JWT pop charger + hoses = check engine light. HELP!
Old Jul 27, 2001 | 06:33 AM
naidd's Avatar
Ok, here it goes...
I took my car to the shop last night. Did a bunch of stuff to it, including a JWT pop charger and some red hoses.
(if you're curious, the rest was an FSTB, Carbon-fiber kit, home depot grill, some lights... stuff that will not cause the problem I'm describing)
Shortly after we started the car (10 minutes or so), my engine light came on. I would hate having to remove the pop charger and ALL the hoses and then bring it to the dealer. Do you have any suggestions on how to fix this?
I would like to clarify a couple of things:
1. We removed the airbox and replaced it with the pop charger.
2. The front piece (my stock intake) we left in place, together with the 2 sensors on it (are those the temp sensor and the O2 sensor?).
3. We did NOT disconnect the car battery while doing the work (I did not know anything about that at the time).
4. Right now, the car feels a little stronger, sounds MUCH nicer Overall, there is no evident problem as loss of power, or whatever.
5. Check engine light is still on today.
Help me shut the d@#n light off, please
Old Jul 27, 2001 | 06:35 AM
UMD_MaxSE's Avatar
Got Bent?
unplug the battery for a few hours and it should go away. If it comes back on, then there may be a problem with the sensors...
Old Jul 27, 2001 | 07:53 AM
naidd's Avatar
Should I mess with the sensors?
I just spoke with my mechanic and he mentioned that the O2 sensor may be the culprit. He also said that the car may eventually "adapt" to the new setup and stop giving that check-engine light.
Did I have to do anything with the sensors (unplug / replace / move them somewhere)? I have not touched them, just left them the way they were.
Old Jul 27, 2001 | 08:04 AM
UMD_MaxSE's Avatar
Got Bent?
O2 sensors? Those are in the exhaust. You didn't touch those, did you? The sensors I meant were the MAF sensor and temperature sensors that are in the intake path. Just unplug the battery and see if the light goes away. If it does, then things are fine...
Old Jul 27, 2001 | 08:43 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Disconnect the battery OVERNIGHT.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
