Need help w/ a code
Old Jun 19, 2007 | 08:09 AM
03maxima1's Avatar
Need help w/ a code
Has anyone pulled this code before:
P1800 Manufact. Control Transmission
Old Jun 19, 2007 | 10:50 AM
oldngivout's Avatar
Willing to learn
From the 03 Maxima ESM:
P1800 VIAS control solenoid valve circuit open.
Old Jun 19, 2007 | 11:35 AM
nismopc's Avatar
Yup, mine gets same code all the time.
Has to do with the butterfly mechanism and VIAS valve.
The code goes in pending state for a while then get stored after so many times of being triggered. I have not been able to find out what the reasoning is. Can only think that the butterfly either stays open too long or closed too long which causes the trigger.
Old Jun 19, 2007 | 11:36 AM
nismopc's Avatar
By the way, that is the GENERIC code for P1800 used by most car manufacturers. Nissan uses same code for Nissan specific reporting. Reason for the difference between the code reader and Nissan FSM and/or CONSULT II reading.
Old Jun 19, 2007 | 11:48 AM
oldngivout's Avatar
Willing to learn
I have not seen that one before, but it may trigger only occasionally because the VIAS only operates above a certain RPM? If you don't drive this way often, then the code would not set.
I would suggest that you check the solenoid valve in the system for 2 things: power and operation.
Old Jun 19, 2007 | 11:50 AM
nismopc's Avatar
It's definately working. Correctly? I don't know, but it is working.
I read a lil in the FSM on how to test, but have not gotten around to it yet.
Car has no evidence of driveability issues, so...
Old Jun 19, 2007 | 08:46 PM
03maxima1's Avatar
thanks, but what does that mean?
Old Jun 19, 2007 | 08:48 PM
03maxima1's Avatar
So you never bothered to do a diagnostic test to try and find out what it is?
Old Apr 16, 2008 | 07:48 AM
maxximaa's Avatar
anybody got a solution for this?
the dealer tried to replace the solenoid but they got the wrong part.
so i left then the code went away. after more than 5 months and now its back with other codes
its driving me
Old Apr 16, 2008 | 08:04 AM
NmexMAX's Avatar
dot dot dot ...
Perhaps use the the correct part.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
