Weird electronic malfunction
Old Jun 9, 2007 | 11:48 AM
StillenMax80x20's Avatar
What would cause the Power door lock mechanism (remot keyless as well) to stop functioning as well as the automatic light on/off with open door and engine off function?
It's not the door switch.
The car runs fine except for a dead battery as a result of this other issue.
I also couldn't find the fuse /relay for the power door locks. Though the keyless relay I DID find.
Thanks in Advance!
Old Jun 9, 2007 | 01:17 PM
steves01max's Avatar
Did you check all your fuses, under your hood on both sides, under your steering column by the door? Sounds like a fuse to me from what you've written. Doesn everything else electrical work, interior lights, stereo, clock, gauges, etc.?
Old Jun 9, 2007 | 01:20 PM
SoonerFan's Avatar
Cletus
its a fuse...check them all
Old Jun 9, 2007 | 10:20 PM
yeah it wasn't a fuse, as it turns out it was some sort of result from the battery dying. i replaced it because it's 7 friggin years old and then it all worked fine. Weird stuff, i couldn't lock/unlock the doors at al, remote or door switch, and the headlights only turned off by the switch. Strange electronics in this car
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
bennuss
Sep 11, 2015 05:55 AM
