problem with spark plugs
so i went out and bought ngk plat spark plugs and replaced em.
they were way past due, and the ignition coils were looking pretty nasty. i took out some of the copper crap inside and cleaned what i could. after install, i take it out for a spin and it feels a little sluggish. after a mile, i got a blinking service engine light. ?? any advice...? i know i need new ignition coils but untill then what coudl be a problem..
already did. now the engine light is off...however, i still feel it sluggish...and when i reverse, the engine feel slike its choking...and the car starts vibratign....
How tight did you tighten them? It's typically hand-tightened until contact, and then another 1/4-1/2-turn. Sometimes if they are not tightened enough, the spark tip doesn't reach down into the combustion chamber as far in as it should.
coils are connected to the proper harness? like the back coils in the back? front coils in the front? or the actual coils in the same spot they were in.
cause shoot, i did not put them back in the same spots...=/
i dont think it mattered.
lol all i did was redo everything and tighten everything real good. ??? doesnt make much sense because everything was on there pretty tight. but i dunno. car is kickin like it used to...feels great.
Originally Posted by TurtleHead
The cylinders dont all fire at the same time.
I think they fire 1, 3, 5 then 2,4,6 but could be wrong.
(No, I'm not suggesting crossing the plugs, just unplugging and switching coils).
It should have no difference. When you order replacement coils, they don't come assigned to a specific cylinder.
Originally Posted by 2002 Maxima SE
Right, but what does that do with putting coil one in place of coil 5?
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
chernandez1278
Sep 16, 2015 01:18 PM
