Brakes work and then don't
Old Jun 30, 2007 | 07:23 AM
nfisher50's Avatar
I tried searching on this topic, but only came up with clutch threads....
My brakes sometimes will go to the floor while tring to stop. I have to pump them to get pressure to build. It doesn't seem to do this everytime, but atleast a few times a day. Usually after a long time of not using them. There are no leaks, fluid level is good, brake pads were changes a couple of months ago. (I didn't open the brake system, so I don't think this could be related). Nissan says that they think it is the master cylinder. Any ideas. I guess it is the cylinder or th brake booster, but don't know which to go after. Any help?
Old Jun 30, 2007 | 08:10 AM
wngan9447's Avatar
Chicken Feet Croo!
Bleed your brakes... sounds like you have air in your system
Old Jun 30, 2007 | 08:40 AM
redmaxpa007's Avatar
i SeE what you did therE
yep. try that before u replace anything..
Old Jun 30, 2007 | 09:31 AM
steves01max's Avatar
worst case.. downshift and throw out an anchor lol jk
Bleed the lines
Old Jun 30, 2007 | 10:18 AM
A33 VQ30DEK's Avatar
you might have a bad brake master cylinder
Old Jun 30, 2007 | 04:21 PM
nfisher50's Avatar
I ended up replacing the brake master cylinder and bled the brakes with a speed bleeder. Thats the only way to go!
Old Jun 30, 2007 | 09:22 PM
nismopc's Avatar
Probably should have bled the brakes first. Sounds like you might have had moisture in your fluid which causes the fluid to boil faster than normal.
This will create the same exact scenario you were mentioning. But good to hear you got it fixed.
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
