Broke MY LinkaGe... PICS.
Hey guys i broke my shifter linkage on my 6 speed. I got a new one from nissan BUT i jsut cant seem to change it.
HAS ANYONE HERE EVER CHANGE THIS ? i cant figure out how to do it !!
IM SO FUKING FRUSTRATED RIGHT NOW !!!
PICS:
WHERE IT BROKE FROM ---
WHERE IT ATTACHED TO ON THE TRANNY---
NEW PIECE FROM NISSAN---
PICS:
i say weld it. i mean you could install that new one which sounds like a pain in the **** but i know its sounds ghetto but that could be a band-aid fix until you figure out how to install the new one.
edit: do you guys think that the sts had something to do with it? it might be a possible suspect. just a thought.
Happened to me:
It is a pain in the *** to replace. You have to have the car up on a lift to see where it meets the interior. Inside the car, you have to actually unbolt and lift your ECU to allow the linkage to be removed. I'm sorry you have to go thru it. I hated it, and actually drove the car for a week like that. I had the ES bushing (Red) as you can see, and somewhat attributed that to the stiffness and added wear on my linkage. I also believe I overtightened that bolt and didn't give the bushing enough lubrication.
Originally Posted by zero2sixtyZ
Happened to me:
Yea im ganna have sum1 do it, im not ganna tackle this, ima have to take a day off work.. not worth it. lol
JB Weld will NOT work, I repeat, will NOT work. Tried it, snapped right off again.
How did I drive like that? It was actually pretty simple. I moved the **** left and right to choose the gate, then I either pushed or pulled to get into gear. I was waiting for my shifter cable to arrive in the mean time. Trust me, I cut up my hand/knuckles pretty bad just shifting.
It happened one day after I pulled out of work. Noticed the shifting got a lot looser. Went into fourth and felt sooooo easy. Tried to shift down, and.... nothing happened. Ripped apart my center console, then BAM, there she was.
To the OP, if I didn't have a friend who could've helped me, I would've paid someone. It is a ridiculously stupid process to do. Good luck man, and I wished no one else had to go thru this.
Originally Posted by absoundlab
where did you get your intake?
Is that an ES bushing I see on the lever end?
NOW.. how the HELL did you get it back in ?? from inside the car i cant even locate the hold from where the thing exited from lol. and theres BARELY any room for me to squeeze my hand in under the car to push it in.. arrr... Please enlighten me how u put a new 1 in ...
i know i gatta drop the 2 new rods from the top behind that big black things going from side to side i forget what its called ( the BS thats blocking it all lol).. then did you put them in 1 by 1 while sum1 pulled it in from inside or what ?
i did all this alone, my friends comign by in about 4 hours to help me ill have an extra set of hand then..
So far everythings out, now i gatta put it all back in.
Apr 16, 2020 05:15 AM
t6378tp
Sep 29, 2018 04:27 PM
timmay5835
Sep 15, 2015 06:09 PM
That sucks.. I hope this didn't happen while you were driving.
Good luck with the fix.
