RSB and FSTB or after addition of LTB)
Old Mar 7, 2007 | 02:58 PM
IloveVQ's Avatar
I'm still apprehensive because although i consider myself a good driver i am only 17 and there is no substitute for experience. i fear that in an emergency situation like a fast lane change or something of that sort i will lose control/spin out of control more easily with the rsb. Will the ltb give the same type of gains? i realize this is a front end bar, but again if making the rear end stiffer makes it less safe, i am weary about it. also will i see major improvement in overall handling with the rsb and eibach and tokico versus just the eibach and tokico (keep in mind the settings of 4 front 5 rear)?
Old Mar 7, 2007 | 03:18 PM
IloveVQ's Avatar
Also are there different stiffnesses of sway bars for the max like one brand is stiffer than another or thicker or are they all the same?
Old Mar 7, 2007 | 03:19 PM
SoonerFan's Avatar
Cletus
they all do the same thing
Old Mar 7, 2007 | 03:22 PM
SoonerFan's Avatar
Cletus
at least you realize that you dont have a lot of experience. very few young drivers do that and they drive beyond their means.
suspension mods + experience = avoiding accidents. there have been many times were I had to make evasive maneuvers on the roads. im pretty sure that other drivers in other cars would not have been able to avoid an accident. autocrossing does wonders for learning how to make sudden movements to keep your car in control. you learn how you and the car work together.
Old Mar 7, 2007 | 03:25 PM
IloveVQ's Avatar
Will i do fine in auto-x without the rear sway bar do you think?
Also, will the ltb show noticeable gains on top of springs strut and a fstb?
BTW thanks for all your help.
Old Mar 7, 2007 | 03:34 PM
SoonerFan's Avatar
Cletus
you dont NEED the RSB to auto-x. it just helps when combined with lowering. i had the RSB on my unlowered 00 and it was still a huge difference....keeps the rear planted because it prevents the huge body roll when cornering.
i dont know how the LTB would work by itself...i installed mine after i was lowered and had the RSB and LTB.
i think that each single thing works better when combined with the others.
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ColdCananda
Sep 20, 2015 10:45 PM
