DO NOT CLEAN 02/03 Thottle Body
Old May 11, 2007 | 06:43 AM
  #41
DaBoxSE's Avatar
So I'll admit that I did clean the TB and moved the plate... Now I have that rough idle. Odd thing is, this morning I was driving to work and my started having intermittent hesitation. My CEL has been on due to P0138 O2 sensor high voltage since I put the car back together this weekend. This morning the CEL started blinking then came back on solid. Could this be related to the TB? or a problem with my MAF?
Old May 11, 2007 | 07:16 AM
  #42
SoonerFan's Avatar
Cletus
sounds like TB to me...the flashing is usually a problem that can ruin a cat.
Old May 11, 2007 | 08:04 AM
  #43
NmexMAX's Avatar
dot dot dot ...
Blinking MIL = multiple cyl. misfire.
Old May 11, 2007 | 08:23 AM
  #44
DaBoxSE's Avatar
Well thats no good...
Old May 11, 2007 | 08:59 AM
  #45
SoonerFan's Avatar
Cletus
which means there is unburnt fuel which is bad for the cat
Old May 11, 2007 | 09:02 AM
  #46
DaBoxSE's Avatar
Sounds like it all ties together...now just where to start. My ex's 2k had similar problems. I replaced the MAF in her car and all was fine after that. Wondering if that could be the case for me. I've replaced my MAF once before, but I dont doubt I need a new one...
Old May 11, 2007 | 09:07 AM
  #47
NmexMAX's Avatar
dot dot dot ...
I would focus more on the problem at hand rather than what the aftermath is. You're disappointing me sooner, thought/hope you'd know better than this
Old May 11, 2007 | 09:08 AM
  #48
SoonerFan's Avatar
Cletus
yes its a misfire (i had the problem).
the point i was making was...fix the problem before you *** up the cat (which is expensive especially if its the precats).
to fix the problem - plugs and/or coils
Old May 11, 2007 | 09:24 AM
  #49
DaBoxSE's Avatar
I just changed the plugs this past weekend. Put in Denso Iridium plugs. So it must be the coils then? I never had a problem with them before... I have just spent a ton of money on the car last week to fix the tranny, clutch, seals etc...kinda disappointing that it looks like I need to spend hundreds more on other things. Ok, i'm done complaining.
Old May 11, 2007 | 11:14 AM
  #50
Whiggy's Avatar
I wanted to get everyone's opinion on cleaning the throttle body a while ago but have been undecided on whether I should try it or no. Now I am glad I have not done it.
http://forums.maxima.org/showthread.php?t=510889&page=2
I wonder if disconnecting the battery before cleaning it would make any difference...does anyone know?
Old May 11, 2007 | 11:40 AM
  #51
DaBoxSE's Avatar
I doubt that, my battery was disconnected for at least day or two before cleaning mine.
Old May 11, 2007 | 02:26 PM
  #52
SoonerFan's Avatar
Cletus
no
my battery was disconncted and the TB was disconnected from the wire harness...thats why I thought it would be ok.
Old May 11, 2007 | 03:29 PM
  #53
absoundlab
you have to pay to learn
Old May 11, 2007 | 03:55 PM
  #54
SoonerFan's Avatar
Cletus
not if people read this thread and learn from my mistake
you guys are all welcome
Old May 11, 2007 | 04:12 PM
  #55
nismology's Avatar
Nothing has been confirmed yet. All we know for sure is that manually moving the butterfly plate can cause some issues.
Old May 11, 2007 | 04:13 PM
  #56
nismology's Avatar
Old May 11, 2007 | 06:07 PM
  #57
2002 Maxima SE's Avatar
I clean mine all the time
sooner, did you do what I have stated time and time again works for me? It's not in your 'I did this items.
The last time I had throttle issues it was due to wiring mishaps w/ SAFCII, and using data scanning software, I was able to pinpoint the problem. Using live feed, I monitored APPS 1&2, and TPS 1&2. A problem will exist if either 4 of those sensors sends out an erratic (not within spec) signal.
The last time I cleaned my TB, prior to SAFC mishap, I let the car sit for 35 hours w/ the negative terminal disconnected, and it was fine after that and an IAVL.
I clean mine every 30k miles.
Old May 12, 2007 | 03:29 PM
  #58
Decoy036SPD's Avatar
well lets see. I made the same mistake as you. however instead I just unplugged the battery and let the car sit for a few hours. plugged it back in. did throttle re learn and ecu clear. drove around for some time. and did it again and car was fine..
Old May 12, 2007 | 03:38 PM
  #59
manually removing the butterfly does not cause problems....
Old May 12, 2007 | 03:47 PM
  #60
SoonerFan's Avatar
Cletus
really?
you wanna elaborate?
thats why everyone on here agrees that is is bad?
thats why five dealerships that I have talked to say it causes problems?
Old May 12, 2007 | 05:19 PM
  #61
Ahmad_1290's Avatar
I cleaned my tb (i didnt remove the butterfly tho.. i opened it a few times)and my after i got a CEL and my idle was always at 1000. I did the ecu reset a bunch of times. The idle would drop but after i turn off the car then start it back up it'll be back at 1000. Then i disconnected my battery for 24 hours, and now its fine.
Old May 12, 2007 | 05:54 PM
  #62
q45Owner's Avatar
If you are so afraid of the TB cleaning, take it to the stealership - they charge $99 for this service and should keep in things order.
When I did mine, I got the high idle, took it to the dealsership and asked them to do a TB Clean service, which they did and the idle was reset using the Consult.....
Old May 12, 2007 | 09:27 PM
  #63
really?
I removed the butterfly plate. it set off a check engine light. I tried relearning the throttle body and ecu to no avail. I then unplugged the ecu for several hours. I then relearned the throttle body and ecu and the car worked perfectly. ever since for at least 4 months.
Old May 12, 2007 | 09:45 PM
  #64
nismology's Avatar
I see a pattern here...
Old May 13, 2007 | 06:54 AM
  #65
SoonerFan's Avatar
Cletus
so what caused my problem since i did all the same steps?
Old May 18, 2007 | 05:33 PM
  #66
SoonerFan's Avatar
Cletus
just got my car back from the dealership
ECU replaced
idle problem fixed
Old May 18, 2007 | 05:35 PM
  #67
NmexMAX's Avatar
dot dot dot ...
You never did try and d/c the battery for a long amount of time, (Couple days), or did you?
Old May 18, 2007 | 05:36 PM
  #68
SoonerFan's Avatar
Cletus
i did.
i disconnected the battery when i did the coils and left it disconnected until the next day (about 32 hours)
Old May 18, 2007 | 05:49 PM
  #69
HotshotVQ35's Avatar
and that cost how much?
ECU replaced
idle problem fixed
Old May 18, 2007 | 07:37 PM
  #70
SoonerFan's Avatar
Cletus
as stated earlier in this thread -
free, covered by emissions warranty
Old May 18, 2007 | 07:59 PM
  #71
NmexMAX's Avatar
dot dot dot ...
Now send it to TS and have them give you CVTC map from a Z33.
Old May 19, 2007 | 10:30 AM
  #72
MaximaPolak's Avatar
Cliff notes: Do not clean the "drive by wire" throttle body because it could end up costing you a lot of money.
I made the mistake of cleaning the TB (and moving the plate) and afterwards the idle was messed up (it was high and erratic). I tried the throttle position relearning procedures (for the TB) to no avail. I went to the dealership for them to do the relearning procedure to the ECU ($98) and they werent able to do it because of the erratic idle. I had to replace the TB assembly which cost around $300 (I talked my way down from over $400). The relearning procedure still wouldnt take because of the erratic idle and a cylinder misfire code (from a preexisting coil problem). I ordered all 6 coils from daveb ($380) and installed them.
I went back to the dealership this morning and even though the idle is better with the new coils, the procedure still wouldnt take. The service manager decided that there is actually a problem with the ECU. Since the throttle was messed up, to much power was going to the part of the ECU that processes the idle/throttle and burned out a circuit preventing it from accepting the relearn. They ordered a new ECU that (thank god!) is being covered by the emissions warranty.
All of this because I cleaned the TB.
MODS: Please make this a sticky or add the link to a preexisting sticky
You should have driven around on it, and it would have fixed itself...when the cleaning your TB threads started to come out a long time ago, I thought to myself, "why not?". I cleaned the TB and had the high idle...went to the dealer. They told me I needed a new ECU then a new TB and finally I got so pissed I just went home. After a 100 or so miles (on my way to Florida from Jersey) the SES turned off and the idle was back to normal.
I had to clean my TB again when my intake sucked up some water. I then too had a high idle and it fixed itself.
You can clean it, but you will get an SES light for a while.
Old May 19, 2007 | 04:11 PM
  #73
SoonerFan's Avatar
Cletus
i drove the car for about 150 miles while waiting for the ECU to arrive. it didnt fix itself.
Old May 19, 2007 | 04:26 PM
  #74
Spliff_Star91's Avatar
i have also once cleand my tb and a couple of days after the idle was high around a (1100) and it had a engine light as well tryied to replace the idle sensor nothing went to the dealership to see what the problem was and they said coils and ecu around a 1200$ worth of work which i said no way. i tried to unpulg the battery from the terminals and would last about 100k unitl engine light would show again I kept driving the car for about 3 months after same problem high idle. During the 4th month i started my car one morning and nothing no light nice idle around (550) since this i have been driving my car for about a year and a half and been all good. It is very bizzare that this has happened but ive heard other stories of this happening. i own a 2000 max
Old May 19, 2007 | 04:28 PM
  #75
SoonerFan's Avatar
Cletus
so
clean throttle body and deal with the problem for months or pay to fix the problem
or...
dont clean the TB
Old May 19, 2007 | 10:05 PM
  #76
Project323
as many times i've done cleaning/removing TB and intake and all related to this, i never EVER had any issues with idle/ecu.
Old May 19, 2007 | 10:40 PM
  #77
JROD'02's Avatar
Why is the high idle speed a symptom of this? What causes the increased revs?
Old May 20, 2007 | 05:54 AM
  #78
Puppetmaster's Avatar
That's because you have a different car and TB.
Thread title = "Do not clean 02/03 throttle body"
Your car = 2000 Pearl White
Old May 20, 2007 | 06:29 AM
  #79
SoonerFan's Avatar
Cletus
if you take time to read the entire thread...it is explained in detail
Old May 20, 2007 | 11:02 AM
  #80
boris's Avatar
Originally Posted by steven88
...if you put it to reverse with IGN on...stepping on the gas will move the throttle plate...
If we do it this way (or remove the entire TB without touching the throttle plate) will we get issues?
Actually i don't see why we would.
