need help to open the for driver side door panel
Old May 2, 2007 | 01:56 PM
SoulEater's Avatar
is anyone know how to open the door panel in 2000 max on driver side. i have a rattling noise from inside. i want to fix the problem. it's so annoying.
Old May 2, 2007 | 03:51 PM
Professor's Avatar
^_-
Yank the screws and pop it off, its rather easy.
Old May 2, 2007 | 03:52 PM
MIXXMAX's Avatar
1) Power down driver's side window all the way down.
2) Pop the screw cover inside the door handle pull of the power window/lock switch. Remove screw. Pull up trim panel and disconnect harness.
3) Pop the step light cover off. Disconnect the harness.
4) Remove the screw cover from the right hander corner of door. Remove screw.
5) Pull the trim from off from the inside pull handle. There are tabs on the top and bottom of trim.
6) Start from bottom of door and pull off door panel.
7) Disconnect harness from the trunk and gas switch.
8) Done!
Old May 2, 2007 | 04:40 PM
SoulEater's Avatar
8) Done!
Wonderfull thanks buddy
vingodine
45
May 21, 2016 12:46 PM
Stelianos
Aug 19, 2015 02:07 PM
shaunkey1
Aug 18, 2015 10:09 PM
