Wanna see engine bay naked ? Pics inside.
Hey guys, it's been a while since my last post about the rebuild of my 5th gen. Here is some pics of my max engine pretty much naked. As you will see I finally decided to remove the rad support and the upper part ( sorry I dont know how to call it ) while sandblasting the engine bay I found out that there was extensive damage on the rad support, so I decided to remove everything in front and replace with brand new parts. One of the problem I had with the max was a clunking that was happening here and there and I though it was my coilover, then I though it was a bearing and so on until I remove the rad support and find out that the engine support that connect to it was moving up and down because of very rusty part. See the pics, below.
I should be able to weld everything back over the next week-end and hopefully spray the primer and paint the engine bay shortly after.
I still have a lot of works to do, but the max should see the pavment by spring 2008 if I dont have major FU.
http://i3.photobucket.com/albums/y89...a/IMG_0027.jpg
http://i3.photobucket.com/albums/y89...a/IMG_0024.jpg
http://i3.photobucket.com/albums/y89...a/IMG_0028.jpg
http://i3.photobucket.com/albums/y89...a/IMG_0025.jpg
Cheers
AA
Cheers
AA
Originally Posted by CVicVogel
Obscene!!!
What I find interesting is the small size of the 2 channel rails that support the subframe. No wonder there is flexing.
Vic
Vic
Ya tell me about it, I wish I'd live in the south, but still we have a great living here and winter is only like from dec to march so it's not that bad once you get use to it. But the max will never see winter again.
Originally Posted by mtrai760
I just finished getting my new support welded in last weekend, putting the car back together now. Good luck.
Did you weld it with a Mig or the old way with acetylen/oxygen ?
Originally Posted by doublea
Did you completely welded the rad support or you just did some tack welding ? It should be all put together over the next week-end.
Originally Posted by MaximumPower01
Any plans to slap in a 3.5, or you stickin with the 3.0?
The project is already going according to my plan, Aaron might port and polish my lower IM and composite IM ( I need to send him some pics over the week-end ), I also want to have both heads port & polish, and probably put some better spring,valve and retainer.
I have an auto tranny so a rebuild of the tranny will have to happend even though my tranny is running strong with no slipping but with the boost thing will change for sure. The 5 speed tranny swap is very possible if I can find one for a decent price but it is not abolutely necessary a better gearing with a bullet proof rebuild of the auto might just do it.
Cheers
I didn't know that the 3.5 IM could be transplant to a VQ30DEK. The Nismo head & cam must be very expensive though but I'm going to investigate seriously about that.
Thanks for the heads up.
AA
AA
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
03VQMAX
Sep 5, 2015 03:47 PM
