My custom semi-cold air intake.
Old Apr 15, 2007 | 10:59 AM
maxspeed96CT's Avatar
The original VQ...
- Relcated battery, it wasnt to hard with the help of a friend. Used a drill grinder/dremel and made 2 brakcets to hold the tray and one for the Fuse Box.
-Made it from old intake pipes I had laying around. Still need to buy matching couplings, I had these laying around so just through them on.
- Sprayed with undercarige coating to resist heat. (have to redo cause I didnt have enought time to let the thing dry)
- Cut the braket mount on my MAf and also removed the screen before the MAF.
- Bought a huge K&N filter.
- Im also thinking of making some kind of heat shield.
- The car feels better, Safc air flow goes to 75% now ,also when I pop the hood after a long drive the filter area is much cooler behind the battery.
Old Apr 15, 2007 | 11:11 AM
irish44j's Avatar
retired moderator
interesting.....do you have any plans to cut a hole in the fender below the filter to get even more cold air to the filter?
Old Apr 15, 2007 | 12:02 PM
NmexMAX's Avatar
dot dot dot ...
When the heck are you going to do the ever so should be popular MAF mod?
My MAF % went up a couple %'s when I removed the screen. But it went down 20% w/ my Ferarri MAF housing
Old Apr 15, 2007 | 12:43 PM
nismopc's Avatar
Excellent job on the battery relocation. Personally think that is a great idea. Wouldn't take much to shield off the rest of the area and create a enclosure for the filter and pipe in some fresh ait from beneath.
What were the readings prior to the mod?
Old Apr 15, 2007 | 12:44 PM
NmexMAX's Avatar
dot dot dot ...
Looks like an A34 Injen intake
Old Apr 15, 2007 | 12:52 PM
The original VQ...
Readings before was about 72, but that also with my auto zone intimidator cone
After I removed the battery I thought about cuttin a hole to make a true CAI, but then thought about water and etc, and didnt wanna go throguht the trouble.
Old Apr 15, 2007 | 12:56 PM
NmexMAX's Avatar
dot dot dot ...
Your MAF housing is too small, as well as all associated tubing.
Old Apr 15, 2007 | 12:59 PM
MaximaInCT203's Avatar
schemes on chicks in his max.
Good stuff my dude! Im actually gonna do this as soon as this stupid Connecticut weather breaks. As for the shield, i have a battery housing (where the battery sits in) from a ford E-150 thats big enough to fit around that K&N..Im gonna drummel out the lil plastic squares inside the battery housing and bolt it down...As far as cutting out a hole in the fender well...Water might be an issue...but it might be safe you never know...Anway, great idea. Dont mind me usin it
Old Apr 16, 2007 | 08:27 AM
Bufflomike's Avatar
Sexier Than Simpson
CAI hole
I am afraid to cut a hole in the wheel well since living in Buffalo is about as salty as winters get.
Old Apr 16, 2007 | 09:23 AM
MaxBoost925's Avatar
Drug Money
for the creativity.
But it looks kinda ghetto.
Old Apr 16, 2007 | 10:23 AM
Maxi98se's Avatar
Your max is hot I saw you getting on Rt.9 Northbound sounds good
Old Apr 16, 2007 | 10:25 AM
SoonerFan's Avatar
Cletus
looks good...ive been wanting to do the same thing.
Old Apr 16, 2007 | 12:56 PM
NmexMAX's Avatar
dot dot dot ...
Not sure why he's keeping his stock MAF housing. He has a SAFCII so he could safely use the Land Rover housing unit, and instantly realize better throttle response as well as a few other added bonus items.
Looks like an A34 Injen unit. Done for cheaper though.
Old Apr 16, 2007 | 01:04 PM
SoonerFan's Avatar
Cletus
function over form
Old Apr 16, 2007 | 01:55 PM
STILLENGLE's Avatar
nice dude thats awsome
Old Apr 16, 2007 | 02:02 PM
NmexMAX's Avatar
dot dot dot ...
Texas just called, they want their state back.
SoonerFan's Avatar
Cletus
please check sig pic size
sig rules http://forums.maxima.org/showthread.php?t=512019
Old Apr 16, 2007 | 02:27 PM
slinky87's Avatar
not to be a hater or anything but that filter is only 3' in diamater which is choking your engine 3.5 inch to the MAF housing and a 3.5 or 4inch diamter filter would flow at least 100CFM or more without any loss in performance, youll gain more with a slightly bigger intake 4cyl cars need 3in 6cyl cars need 3.5 inch v8's need 4 inch or better
Old Apr 16, 2007 | 02:28 PM
The original VQ...
Ya i know its ghetto, but its made from pipes and couplings i had in the garage, and i started the project alittle late, didnt have time to let the under carrige paint dry......Needed to drive the car that night
Basiclly it costed me 60$(cause thats waht i paid for the K&N)
Nemax gimmie more info on the range rover MAF bro.
I was about to buy aarons spacers, but I needa new clutch , 103k its just not taking the beating im giving it. Also cause im going to the track in june or july and it wont lat till then.
Old Apr 16, 2007 | 02:29 PM
SoonerFan's Avatar
Cletus
you are wrong...the filter size is fine
Old Apr 16, 2007 | 02:41 PM
matt2k2max's Avatar
Looks awesome man... thinking of doing something close to that on mine...
Old Apr 16, 2007 | 04:22 PM
NmexMAX's Avatar
dot dot dot ...
Please don't get me started.
TB = 70mm. (2.75")
Old Apr 16, 2007 | 05:48 PM
The original VQ...
I know all that sounds good, but its not right bro....Sorry....
Either wat the filter inlet is 3.5, i Had to do some special stuff it to fit on the 3" pipe..
Old Apr 16, 2007 | 06:38 PM
nismopc's Avatar
Very informative first post.
Welcome to the forum.
Old Apr 16, 2007 | 06:44 PM
NmexMAX's Avatar
dot dot dot ...
Anyone that doesn't have any sort of piggy back, shouldn't mess with the MAF housing size, mmmmmk?
Old Apr 16, 2007 | 08:28 PM
Theyears02's Avatar
setup looks nice, not too sure about the pipe coating but if it keeps the air cooler then good news. cutting a hole in the fender might be mighty beneficial to you...
Old Apr 17, 2007 | 06:31 PM
Osburn2027's Avatar
what did you have to do to relocate the batterty
Old Apr 17, 2007 | 07:21 PM
The original VQ...
2 1.5 inch wide steel brackets going across.
Had to cut one bracket that was on the side, other than that I drilled the stock battey holder and just got it to fit.
If you good with a drill and a dremel tool or somthing like it, youll be ok.
I didnt have to thread any new holes or anything.
Old Apr 25, 2007 | 09:59 AM
Osburn2027's Avatar
i was able to relocate mine using existing hole no custom fab requred. pic coming soon'
Old Apr 25, 2007 | 10:14 AM
Osburn2027's Avatar
[IMG][IMG]C:\Documents and Settings\Compaq_Owner\Desktop[/IMG][/IMG]
Old Apr 25, 2007 | 10:21 AM
nismopc's Avatar
Sweet!
Image linked to Desktop
Old Apr 25, 2007 | 10:26 AM
Osburn2027's Avatar
[IMG]C:\Documents and Settings\Compaq_Owner\My Documents\My Pictures\dsc00022.jpg[/IMG]
Old Apr 25, 2007 | 10:27 AM
Osburn2027's Avatar
how do you post pics of the computer not the internet
Old Apr 25, 2007 | 10:28 AM
mist max2000's Avatar
ehhh i think u need help lol... u gotta host the pic somewhere... webshots.com
or photobucket.com or somewhere and then link it to that,.. well thats one way to do it anyone.. u cant link off ur desktop lol
Old Apr 25, 2007 | 02:40 PM
Osburn2027's Avatar
[/IMG]mount of the bateery tray veiw from the other side
A hole i cut to run me filter in the inner fenderwell.
Another view
Old Apr 25, 2007 | 02:41 PM
Osburn2027's Avatar
Old Apr 25, 2007 | 02:50 PM
nismopc's Avatar
I can't see anything. The pics are too small.
What did you use to cut the hole?
Old Apr 25, 2007 | 03:27 PM
CoolMax's Avatar
is invisible
Old Apr 25, 2007 | 04:54 PM
Osburn2027's Avatar
I used a drill bit to make a scuare hole by drilling many time to make a hole bigenough for a sawzall. then i had to use an air cut of tool for some finall triming. Also i got all my tubing and filter from autozone it was like 70$ including the filter
Old Apr 25, 2007 | 05:49 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
Same here. I saw this thread and decided that I was going to do it too. I moved the pan over the existing holes. Drilled the hole in the pan to line it up and secured it in place. I moved the fuse box right next to the other fuse box and screwed it in place in the existing hole there too.
Now all I've got to do is see if HD will take the bar that I bought back???
