I need help
Old Jun 8, 2007 | 12:56 PM
supermanrox305's Avatar
I need help
Does anyone know the part number for the injector plugs on the 00vi ? Or where can i get the plugs ? Napa, Advance, Anywhere ?
Old Jun 8, 2007 | 12:58 PM
STILLENGLE's Avatar
courtesy parts.com or dave b
Old Jun 8, 2007 | 01:07 PM
Didnt find anything at courtesyparts.com
Old Jun 8, 2007 | 01:08 PM
STILLENGLE's Avatar
Do you need the whole fuel injector or no.
heres two links
http://www.courtesyparts.com/Merchan...de=16600-480CC
http://www.courtesyparts.com/Merchan...Code=16600-A32
hope that helps its courtesy parts if you couldnt find it on there.
Old Jun 8, 2007 | 01:23 PM
No i just need the plugs that connects to the injector
Old Jun 8, 2007 | 04:29 PM
NmexMAX's Avatar
dot dot dot ...
I have a used A32 engine harness. Perhaps you could take a picture of the connector you need to connect into and I can cut some off, send them to you, then you could splice them in.
So, why do you need these plugs? What's the problem here?
Old Jun 8, 2007 | 05:13 PM
I did the 00vi kit swap. And i never got the plugs for the injectors. So we just did something there to them work and for the car to turn on. So now one of them is loose.
Old Jun 8, 2007 | 05:25 PM
NmexMAX's Avatar
dot dot dot ...
Old Jun 8, 2007 | 06:28 PM
Tommorow i will take. The weather is not good in miami
Old Jun 10, 2007 | 02:54 AM
I found out that they are top fed injectors. Like the ones that 3.5 use. So i think i could use 3.5 injector plugs. Or i could just get the ones that come on the 2000 or 2001 maxima's. Does anyone have them ?
Old Jun 10, 2007 | 02:15 PM
NmexMAX's Avatar
dot dot dot ...
Try the classified forums
Old Jul 13, 2007 | 05:30 PM
mr_elotoe's Avatar
Diznatin Mizaxima.org Mizember
NmexMAX...still got thhat A32 engine harness??? You could really be my life saver. I need one electrical connector for one of the ignition coils in my '01 and I'm hoping that the connectors are the same. whattayahtinkaboutdat?
