Maximum Tire width/height...no this is not starting the fight over 'rim sizes' again!
Old Jul 17, 2001 | 12:17 PM
jjs's Avatar
jjs
Does anyone have any figures on what the maximum tire section width and overall height is for the 17" SE/AE?
I am referring to potential rubbing in the wheelwell, etc...
NOT to what is safe and what is not as far as the whole rim size fight goes!!!
Specifically I am entertaining the idea of Dunlop SP Sport A2's in 235/55 17 98H. While maybe not a razor sharp as a 50 series or lower, my only concern is that they are .8" wider in section width and a whopping 1.7" wider in tread width than stock. They are also 1.2" higher than the RE92's.
Thanks!
Old Jul 17, 2001 | 12:26 PM
Jeff92se's Avatar
I'm needing a caw
Why would you want to put the widest width tire you can on a 7" rim? At some point, the gains from the wider tires do not outweigh the bigger size/weight of the tire.
I suggest you use this link to determine what tires sizes keep the overall diameter of the tire as close to the oem diameter as possible.
IMHO. A 225/235 is about as wide as I would go on the factory maxima 7" rim.
http://www.miata.net/garage/tirecalc.html
Thanks!
Old Jul 17, 2001 | 12:32 PM
jjs's Avatar
jjs
I am not going with the widest I can...
I simply want to know what boundaries there are for mounting tires of various sizes.
I indicated a 235 tire above and actually the rim sizes allowed (according to Tire Rack) are 6.5"-8.5". Well within specs now famous from the 7" 'controversy'.
The SP A2's simply had a good price, one helluva treadwear number...420 (even though I know this varies greatly between manufacturers, it beats the heck out of our stock 160). I am also not concerned with giving up some cornering for longer life, better traction, lower cost and maybe as a benfit, a slightly more comfortable ride.
Old Jul 17, 2001 | 03:47 PM
y2kse's Avatar
Re: I am not going with the widest I can...
Before you go any further, I urge you to take a look at the web site Jeff92se provided. I think you're forgetting something.
Old Jul 18, 2001 | 07:21 AM
jjs's Avatar
jjs
Two things....
1. Which one are you referring to...the miata tire calc site?
2. If your concern and what I have overlooked is a speedo calibration, I can live with that. Over the years I have had an '88 5.0 Mustang with off size tires, and actally still have a '97 Ram with taller/wider than stock. I have gotten rather good at programming my own head to take into account a recalibration on the fly. A couple of days in any car and I know which side of the 'real' MPH the needle should be on.
Thanks!
Maxboy23
Sep 8, 2015 06:53 PM
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
maximaham
Aug 20, 2015 10:23 AM
