Bose Headunit and Temperature Display Goes off when head lights are on??
Old Aug 1, 2007 | 01:30 PM
mohmony's Avatar
I have a 2001 Maxima GLE With close to 100K Miles, Whenever the Headlights are ON -- The Display on the Odometer / Dashboard, Bose Head Unit Display and the Temperature Display are off..
Bottomline, No Ambient Light in my car after it turns dark...
Any clues as whats gone and how expensive is it to fix this?
Old Aug 1, 2007 | 01:31 PM
DasYears
do you have the gauge cluster light level set really low?
Old Aug 1, 2007 | 03:07 PM
bwinter7's Avatar
LOL I thought I had the same problem one night, I was coming out of my friends house, got in my car, turned it on, and boom, no interior lights. Everything worked, stereo, climate controll, but no dash lights. I reached down to adjust what I thought was the little dimmer switch, but I seemed to have found the mirror adjuster. I thought I blew a fuze or something, so I drove home on the highway using a lighter to see how fast I was going lol. Then the next day I realized what a stupid ******* I was lol
Old Aug 1, 2007 | 03:56 PM
00MaxSE's Avatar
Pointy Elbows
Were you drunk?
Old Aug 1, 2007 | 05:31 PM
bwinter7's Avatar
Originally Posted by 00MaxSE
Were you drunk?
no comment
let's just say this is my 4th maxima, I should know the difference between the mirror **** and the dimmer switch
Old Aug 1, 2007 | 07:18 PM
mohmony's Avatar
I tried it either wise -- No Luck.
Old Aug 1, 2007 | 07:22 PM
bwinter7's Avatar
You may need :
1- A new dimmer switch
2- A new fuse somewhere, check them
All those things you described are on the same circut, I would check the fuses, then get a new switch.
Old Aug 1, 2007 | 08:30 PM
Trurida18's Avatar
i'd say it was a fuse
Old Aug 14, 2007 | 07:26 AM
hehehh's Avatar
similar thing
In my case only the the bose displays comes off when I turn on the lights, the AC display works fine.
does this also sound like a fuse, or is it something else? thanks
Old Aug 14, 2007 | 12:45 PM
BMWHIGH1's Avatar
Could be a fuse
Old Aug 14, 2007 | 12:55 PM
radpp16's Avatar
find a fix yet?
Hey I got the same problem...My AC lighting and some buttons on the BOSE display don't work.
What's the fix.. what fuses are supposed to be changed.
Roger Diaz
Old Aug 14, 2007 | 06:45 PM
hehehh's Avatar
Originally Posted by BMWHIGH1
Could be a fuse
Do you think it is a fuse in the head unit or a fuse on the main panel? It sounds strange that there would be a fuse for just the display light...
Old Aug 14, 2007 | 07:23 PM
Stardust's Avatar
F---ing Kangaroos
check your fuses
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
iflexsteel
Sep 15, 2015 03:37 AM
Max139617
Aug 29, 2015 02:55 PM
doobadoo
Aug 15, 2015 06:43 PM
