Missed shift..Went from 2nd to 1st....
Old Aug 20, 2007 | 04:13 PM
shoman94's Avatar
Now I have a differential whine. Has anyone gone through this. Everything shifts the same....The whine is especially loud from 20-35mph when I'm barely on the throttle.
Any ideas of what it could be? Should I look for a used tranny....??
Jason
Old Aug 20, 2007 | 05:13 PM
theoutsider's Avatar
Might be a shot rubber strap or something?
Old Aug 20, 2007 | 05:17 PM
shoman94's Avatar
Shot rubber strap??
Old Aug 20, 2007 | 05:32 PM
Bufflomike's Avatar
Sexier Than Simpson
Is it gear or speed related. If its one gear its probably that gear, if it is speed you probably have a bearing, main shaft issue
Old Aug 20, 2007 | 05:33 PM
STILLENGLE's Avatar
Originally Posted by shoman94
Shot rubber strap??
Old Aug 20, 2007 | 06:02 PM
shoman94's Avatar
It's speed related...
Old Aug 20, 2007 | 06:04 PM
shoman94's Avatar
Originally Posted by STILLENGLE
Yea yea... It was a tard statement what he said.... maybe he translated wrong? lol
Old Aug 20, 2007 | 07:17 PM
00SEMAX19's Avatar
I did the same thing about 6 month at high rpm and have also had a gear or bearing whine ever since. The car drives fine, no problems so far but the noise is bothersome because I know I F'd something up.
What rubber strap?
Old Aug 20, 2007 | 08:00 PM
DragdMax's Avatar
i did the same thing at redline........
the dealership swapped my tranny........
Old Aug 20, 2007 | 08:31 PM
DasYears
how the hell do you go 2-1 at speed? you must have the motto "if you cant find it, grind it" cause i have to rev-match to get into first at anything over ~15
Old Aug 20, 2007 | 10:39 PM
wyche89's Avatar
i have to admit, i wanna get a 6 speed for my next car, but this kinda scares me.. lol.. and what the hell is rev matching? ahh so much to learn...
Old Aug 20, 2007 | 10:53 PM
Trurida18's Avatar
i know how to drive a stick..i wouldnt mind driving a 6 speed, they seem like so much fun....BUT it would be HELL here in Baltimore, and i know it. This city is one of the most congested in the nation, in terms of car/highway or street ratio, and flow of traffic
Old Aug 20, 2007 | 11:01 PM
DasYears
hydraulic clutch FTW. makes driving in traffic so much more reasonable. i drive in >45 mins of traffic on the way to work (freeway only, i get a lot more in town, going to dinner or w/e else) and its really not bad. i can handle it easy. have driven a 65 C10 ( 3 on the tree) in traffic and its 10000X worse
Old Aug 20, 2007 | 11:05 PM
Trurida18's Avatar
that makes me shift my direction I may decide to get an 03 6 speed by the end of the year
Old Aug 21, 2007 | 12:02 AM
shoman94's Avatar
I was running someone and shifted quick... I guess I hit it just wrong and it went in. First time this ever happened to me.
Old Aug 21, 2007 | 01:00 AM
accordingtou's Avatar
VQ30 DE T
Jason
2500rpm^@45mph^into 1st gear=omfg the stress on 1st gear you must of bounced off the rev limiter acouple times.
Try a different gear oil for now,
Dont feel bad I went from 4th to 2nd in my old accord.7k^rpms.I almost went through the windshield.Traded it shortly after.lol be glad you didnt blow the motor.
Old Aug 21, 2007 | 04:36 AM
Bufflomike's Avatar
Sexier Than Simpson
Since it is speed sensitive it sounds like a main shaft bearing, sorry. I would run it until it craps on you or you need a new clutch. I may also try some lubeguard at lubegard.com, seed based lubricant.
Old Aug 21, 2007 | 10:18 AM
00SEMAX19's Avatar
For me it went right in. I pushed the clutch back in so fast I have no idea how high the rpm went
Old Aug 21, 2007 | 02:18 PM
shoman94's Avatar
Now I'm having trouble locating a tranny. I only found 1 2004 6sp with locking diff... 1200 bucks..... pricey....
Old Aug 21, 2007 | 04:22 PM
dgeesaman's Avatar
Maintenance Monster
A lot of things can happen if you overrev a tranny. It's impossible to know what is damaged until you get the tranny removed, opened, and inspected. It could be as simple as changing the bearings, or may be more ugly like changing a gear and shaft because the high loads scored the sleeve bearing faces under the gear.
Dave
Old Aug 21, 2007 | 10:14 PM
02BBQ's Avatar
Shoman94- i did the same thing in my 02 when it had 36k on it and i just sold it at around 70k. Sound went away during this time and the trans was just fine.
Old Aug 22, 2007 | 07:20 AM
bert's Avatar
I did an accidental 3-2 shift a while back. I saw the RPM go to 8000. No real problems, no noise afterwords. This happened around 60K miles and at about 110K miles the tranny bearing went out and I did a compllete tranny job. I don't think they are related, or not very much.
For all of you who say that driving manual in traffic is a PITA, you don't know how to drive stick or how to put up with traffic. Drive like a truck driver. If you try to tailgate everyone in start-stop traffic of course you will go nuts. If you let them go and don't play the accordion game you will be OK, plus probably save your clutch. Worried that 'everyone will cut in front of me!'? Don't worry, who cares, lane hopping is usually slower than keeping a lane. Though knowing local patterns and selecting the optimal lane is possible. (e.g. shift left when on-ramps are comming, shift right when off-ramps are comming.)
You are on a uphill heading towards a red light? Coast up, in gear. You don't need to brake and you probably won't have to start from a dead stop. At a light and have a wait, put it in neutral, drop the clutch. On a hill too, use the parking brake.
Be courteous to others and appreciate those who are courteous to you. A thank you wave is nice. I will usually always let someone who uses their flasher in. No flasher, no help.
Old Aug 22, 2007 | 10:50 AM
pmohr's Avatar
No more Maximas...
You won't hit the rev limiter when you overrev a motor. It's only there to keep the engine from spinning above a certain RPM under it's own power.
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
