Anyone else have this problem?
Old Jun 23, 2007 | 02:06 PM
thisasian's Avatar
Anyone else have this weird problem with their car? So here's the situation, it's warm outside, about 70+ deg, the car is in drive, and I'm stopped in traffic. The car feels like it wants to pull forward when I have my foot on the brake. I can feel the car wanting to rev higher. When I notice, I put the car in park or neutral to check what's wrong. The car revs higher by itself. Initially it just goes to about 1500rpm, but when it gets bad, or when it's a really hot day, the engine revs to 3000rpm.
After a few minutes of this, when I'm definitely stuck in stop and go traffic, the car will start to overheat. It let it get bad once, hope it didn't warp the head or gasket
Would someone help me track this down?
Only mod I've done that I thought would have an effect is the O2 sim. I took it off, and soldiered the wires back together (have P0420 again). It still does it with the O2 sim off, though it hasn't gone to 3000rpm again yet.
I took out some of the fuses on the passenger's side box once (fuse box in the engine bay). Not sure if I might have mixed up a few of those fuses (seemed like they're mostly the same size anyway).
I had the Coolant flushed and thermostat changed, but it hasn't helped.
Thanks Org.
Old Jun 23, 2007 | 02:29 PM
vansskaterfreek's Avatar
when i bought my car, it did the same thing....... all it was, it was the cruise control cable, it wasn't seated properly.....thus pulling on the throttle plate just as you would when applying the accelerator pedal
Old Jun 23, 2007 | 02:32 PM
AnDyMaN's Avatar
are you the only asian in RI?
and i agree vanskaterfreak
Old Jun 23, 2007 | 02:52 PM
CoolMax's Avatar
is invisible
http://forums.maxima.org/showthread.php?t=526878
Old Jun 23, 2007 | 02:53 PM
NmexMAX's Avatar
dot dot dot ...
check fuses, check TB/throttle cable hardware.
Old Jun 23, 2007 | 10:35 PM
mist max2000's Avatar
double thread post FTMFL... hope u fix ur prob though...
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
