Warm Engine Startup Problem...
Old Aug 19, 2001 | 11:39 PM
MaxedOut2g's Avatar
i was wondering if anybody else is having this problem....i think it was posted a while back but im not sure...
when the engine is cold, say in the morning when im leaving for school, startup is perfect, turn the key to ignition fully and hold for about a second..
however, when the engine is hot/warm, i turn the key to ignition and i only have to hold it for 1/2 second and the engine starts, but not how it should...it sort of 'klunks' i guess u could say...i dont know how to xplain it, but its juss not rite....the problem is even worse if the car is parked in the sun.......ideas/suggestions b4 i take to dealer...and i been having this problem for a while, but its finally bugging me enough to wanna take it down there
A_T_W
Old Aug 19, 2001 | 11:55 PM
melanthius's Avatar
Metal Expands
All sorts of things happen in warm temperatures. all the metal in your car expands when warm. This means the pistons have a tighter fit in the cylinders when the car is hot, and there is more force of friction to overcome when starting. When the car is cold, the metal is contracted, and it is easier to overcome the friction. Don't worry about it, I don't think you have to get it checked out. Maybe it's time for an oil change?
If someone thinks I'm wrong, please let me know. I'm not an expert but I think I'm right here.
Old Aug 20, 2001 | 12:09 AM
MaxedOut2g's Avatar
Re: Metal Expands
thing bout contracted-ness could be rite...but bout the oil, thing is, it happens all the time, even after ive juss got my oil changed....im about 200 miles away from an oil change rite now, so i should be gettn that either endof this week, or early next...thanks for the suggestions dawg, appreciate it
A_T_W
Old Aug 20, 2001 | 06:08 AM
UMD_MaxSE's Avatar
Got Bent?
mine does it too.... especially if it is hot and the car was shut off within 30 minutes.
Old Aug 20, 2001 | 06:58 AM
mike-777's Avatar
You might try synthetics if you aren't using them now.
I use Mobil 1, and never a start up problem.
I suspect a trip to the dealer may be in order. A new car shouldn't do this. Vapor locks, fuel starvation, ignition,
could be a lot of things.
Old Aug 20, 2001 | 07:16 AM
UMD_MaxSE's Avatar
Got Bent?
well, I use Mobil1 5W-30.... it only happens a few times... not very often
220k+ A32
18
Sep 22, 2015 11:39 AM
carid
Sep 17, 2015 05:00 AM
97_GXE
Sep 15, 2015 06:47 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
bennuss
Sep 11, 2015 05:55 AM
