2K Double Din Radio Kit??? Where to get it..
Old May 13, 2007 | 09:55 AM
Insane Maxima's Avatar
Hey guys i know im kind of a newb here but i have been working on the sound system in my max and as of now i have a flip out screen. The only reason i dont like it is because it blocks the damn vents. Anyone know where i can find a double din kit for the new pioneer d3? Thanks a lot guys.
Old May 13, 2007 | 09:56 AM
SoonerFan's Avatar
Cletus
if only there was a forum to ask audio/electronic questions
http://forums.maxima.org/forumdisplay.php?f=25
Old May 13, 2007 | 11:11 AM
maxspeed96CT's Avatar
The original VQ...
I got mine from sound domian, just had to cut a small divider that went across the center.
Old May 13, 2007 | 12:29 PM
djfrestyl's Avatar
Suspension Yoda
http://www.courtesyparts.com/Merchan...de=68750-VENTC
That is what you need, and yes, that is the price.
Old May 13, 2007 | 05:12 PM
The original VQ...
na man, dont pay 140$
http://sounddomain.com/
check my setup out
Old May 13, 2007 | 06:52 PM
djfrestyl's Avatar
Suspension Yoda
Yes, and that requires cutting/sanding, test fitment, etc. To each his own.
Old May 15, 2007 | 06:50 PM
98maxi's Avatar
I just did one in my 00 Max and it didn't require sanding, just cutting of the middle section of the Scosche NN1494 kit (http://www.sonicelectronix.com/item_...-+NN1494.html). The part that takes the longest is modifying the aluminum bracket that is going to hold the radio. Basically, you drill another hole lower than the OEM hole. By holes, I mean this. There are 4 holes on each side that holds the OEM radio. You would use 2 holes at an angle from each other per side, meaning drill one hole right below the indentation at the bottom of the top right OEM hole and another hole at the bottom left of the OEM hole. From there, you have to test fit and that's it. I didn't do a write up for it but that's how I did it. This is a picture of mine. I used a Kenwood double DIN though.
Old May 15, 2007 | 07:02 PM
imported_Jay_5's Avatar
Looks pretty good
Old May 15, 2007 | 07:08 PM
98maxi's Avatar
Thanks...I'm going to add the NAV unit next...should be here in the next week or two. I'll take day time pics next time with the NAV screen on.
Old May 15, 2007 | 07:30 PM
SEmy2K2go's Avatar
Go BUCKS!!!
I got mine from another member on here for $50. Check the 5th gen classifieds. You may get lucky.
Old May 16, 2007 | 04:28 AM
djfrestyl's Avatar
Suspension Yoda
No one should have to modify their radio bracket to hold a STANDARD sized HU, whether it be double or single din. Just the fact that you have to modify mounting holes is reason enough to say that the Scosche kit sucks.
Old May 16, 2007 | 06:06 AM
burnurass's Avatar
Saw you on rt.22 today..murano rims looking sexy while in motion.
I tried the scosche...it sucks A LOT!! I went with the OEM kit and have NOT looked back. Recently picked up another one for my special project for REAL cheap....cheaper than tim's. Just gotta keep your Eye out for one...
Old May 16, 2007 | 03:26 PM
djfrestyl's Avatar
Suspension Yoda
Thank you sir...
What's the project?
Old May 16, 2007 | 05:40 PM
Squirrel82's Avatar
Lazy *****.......
Old May 16, 2007 | 05:51 PM
djfrestyl's Avatar
Suspension Yoda
Yea, lazy, that's it
Old May 16, 2007 | 06:01 PM
slickrick's Avatar
I'm not lazy...I hired Kpr10is to do my Scosche kit.
Old May 16, 2007 | 07:27 PM
The original VQ...
You must not have a bose unit.......
Those of us with SE maximas have a huge bose unit and require the kit.
i didnt have to do much work to do min,e the center trim pice is s thin i used a box cutter to cut it off.
Old May 16, 2007 | 07:34 PM
djfrestyl's Avatar
Suspension Yoda
Bose or not, shape of the bracket/opening/dash/kit are the same. SE/GLE does not matter either.
Old May 16, 2007 | 07:35 PM
slickrick's Avatar
all 2k+ maximas except GXE's had the DD unit...hence the "gxe dash kit." Nilesh knows what he is talkin about.
Old May 16, 2007 | 07:37 PM
nismos14's Avatar
§è~® f®ÈÄk
Ya and? The one he linked would go in place of the bose area.
You guys using the scosche have fun with a poop looking dash
Old May 16, 2007 | 07:46 PM
slickrick's Avatar
Hey don't hate kid...I got my dash kit for $7 and Kevin hooked me up on the custom fitment.
Old May 16, 2007 | 07:49 PM
nismos14's Avatar
§è~® f®ÈÄk
As long as you like it,
Old May 16, 2007 | 08:43 PM
98maxi's Avatar
Everyone has an opinion. The way I see is I modified the radio bracket slightly. The modification doesn't keep me from putting the OEM radio back if I wanted to. The kit cost me $15 and OEM kit is $150+. I'll take the kit for $15, not to mention that the kit doesn't look bad at all. People who have seen the radio in person like it....like everything else, there's ALWAYS going to be people who DON'T like certain things...that's life
Old May 17, 2007 | 02:55 AM
The original VQ...
Nope I dont care what you say mine looks better
Plus its abut 100$ cheaper
Old May 17, 2007 | 04:35 AM
djfrestyl's Avatar
Suspension Yoda
Exactly, someone (a very skilled installer) took the time to cut/trim/sand/modify the kit so that it fits and looks right. In my opinion, if I buy something, no matter the cost, it should fit for its purpose and require no modification. That's exactly what the concept of a dash kit is made for - to fit and trim out a dash. What's the point of spending ANY amount of dollars on something if it does not fit right out of the box?
Old May 17, 2007 | 04:40 AM
LoSt180's Avatar
geeze, they raised the price. I thought $90 was too high a year and a half ago
Old May 17, 2007 | 05:05 AM
nismos14's Avatar
§è~® f®ÈÄk
Doesn't matter
When it all boils down to it Alti dash kits > 5th gen max kits.
Old May 17, 2007 | 08:39 AM
slickrick's Avatar
yep...the only reason Kevin did the work was because this kit was about 3 years ago and nobody posted how BAD it was, so Kevin was a lil mad when he had to do the work. In hindsight, Dave B should have been given a call.
Old May 17, 2007 | 04:42 PM
djfrestyl's Avatar
Suspension Yoda
Agreed. I've purchased two from Dave B in the three years I've owned this car - one was $81 and change, the other was roughly $88.
Old May 17, 2007 | 04:58 PM
Squirrel82's Avatar
15 dollars
Old May 17, 2007 | 07:52 PM
The original VQ...
Doesn't matter
hahahaha
10 char
Old May 17, 2007 | 08:02 PM
The original VQ...
Thats my kit, but i cut that center divider
Originally Posted by Squirrel82
15 dollars
worldwiderecognized
Sep 30, 2015 01:16 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
Pied
Sep 26, 2015 03:29 PM
