Steering vibration
Old Jun 27, 2007 | 06:48 AM
xmaltbeerxcp's Avatar
Steering vibration
Hey so on my 03 Max, after a wheel alignment and balance I am still having some vibration from my steering wheel at 70-80 just cruising. I have Stillen drilled rotors and Axxis pads. No vibration while braking just while cruising so I don't think it can be the brakes?
Old Jun 27, 2007 | 06:56 AM
Teddie18's Avatar
It could be a tire that has a bad belt. Or bad alignment, balance, damaged wheel or wheels. You also should have the steering/suspension checked for excessive play (out of spec) or damaged/worn components.
Old Jun 27, 2007 | 08:40 AM
LACEY DAVIS's Avatar
after markret rims you may need hub rings
Old Jun 27, 2007 | 09:19 AM
imported_black_max's Avatar
I had the same problem, but my tires were getting pretty worn plus whoever owned my car previously had put on 245s on the stock rims. A new set of tires solved my problem. If your tires are good they could need rebalancing or you could have bent wheels.
Old Jun 27, 2007 | 08:10 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
balance and align bad wheel or tire
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
