Trouble code p720
Old Aug 6, 2007 | 05:02 AM
Totalpckge1's Avatar
Trouble code p720
I got the code going to Boston from NY. The code means the speed sensor is gone. I am looking in the book but it gives insuffent pictures. Does anyone know where it is? Thanks in advance.
Old Aug 6, 2007 | 05:13 AM
maximalxl's Avatar
From the looks of the location in the 2002 Max FSM it looks like the rev sensor and vehicle speed sensors are on the firewall side of the transmission and held in place by a single bolt. If you can access it from beneath you can probably disconnect the harness connectors, remove the bolt and replace the old sensor with a new one. The diagram on page AT-285 shows a good photo of the sensors locations.
Credit to Zero Duce SE
Old Aug 6, 2007 | 06:18 AM
Where is this diagram you speak of?
Old Aug 6, 2007 | 08:06 AM
maximalxl's Avatar
I thought I attched the picture onto the post...guess not....anyhow swing over to autozone or strauss.....and ask them they'll find out for u...
Old Aug 6, 2007 | 08:21 AM
Stardust's Avatar
F---ing Kangaroos
Do you think you could search for the answer yourself? Are you just that lazy?
http://forums.maxima.org/showthread.php?t=531298
http://forums.maxima.org/showthread.php?t=531345
Old Aug 6, 2007 | 01:30 PM
Very interesting point you brought up. And the answer is no I was unable to search for the topic because I am restricted from doing so otherwise I wouldnt have bothered any one of you for help. Thanks.
Old Aug 6, 2007 | 01:35 PM
DasYears
if you had read the sticky's you would have found a way to search. either way, did you get the answer from those threads?
Old Aug 6, 2007 | 02:00 PM
Stardust's Avatar
F---ing Kangaroos
http://forums.maxima.org/showthread.php?t=368622
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
