Help Please
Old May 11, 2007 | 06:26 PM
03tgtmaxima's Avatar
Help Please
What up all? well the string of luck continues and it is rubbing off on the max. I had a brake and bat. light come on at the same time and the alternator was making an obvious noise. when that light's would stay on after a while when i would step on the brakes my car wouldnt die but acted as if i was about to. if in drive i got no action from the gas pedal, shift it to Neutral and then the pedal would be active again. After a couple days passed, even after reving it i could not get the car to respond when put back in gear.
The alternator was changed today at 2:30 and it did the same crap on the freeway so i had to pull off and shut down. The car would not start again and clicked as if the battery was dead. after a jump my car made it back about 4 miles to my house and died again and didnt start. to shorten the story my car was towed home and i am ripping my hair out trying to figure this out.
Even a hunch would help me out at this point.
thanks all
-Stanley
Old May 11, 2007 | 07:02 PM
atom's Avatar
its your battery. Same thing happened to me off and on for a few months.
Old May 11, 2007 | 07:13 PM
Gjohnson's Avatar
I would definatley say battery or altenator related. Those same lights poped on when one of my belts snapped last year and it was because the altenator was no longer being driven. I would pull the battery and take it down to the nearest auto shop and have it tested. That or take the entire ride down there and have them check the new altenator as well.
Old May 11, 2007 | 08:17 PM
PandaXpress's Avatar
make sure the alternator was installed properly..
Old May 11, 2007 | 09:55 PM
Black96Max's Avatar
battery...i had that problem with my old 4th gen...changed the battery and never had a problem again
Old May 16, 2007 | 09:30 AM
thatks for the help ya'll. i am gonna pop the new battery in tomorrow.
Old May 16, 2007 | 09:32 PM
OK now i am stumped i guess i will replace the Alt. again i popped a new batter into it it about 5 minutes ago and same crap. any other ideas
Old May 16, 2007 | 11:49 PM
tedo007's Avatar
faster than you think
may be the wire from alternator to battery is loose check and make sure everything is connected right
