Front suspention problems already?
Old Aug 12, 2001 | 05:10 PM
bert's Avatar
Well, I have 43000KM (27000 miles) and the front end has some knocks in it (comming through the steering) and some squeeking in there too. Fortunately I have not touched the suspention, not even a FSTB
Am I driving my car too hard or is the suspention weak? Am I the only one?
Old Aug 12, 2001 | 05:13 PM
AznWontonboy's Avatar
did you run over a curb or anything? you might have to re align your car... in my 4th gen there was massive shuddering when i got hit in the front wheel, my alighnment was really off.
Old Aug 12, 2001 | 09:46 PM
PhatGuy
Ya I'm having that problem a bit too. Never ran over anything. Just some vibration and slight shake at higher speeds. PSI was ok so it must be a wheel balance or something for me. I am going to have the dealership check it out anyways.
Old Aug 13, 2001 | 06:54 AM
bert's Avatar
It's not a ballance issue, things are real fine. I didn't hit anything that I know of and I am the only one who drives it.
It's not a high speed issue, it's a low speed over bumps issue. I would say that it's a tie-rod or something going out.
Old Aug 13, 2001 | 12:12 PM
augie's Avatar
I had a problem like that and it happened to be the front strut.
Old Aug 13, 2001 | 12:37 PM
bert's Avatar
Just one or both? Did they do both as a precaution? (am I being to ****ing optimistic? Is it at about the same milage? You drive your car hard?
What is the build date of your car? Mine is Dec 16 1999.
Old Aug 13, 2001 | 12:51 PM
Max_Gator's Avatar
Could also be in the brakes. I had a loose bolt that would make a knocking sound when braking.
Old Aug 13, 2001 | 01:43 PM
augie's Avatar
It was not the brakes. I had the S.M drive my car and sure enough it was the passenger right strut. I heard a weird knocking whenever I would drive, I also heard on smooth road. I haven't looked to see when my car was built, I will later on. I do drive my car pretty hard, but not to the extreme. As a matter of fact, I'm experiencing the same problem again. Maybe the struts suck on these, just like the rotors. :[
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 12, 2016 04:11 PM
JoshG
21
Sep 4, 2015 09:04 PM
homeyclaus
Sep 3, 2015 06:15 PM
kirkhilles
Aug 8, 2015 10:53 AM
