Any know how to remove, take clock unit?
Old Aug 10, 2001 | 01:46 PM
2kseman's Avatar
Was wondering if any has removed that clock piece on center of dash...and if so, how it was done...
I tried the search, and well, you know how that goes...
Appreciate any replies or comments..
thanks.
Old Aug 10, 2001 | 01:54 PM
mingo's Avatar
it's real simple... pull it straight up.. a panel puller might help, just pry it til it pops off, and unplug the clock.. make sure you get under the trim piece, dont' pry it from where you see the clock, u gotta go under the whole thing... if you dont' have a panel puller use a slotted screwdirver, wrap it in cloth so you wont scratch up your dash.
i'm not in any way liable for physical damages to you or your car, attempt it at your own risk.
Old Aug 10, 2001 | 02:20 PM
jsmith24's Avatar
Mingo is right...just pull up on one end of the clock module. It takes effort, and feels like you might break it, but it will be okay. There is one clip at each end, on the side closest to you, and one in the center on the side closest to the windshield.
Old Aug 10, 2001 | 02:39 PM
max'n out's Avatar
I moded it...just pull on up on it.
Old Aug 10, 2001 | 03:49 PM
BluLite's Avatar
yeah thats how you do it
Old Aug 10, 2001 | 04:22 PM
rocketshipon19"'s Avatar
What are you guys putting in place of the clock?
Old Aug 10, 2001 | 04:30 PM
max'n out's Avatar
I put a status display in its place.
Old Aug 10, 2001 | 07:19 PM
Pat DiPersia's Avatar
Status display? What's it displaying? More info and pix!
Old Aug 10, 2001 | 07:26 PM
mdeal's Avatar
I am not sure of the gentleman's handle on the ORG, but this guy incorporated his radar detector lights into the clock display. See http://www.fourthrock.com/maxima/images/radar.jpg
I also have a pic of the wiring behind it.
If "Dan" would prefer me not to show the pics, let me know. Otherwise, I thought it was an great demonstration of skill and ingenuitiy.
Old Aug 10, 2001 | 10:52 PM
2kseman's Avatar
I tried pulling one side up and I thought that thing would break, now, thanks to all your comments, I'll try pulling it straight up! BTW, I plan to incorporate the JET V-Force unit in there there somehow....the LEDs lighting up as the gas pedal is depressed is pretty cool..especially at night...thanks again to all for the info.
Old Aug 10, 2001 | 10:53 PM
max'n out's Avatar
It shows system voltage at the amps and battery also amp temp. so when they hit a temp the fans kick in. Basically the whole clock is gone along with the gray blocks on either side and the digital display is covered by tinted plexi.
Old Aug 12, 2001 | 12:09 PM
mingo's Avatar
wow that looks alot better than what i did. i mounted my valentine one concealed display where the clock went and hid it behind a tinted piece of plexi..
Old Aug 12, 2001 | 03:40 PM
mdeal's Avatar
2kseman, Do you plan on dynoing with your Jet v-force module?
RealityCheck
Oct 2, 2015 06:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
