Sqeeeky window:( sqeek up. sqeek down
Old Aug 14, 2001 | 09:19 AM
GordanLu's Avatar
Damn driverside window is killin my last bit nerve! I so far tried cleaning it with water, Invisible Glass, sqweegy. I cleaned it all around, even the rubber surrounding it. My max is a 1/2 year young and I don't see why this is happening. It's been sqeeking for about a month now. Has anyone experienced this? If anyone can help, please feel free to suggest anything and everything. I might take it to the dealer but...
Old Aug 14, 2001 | 11:02 AM
Max_Gator's Avatar
If you figure it out please tell me; I'm going crazy too. I suspect it has to do with the tinting.
Old Aug 14, 2001 | 11:05 AM
raynist's Avatar
My rear passenger side does this also. I am going to clean it with Rain X and let you know how it works. I suspect that the window has a lot of sap on it from parking under a tree.
--Ray
Old Aug 14, 2001 | 11:08 AM
raynist's Avatar
Hey Max Gator,
I looked at your dyno runs, are they all from the same day? If not, was the weather much different for run 11??
Ray Nist
Old Aug 14, 2001 | 11:55 AM
MAXinNH's Avatar
My 2000 front windows were squeaking like crazy too...
The fix is to pick up a can of automotive silicon spray.
Roll the window all the way down, and spray the silicon into the vertical risers that the glass rides in. Do not spray onto the glass.
Works like a charm...
P
Old Aug 14, 2001 | 12:02 PM
JMax2K's Avatar
P
Yeah, mine did the same thing. You have to do the silicone thing about once every 6months or so...
Old Aug 14, 2001 | 12:07 PM
Max_Gator's Avatar
Originally posted by raynist
Hey Max Gator,
Ray Nist
All runs were done on different days - several months apart. I believe it was somewhat hotter and more humid when run 11 was done and that may have affected the run. However, I believe it is more likely that there was some type of dyno error or other problem with my vehicle because I only lost hp above 5200 rpms.
I will be redynoing soon - hopefully that will solve the problem.
Old Aug 14, 2001 | 12:12 PM
Maximam's Avatar
Yep Silicon, sprayed it on a rag then ran it along the rubber trim. No more squeek!
Mark
Old Aug 14, 2001 | 12:14 PM
psing23's Avatar
ye i have the same problem with my windows...
Old Aug 14, 2001 | 12:46 PM
PhatGuy
Mine has done it a few times too. The dealer will fix it for you. It can be misaligned a bit so the silicon spray could be curing the squeeking but not the problem. When that spray wears down it will start again.
Old Aug 14, 2001 | 01:14 PM
y2KAOSMax's Avatar
I had the same problem with my driverside window and left passenger side window. I took my car to the dealer and they put some silicon stuff on it, but it kept on doing it. I took it back again and they put more on, this time it worked. Until it rained, now it only squeeks when it rains, so far. It's really annoying..
Old Aug 14, 2001 | 03:26 PM
Ludacris's Avatar
Front passenger side window squeaks, and when u close the door with the window slightly open the window will drop lower into the door. And theres also some verticle glue (?) stripe on the glass. Anyone have this problem?
Old Aug 14, 2001 | 03:46 PM
MaxedOut2g's Avatar
different problem...
my windows dont squeak, but when i open em, they make a LOUD popping sound...i think its cuz of the tint but im not sure
Old Aug 14, 2001 | 08:17 PM
Loe max's Avatar
My drivers side windows squeak going up or down and they make a poping sound going over bumps.
The window seals are poorly designed. Even after a couple of hours after washing the car, rolling down my window and then rolling them up again will get the window soaked in water and it dries as ugly water spots making the window look dirty.
Old Aug 15, 2001 | 12:17 AM
psing23's Avatar
yup
Old Aug 15, 2001 | 08:35 AM
GordanLu's Avatar
I will try silicon spray. Thanks for the help. Now I can rest with ease.
Old Aug 15, 2001 | 08:50 AM
eortiz15's Avatar
Re: different problem...
No. I don't think is the tint. I don't have tint on my
driver/passenger windows and those are the ones making
the noise you mentioned.
Old Aug 15, 2001 | 09:14 AM
GordanLu's Avatar
Old Sep 27, 2001 | 10:10 AM
DKNYchinito
Sup... I have the same issue here, but when I pointed it out to my dealership, they just said its a problem that can't be fixed. If you had this window squeek problem fixed by your dealer, could you lemme know what they did? Thanks man... BTW, nice pic, kinda scary though .
-Dave
Old Sep 27, 2001 | 10:31 AM
NuJerseyDrive's Avatar
Man my dirvers side window has been squeelin like a pig for the past 3 months and it's drivin me My friends make fun of it all the time. Thanks for the advice about the silicone spray, Ima try it this weekend.
How the hell are you supposed to holla at a honey without suffering from this embarrasment? Sign language?
Old Sep 28, 2001 | 06:04 AM
GordanLu's Avatar
Hello everyone! Long time no write. Is this a wake up call to get this problem fixed? I haven't been on .org for awhile and when I sign on ...BOOM!.. A reminder to get it fixed and now it also makes that popin' noise.
Yo DKNYchinito, your dealer should fix that for your; if not take it to another dealer if you can. peace
Old Sep 28, 2001 | 10:52 AM
DKNYchinito
Cool... i'll try bit**ing harder next time . I know that i gotta get this fixed before my bumper to bumper warranty runs out.
Peace
Old Sep 28, 2001 | 04:30 PM
drudawg888's Avatar
Peace
call me crazy, but i kinda like the squeaky noise. :P
Old Sep 28, 2001 | 04:35 PM
you are crazy
Old Sep 28, 2001 | 05:15 PM
shadou's Avatar
You know the same thing happens to me as well. But it didn't start until after my tint was installed. So, I think it has something to do with the tint but yes, it does annoy me as well.
Shadou
Old Sep 28, 2001 | 06:14 PM
drudawg888's Avatar
hehehe
um actually when my girlfriend's around, the doors aren't the only things in my car that squeak.. hahah!
Old Sep 28, 2001 | 06:20 PM
Y2KMaxGXE-R's Avatar
Bro I had the same problem after I removed my window tint. I took it to the dealer and the simple silicon grease took care of it.
Old Sep 28, 2001 | 11:14 PM
serin's Avatar
silicon grease doesn't make the window all greasy?
Old Sep 29, 2001 | 03:15 AM
GMAN01SE's Avatar
Thanks!
I'm glad I'm not the only one. I'll definitely try the silicone.
Old Sep 29, 2001 | 09:52 AM
Cisco's Avatar
Re: Thanks!
Does the silicon spray have any effect on the tint? I've heard to stay away from putting any chemicals on the tint.
GC
Old Sep 29, 2001 | 11:00 AM
rerunn's Avatar
My windows were screeching before I got tints on. The sound got way worse after I got the tints. Finally took it to the dealer a few days ago and had them look at it. They "lubed the tracks" and its been dead silent since.
Old Sep 29, 2001 | 04:56 PM
tmds's Avatar
Same thing on my I30t
Hey guys, I have the exact same pop/squeeking problem on my 2001 I30t. When I dropped the car off for its 3mo. checkup, I had them look at it. They lubricated it with whatever it was they used--probably the silicon stuff you guys have mentioned. The problem went away for about a month but has come back. I'm going to be dropping it off soon for a 6mo. checkup and I will have to repeat the issue.
It's quite irksome.
Oh, and I don't have tinting on the windows just yet. Working on that.
AaronL
Aug 8, 2020 10:31 AM
TKHanson
Nov 24, 2018 01:39 AM
Andy29
Sep 29, 2015 05:32 AM
Marc2theMax
Sep 28, 2015 08:13 AM
