Stillen RSB problem
I just found while rotating my tires that the end of one of the threaded bolts on my RSB clamps was cutting its way through my rear brake lines. It was happening on both sides of the car. The end of the threads is fairly sharp and it must rub each time the suspension passes by. Its not obvious when the car is jacked up with the wheel off because in that position the brake line and clamp are nowhere near each other. I think it can be solved by reversing the bolt and putting the much shorter head on the inside. I thought I followed the instructions pretty carefully and find this to be a pretty shocking discovery. The cuts are deep enough that I'll be replacing these brake lines soon. If you've installed one of these and don't recall which direction you installed the bolts you might want to take a good look.
Do you have the hex bolts on the outside? You may want to call Stillen about this. This is serious. I'll inspect my car very soon. I've noticed recently I get an occasional thunk during high speed cornering. It almost sounds like my RSB comes in contact with the beam.
get a peice of metal wiring.. a thick peice of wirign.. well not a wire. but kinda like a paper clip but much stiffer. bend on end into a "U" and hang the brake line on it, bend the other end into "O" so you can bolt that down now you have a support for the brake lines...
the above are just suggestion for how to fix the problem. if u mess up then it is your fault. and not mine
This moring I reversed the bolts and there is indeed enough clearance for the hose to move by. In hindsight I find that the instructions did mention installing the rearmost bolt with the head inwards. Obviously I glossed over it, my fault. However if anyone else has installed this and doesn't recall if they followed the step I would strongly recommend checking. My brake lines were down to the fabric.
Actually when I first installed the RSB in my 2K I had the bar slightly behind the axle. So whenever I hit a serious bump, the multilink beam part would come down and hit the RSB. Have someone push down on the rear of the car while you look to see if there is contact.
Re: So you saying I need to put RSB right under the beam axle?
Originally posted by Dany
Will this eliminate the contact with RSB?
Thanks.
Thanks.
Stagnet04
Sep 14, 2015 11:28 PM
