Check Engine lights
Old Sep 9, 2001 | 05:42 PM
Foglght's Avatar
A while ago I made my own intake system for my max. Took out everything that didn't need to be there. It worked great for a while until i decided it needed to be better. I went over to the local rice shop and made one up with the owner. Now I am having problems. I keep getting a check engine light and a MAF code from the PCM. When the light goes on the car goes into fail safe mode, and I can't rev the car over 2,400 rpm until I shut off the engine and restart. I am curious if anybody else has had this problem. I am trying to decide if I might have hooked a vaccuum line up wrong or something else. My dealer said that it's the K&N air filter. I can see where the filter would have been too close to the MAF and caused some of the oil to get up into the filaments of the MAF. I know though that stillen sells the Oiled Filter kits and I don't think stillen has these problems.
Anybody else out there with this prob?
cya,
Ryan
Old Sep 9, 2001 | 07:53 PM
g dogg's Avatar
Took out everything that did'nt need to be there. maybe the problem. there are smog sensors on the intake and MAF, that, if are not reinstalled properly will cause an ECU issue. Not sure what type of intake you installed, but if your sure it was installed correctly you may want reset the ECU by disconnecting the battery overnight, the hook back up in the morning and see what happens. You may want to check the FAQ threads for further insight.
Old Sep 9, 2001 | 11:32 PM
yongjun's Avatar
Those sensors can be kinda sensative at times so watch out
Old Sep 10, 2001 | 05:04 AM
Keikan
Re: Check engine light
Check airflow direction through and position of MAF.
Check for obstruction in air flow from MAF to TB.
Leaks can also trigger check engine lights.
Just some suggestions.
Old Sep 10, 2001 | 02:08 PM
Foglght's Avatar
Re: Re: Check engine light
I keep going to work and erasing the code. A couple of people at work were saying that it takes some time for the computer to adjust to the new induction system. My light hasn't gone on for about 3 weeks now. I did replace the breather line into the valve cover with a straight k&n breather. I was wondering if that line actually needs vaccuum in order to get proper balancing and readings.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
