Stupid question for OG's
Old Jul 17, 2007 | 04:46 PM
MaxBoost925's Avatar
Drug Money
For the rear on our 5th gens, is there supposed to be a little toe in stock? I put 20mm spacers in my rears and now looking from the top of the rear fender down, it looks like I have some toe-in as well as a little negative camber.
Just making sure my car isn't fcked up.
Thanks guys.
....Eugene, you should know more about this since you're running my wheels.
Old Jul 17, 2007 | 04:53 PM
S00NR1's Avatar
OU > *
Yes.....I made a thread for this a year or two ago with pics included. Try an Eibach camber kit if you want to bring it back up to vertical.
Old Jul 17, 2007 | 05:02 PM
Drug Money
No, not the front - the rear. The rear is not adjustable, I just want to make sure that mine is still within spec.
But thanks for the quick response.
Old Jul 17, 2007 | 05:16 PM
S00NR1's Avatar
OU > *
Got it -- as for the rear, that is what I was referring to in my post. It looked to be toed in by a few degrees, but it is less noticeable with the 235s as compared to the 225s I had on when I created the thread (RE92s).
Old Jul 17, 2007 | 10:38 PM
DasYears
Can i still answer even if im not an OG?
seems that a little negative camber is good for your handling so dont worry about that, but i dont think toe in on the rear sounds normal, but really i dont know
Old Jul 18, 2007 | 01:12 PM
Drug Money
Sooner, Irish?
The toe is pointed pretty inwards too.
Old Jul 18, 2007 | 02:11 PM
DasYears
take a picture and post it
Old Jul 19, 2007 | 07:26 AM
OOmaxSE's Avatar
If you are unsure, which you seem to be... head over to an alignment shop and get a 4 wheel alignment which will knock your rears (and fronts) back in spec.
Old Jul 20, 2007 | 03:47 PM
Drug Money
Rears are not adjustable homie. If they're off, you're damaged somehow.
Old Jul 20, 2007 | 03:52 PM
upstatemax's Avatar
Neg camber is normal, toe... I don't think so.
I would have it checked out.
Edit... Little bit of Toe *might* be normal, I would look up the factory alignment specs...
upstatemax's Avatar
Not true...
Old Jul 20, 2007 | 04:00 PM
OOmaxSE's Avatar
Nope "g-unit!"... rears CAN be adjusted. *uber smiley face*
Old Jul 20, 2007 | 04:04 PM
upstatemax's Avatar
Old Jul 20, 2007 | 04:26 PM
OOmaxSE's Avatar
Originally Posted by upstatemax
Paraphrase tho, no?
Old Jul 20, 2007 | 04:41 PM
Drug Money
hehehe. I know about the camber. Its just the toe I'm more concerned about.......ese!
Old Jul 20, 2007 | 04:54 PM
Drug Money
....without a sledgehammer?
Old Jul 20, 2007 | 08:12 PM
ChromeSE5's Avatar
My brother noticed it too... I wasn't really looking but I think the spacers make the toe way more pronounced. I have a lot of camber too but the tires were from a 240sx owner so there was some inner wear. I want to fix it but my new hobby is costing a lot in terms of carbon fiber and titanium
Old Jul 20, 2007 | 10:09 PM
Drug Money
Thanks Eugene. So in the end, your car is still within specs right? I think it's our wheels that give it the illusion.
...what CF and Ti?
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
