Noise comming from the wheels
Old May 1, 2007 | 11:48 AM
Dimashka's Avatar
I just instulled Illuminas w/ eibach and when i turn the wheel all the way to the left I get a screatching noise as if metal rubs against metal. The car does not have to be moving. The noise only comes from the driver side wheel. Again this only heppends when the wheel is turned all the way to the left(THE LAST INCH OF MOVEMENT OF THE WHEEL) Please help.
Old May 1, 2007 | 03:10 PM
STILLENGLE's Avatar
you rotors maybe warped or you may have installed the springs wrong.
Old May 2, 2007 | 09:56 PM
Dimashka's Avatar
what do you mean installled the springs wrong?
Old May 3, 2007 | 08:50 AM
BLUEMAX01SE's Avatar
Probably put them in upside down or maybe you put the right spring on the left side and the left spring on the right side! Either way 2 rights don't make a wrong!
JK He means the spring may not be seated correctly on the strut! Good luck!
Old May 3, 2007 | 08:56 PM
Dimashka's Avatar
[QUOTE=
JK He means the spring may not be seated correctly on the strut! Good luck![/QUOTE]
so what do i do to fix this?
Old May 4, 2007 | 09:28 AM
Re-install spring on the strut! Make sure the starting point of the spring is seated kind of flush on the bottom part of the strut (small dent like looking portion at the bottom of the strut where the spring sits) Good luck!
Old May 4, 2007 | 09:34 AM
kukx30de's Avatar
look at the drivers side hub.
Below the connector for the outer ball joint there is a metal piece that is supposed to have a plastic cover on this. At full turn this metal piece hits the lower control arm.
Check that spot out to see if you have rubbing happening there.
Old May 4, 2007 | 12:14 PM
lake3031's Avatar
Also, when you rein install the string and front stut make sure the spring is seated inside the perch correctly and the 'out' is in fact pointing out toward you.
Old May 4, 2007 | 01:28 PM
n3985's Avatar
大陆弟弟
As kukx30de said, check your plastic bump stops.
Old May 4, 2007 | 02:55 PM
MaxBoost925's Avatar
Drug Money
The turning thing stopper thingy that hits the control arm has a plastic cap over it. See if you still have that.
-sooner, upstate, irish you know what i'm blabbering about right?
Old May 5, 2007 | 05:36 AM
EastSideMaxima's Avatar
A swift Bimmer driver
See post # 13
http://forums.maxima.org/showthread....ight=bump+stop
This is the solution! Thanks to Irish!
I had to do this and it was all set!
Old May 7, 2007 | 09:00 AM
Dimashka's Avatar
My car is in the shop right now, I will try this tomorrow. Why did this only happened after i droped it? How the drop and the stop bolt have anything to do w/ each other. Thank you guys again u being real helpful.
Old May 7, 2007 | 06:59 PM
Good question...
Same situation with mine...
So I would love to hear from the pros about this one.
Old May 7, 2007 | 07:02 PM
kukx30de's Avatar
hmm after re-reading his post... i feel definately rotors and pads for the pulsation when braking... as for the screech/squeal... have you checked the shields behind the rotors? and ofcourse as others have said check your strut install again... too many components touched and chances of mess up when doing struts...
Old May 7, 2007 | 08:57 PM
irish44j's Avatar
retired moderator
yes, you are correct. The new control angle causes it to rub differently.
Old May 7, 2007 | 08:58 PM
irish44j's Avatar
retired moderator
Originally Posted by EastSideMaxima
See post # 13
paypal to irish44jsuperchargerfund@irish.net
Old May 7, 2007 | 09:02 PM
irish44j's Avatar
retired moderator
as stated by me a couple posts up, when you lower the car, it causes the lower control arm to sit at a different angle relative to the hub/spindle assembly. because of this slightly different angle (it's only 5-10mm), the bumpstop doesn't contact the LCA bump plate flush, and instead hits it at a bit of on the angled surface. This causes the noise.
You can fix it by:
1. make sure the plastic cap isn't worn through...if it is thin, replace it.
2. put some machine grease on the LCA section where it contacts, to eliminate the friction and noise.
done.
Old May 7, 2007 | 09:04 PM
irish44j's Avatar
retired moderator
now, if it does this noise when the car is not moving AT ALL:
1. It could still be the bump stop
or
2. the upper spring perch is not aligned correctly outward
or
3. the end of the spring on the lower seat (the strut) is hitting metal-on-metal. The spring isolator should be made to overlap the end of the spring itself by an inch or so (as an insulator).
/thread.
Old May 8, 2007 | 03:20 AM
Originally Posted by irish44j
and how much $$$ is that? haha
Old May 8, 2007 | 07:24 AM
Dimashka's Avatar
its in the shop for a dififerent reason. I rearended some one a little. So my bumper and my new stillen kit is getting painted. But i am getting it tomorrow. I will try all of these things. I hate noises. Thank you guy. I will follow up.
Old May 9, 2007 | 01:01 AM
Dimashka's Avatar
I got my car back today. I did look at those bumpstops, and the cap is wearing out. So i rotated it for right now and put some grease and all the sound went away. thank you guys so much.
Old May 9, 2007 | 03:25 AM
MaximaInCT203's Avatar
schemes on chicks in his max.
Ayo depending on what kind of screech your hearing, it could simply be your power steering belt going bad.....That is, IF, none of the stuff mentioned above doesnt turn out to be the problem which i think it will. Just adding to the laundry list of possible sources
Hondarydr
Dec 30, 2024 06:15 PM
MikesChevelle
Nov 23, 2024 11:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
jhontelj
Aug 17, 2015 04:07 AM
