brake fluid
Old Jul 29, 2001 | 05:40 AM
jayc5627's Avatar
how many bottle of fluids will I need to replace front rotor? back rotor? both? and how much does it cost per bottle?? thanx
Old Jul 29, 2001 | 08:37 AM
mdeal's Avatar
You don't need fluid if you are replacing the rotors.
Old Jul 30, 2001 | 04:17 AM
wdave's Avatar
even if you replaced all the fluid in the system it would probably be less than a quart, good fluid like Castrol GT LMA is about $5 a quart or $2.75 per pint bottle (better way to buy it if you're not using a lot at one time).
wdave
Old Jul 30, 2001 | 08:27 AM
Eric L.'s Avatar
Unless you are removing a brake line or doing caliper work, you do not need to bleed the brake system. If you do need to, it's around $5 for large bottle of Valvoline Dot3/4 Synthetic brake fluid, enough to flush the entire system.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
