Needed Maintenance
Old Mar 6, 2007 | 03:34 PM
Noela's Avatar
Needed Maintenance
Hi,
My 2k2 max has 78K on it - the 30 or 60k service has not been done yet.
I took it to the dealer for an oil change and they noted the following:
-- 60K service (this does not include an transmission service, but instead a minor tune up involving checking plugs, wires and distributor cap)
-- Engine oil flush (I have never heard of this)
-- Transmission flush
-- replace drive belts
-- replace micro filter, air filter, and wiper blades.
They wanted to charge close to $600 for this service. I refused and paid for only the oil change.
Now, I want to plan my service. I want to replace the micro filter, air filter and wiper blades. Probably, I could replace the drive belts - if it is not too diffficult -- i have not yet seen the instructions).
I would then want to do the transmission service and the oil flush if I understand what they mean. According to the dealers, there is a lot of gunk and dirt in the pans and they need to flash everything out.
From what I read here and other forums, these flushes are not recommended for such high mileages, particularly since they have never been done. What is the consensus: flush or change oils
I would appreciate your comments,
rgds, MN
Old Mar 6, 2007 | 03:43 PM
SoonerFan's Avatar
Cletus
-- 60K service (this does not include an transmission service, but instead a minor tune up involving checking plugs, wires and distributor cap) you can do all that yourself for a lot cheaper
-- Engine oil flush (I have never heard of this) not needed
-- Transmission flush not needed but if you want to do it, it would be cheaper at a transmission shop
-- replace drive beltsyou can do that yourself for a lot cheaper
-- replace micro filter, air filter, and wiper blades.you can do all that yourself for a lot cheaper
in my opinion, only warranty work should be done at a nissan dealership
Old Mar 6, 2007 | 03:52 PM
LA02MAX's Avatar
^^ agreed. You can do the tranny fluid flush yourself as well. it's fairly easy to do. As for the drive belts, look here: http://www.greghome.com/Greg%27s%20G...xSE/2K2UDP.htm
He gives detailed instructions when you click on that link for the '99 maxima.
Old Mar 6, 2007 | 03:53 PM
kenshi's Avatar
I 100% agree with that. Most scheduled maintenance besides fluid changes is just inspection, like brakes and belts. Fluid changes are usually done at a flat rate by most shops.
Old Mar 6, 2007 | 03:59 PM
SoonerFan's Avatar
Cletus
exactly...even in the owners manual in the maintenance schedule, it says "inspect" for most things. you are paying the dealership to simply look at something. they will charge you around 2 hours of labor plus the parts they claim needed to be replaced.
im not saying the dealership is dishonest...im saying they are a business trying to make money. 90% of car owners pay it...im not one of them.
Old Mar 6, 2007 | 05:28 PM
RLW001's Avatar
Originally Posted by Noela
Hi,
If a dealer said they were going to check my plug wires and distributor cap I would walk out.
Old Mar 6, 2007 | 07:02 PM
Noela's Avatar
RL, that was what really made me curious ...i saw that, and just concluded that they are cheats. This was at Cherry Hill Nissan, in south Jersey. Avoid them !!
I will do the blades and filters, and probably get the OEM belts and have another trusted mechanic do those, if i am unable to.
regards to all.
Noela
Old Mar 6, 2007 | 07:15 PM
NisTech's Avatar
lol it's probably an updated flyer or something else like a service writer but it's definitely not a tech.
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
smplyamzng
Dec 13, 2015 01:19 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
TonyJr
Aug 20, 2015 12:14 AM
