Sway Bar Bushings
Sway Bar Bushings
Now i could have sworn our cars use 23mm bushings. But when i went to Purchase them from http://www.energysuspensionparts.com
they had two parts listed:
1) the 23mm sway bar ES bushings (7.5125)
2) the 22mm sway bar ES bushings (7.5124)
My question is. Which part is the one that fits on a 2k1 5th gen? 1mm could mean the difference between too much play. I couldnt even find out what size the OEM bushings are.
Thanks for an assist
Originally Posted by Maxim(a)SerjVQ
SE models have a 23mm bar and need the larger bushings, other 5th gens use 22mm afaik
Originally Posted by Stardust
Wrong! All 2000 & 2001's have 22mm bars, 2002 & 2003 SE's have 23mm bars
My 2000 SE has a 23mm bar.....stock. Measured them with vernier calipers before I bought the bushings, just to be sure.
Looks like you got stuck with a re-badged GLE
as you can see.....it fits correctly
Originally Posted by irish44j
Wrong!
[img]http://memimage.cardomain.net/member_images/10/web/442000-442999/442543_408_full.jpg[img]
My 23mm bushings looked like they fit properly but the 22's fit better.
edit: when you replaced yours did you read what the stock bushing said? Mine clearly said 22
I don't recall them saying anything on them, and I usually look at old parts pretty close to see the wear patterns on them (my old bushings were beat to hell)
but that's the reason I measured them with my engineering calipers, because there was alot of so-called "authoritative" information out there that was conflicting at the time. We measured mine at (IIRC) 23.2mm and also measured someone else's (soonerfan's, I think) GXE which was 21.9 or 22mm....
clearly, though, it doesn't really matter much I guess....
so i guess i need the 22mm for my 2001 GLE. Im not upgrading the front sway bar btw
I ordered the 22mm ones from Energy Suspension....my brackets dont look to be in to bad condition. So im going to re-use them
[img]http://memimage.cardomain.net/member_images/10/web/442000-442999/442543_407_full.jpg[img]
Nissan you got some splainin' do do
That is very strange.
well. . .okay then. . . did stardust get his car used? or new? it could always be a parts bin snafu. Still seems like the information i gave was accurate in the case of Trurida. . . if non-SEs have 22mm, then whether they made a manufacturing change or a boo-boo on the 2000SEs, i think him needing the 22mm bushing wouldn't change?
Yeah, by looking at the pictures they don't seem to that bad. Looking at the first picture in the thread, they seem to have a tight fit.
On that note a related question, to slide the bushings the upper sway bar link end has to be disconnected and pushed in.., right?.
No, all you need to do is put a jack under the control arm and lift it.
But this picture tells a different story, it is one solid mass...
http://www.energysuspensionparts.com...E5124&cat=4206
^^ could be a number of reasons, maybe they are not hosting it, maybe they dont want to open up a BRAND new set of bushings, or maybe they are just a reseller, WHO dont have the product AT hand, the reasons could be endless..
Urethane bushings quicken the response somewhat. Less bushing compression allows the anti-roll bars to do their job more quickly. If you do the D bushings, definitely do the end links too.
knight_yyz
Nov 1, 2015 01:34 PM
ColdCananda
Sep 20, 2015 10:45 PM
of nissan do do things that way. Im just gonna go to autozone and pick them up instead of ordering them. 22mm here i come
small FSB
