cpmplete y / b pipe install
Old Sep 25, 2001 | 06:15 AM
proudowner's Avatar
Anyone with a complete set, Where there any improvements! I own a Grey Lustre 01AE. Thinking of switching, want to know if its worth the change. Thanks
Old Sep 25, 2001 | 06:19 AM
UMD_MaxSE's Avatar
Got Bent?
get the y-pipe for sure... that will get you the most gains... everything else is secondary in terms of exhaust..
Old Sep 25, 2001 | 11:50 AM
MOBOY's Avatar
Re: cpmplete y / b pipe install
I heard that these mods don't work on the Grey Lustre 01AE models....I am not sure...but that is all I heard!
Old Sep 25, 2001 | 12:04 PM
mbcp_tdogg's Avatar
Re: Re: cpmplete y / b pipe install
Are you serious?
Old Sep 25, 2001 | 01:00 PM
ToYLeT902's Avatar
JET Speed Lab
yup. they only work on super black.
Old Sep 25, 2001 | 01:04 PM
NickStam's Avatar
I heard cars w. metallic paints were built with 3.5" piping instead. Beware!
Old Sep 25, 2001 | 03:30 PM
BigDogJonx's Avatar
Where can I get a resonable priced Ypipe? I was thinking of getting that or the Straight pipe. But someone said that a Ypipe and a Straight pipe is not good since it messes up the ECU or something. If I dont end up getting a Ypipe, you know anywhere in the DC area where I can get a good straight pipe? for less than $80?
Old Sep 25, 2001 | 05:16 PM
UMD_MaxSE's Avatar
Got Bent?
I think you have a few things mixed up. The y-pipe is the pipe that goes from the exhaust manifolds back to the cat. Stillen and Cattman are the two companies that currently make y-pipes for the 5th gen. I think Warpspeed is also going to start making y-pipes for the 5th gen. The cheapest y-pipe would be Warpspeeds most likely, while the Cattman pipe is the most expensive at $400. Most of the gains you will see are from the y-pipe. A straight pipe is used to replace your catalytic converter. You have cali spec emissions, so you can actually get away with a straight pipe and y-pipe, given that you don't touch the front pre-cat that is built into the front exhaust manifold. You have no O2 sensors behind the main cat. However, I would say get an aftermarket high-flow cat rather than a straight pipe. Anyhow, before anything, you should get a y-pipe first when modding the exhaust. You will not see any gains from a straight pipe or high-flow cat alone.
Old Sep 25, 2001 | 05:20 PM
ToYLeT902's Avatar
JET Speed Lab
i have the b-pipe
Old Sep 25, 2001 | 05:27 PM
UMD_MaxSE's Avatar
Got Bent?
Originally posted by ToYLeT902
i have the b-pipe
yes
+1
Old Sep 25, 2001 | 05:31 PM
ToYLeT902's Avatar
JET Speed Lab
yes
+1
Nooo.. im better than that... that was important information that can be used.
Old Sep 25, 2001 | 05:38 PM
UMD_MaxSE's Avatar
Got Bent?
Old Sep 25, 2001 | 05:41 PM
ToYLeT902's Avatar
JET Speed Lab
Old Sep 25, 2001 | 05:44 PM
UMD_MaxSE's Avatar
Got Bent?
Old Sep 25, 2001 | 05:48 PM
ToYLeT902's Avatar
JET Speed Lab
Old Sep 25, 2001 | 05:55 PM
UMD_MaxSE's Avatar
Got Bent?
smoking is bad for you
Old Sep 25, 2001 | 05:57 PM
ToYLeT902's Avatar
JET Speed Lab
Old Sep 25, 2001 | 06:03 PM
UMD_MaxSE's Avatar
Got Bent?
that is bad for you also.....
Old Sep 25, 2001 | 06:04 PM
ToYLeT902's Avatar
JET Speed Lab
Old Sep 25, 2001 | 06:07 PM
AznWontonboy's Avatar
that is very very Goo, eh err BAD MAN WHAT ARE YOU THINKING YOUNG MAN.
Old Sep 25, 2001 | 08:14 PM
BigDogJonx's Avatar
Damn that means I am getting conflicting info from other people. They say that a straight pipe will give you a nice boost in the top end and will increase the gas mileage.
Secondly I dont understand this CALI-SPEC stuff...... what you mean by that? You saying that my car has a california specifications for emissions? Is that good or bad for performance?
Now a Ypipe and a high flow cat will bring some major gains correct? How much estimated for a highflow cat? is this the one made by Random?
Man I still need to meet up with you and check you joint out and what not, i keep forgetting.
Old Sep 25, 2001 | 08:26 PM
cobymoby's Avatar
Huh??? What??? Huh??? What the hell is a Maxima?? Where are all of the darn Civics on this board! What's this talk of a Z pipe, T pipe, Q pipe and all??
ha ha laters....
Old Sep 25, 2001 | 08:47 PM
mbcp_tdogg's Avatar
Toylet's got issues...
Old Sep 26, 2001 | 04:55 AM
UMD_MaxSE's Avatar
Got Bent?
well, a straight pipe may give you some top-end power, but really though, running without a cat is bad. By cali-spec, yes, it means that you have California Spec/NLEV emission. Basically it means that you have 4 O2 sensors in the exhaust path, a pre-cat built into the front exhaust manifold, plus some extra hardware in the intake manifold. This isn't good for performance, but the difference should not be huge when compared to fed-spec maximas. A y-pipe and hi-flow cat will get you some nice gains. Random Tech makes these hi-flow cats.
If you want to meet up, just let me know. Drop me an e-mail: nauman6@yahoo.com ... later....
Old Sep 26, 2001 | 07:08 AM
bapow1's Avatar
Will this pass inspection in NJ? Ours is much like the CA inspection for emissions. According to cattman the new Y pipe will take out the "pre-cats" and is not street legal (for offroad use only). You mentioned that the pre-cats are in the manifold... I'm a little confused (nothing new).
Anyone in Jersey pass inspection with this mod? How hard would it be to switch back to the old pipes every other year (how hard is the mod)? Also...how much power increase (HP/Torque) can you expect out of this mod alone (I have a 2k and cattman only give the dyno's for a 96 max).
Thanks,
Paul
Old Sep 26, 2001 | 09:09 AM
ToYLeT902's Avatar
JET Speed Lab
Old Sep 26, 2001 | 09:21 AM
UMD_MaxSE's Avatar
Got Bent?
Thanks,
Paul
if you have your main cat still there, or an RT cat, you should pass emissions just fine as long as the car is warmed up. Precats only do their job when the car is cold. All bets are off with a straight pipe though.... thats why you should probably just go with a hi-flow cat or the stock cat even....
Old Sep 26, 2001 | 11:33 AM
bapow1's Avatar
OK Thanks,
Paul
Old Sep 26, 2001 | 11:51 AM
UMD_MaxSE's Avatar
Got Bent?
OK Thanks,
Paul
no problem
Old Sep 26, 2001 | 03:22 PM
Foglght's Avatar
Re: Re: Re: cpmplete y / b pipe install
I was really wondering about the B-pipe more than anything. The y-pipe really helped me out. I put my car up on the hoist at work and finally noticed the crimp in the exhaust just after the resonator. What the hell is that? Come on....that can't be good for airflow. Put a circular rubber mount there and make it better nissan. Does anybody know if the B-pipe does much for HP?
Old Sep 26, 2001 | 06:10 PM
mbcp_tdogg's Avatar
Old Sep 26, 2001 | 10:12 PM
Keh mon's Avatar
You guys are just a bunch of post ******! You don't know anything about these darned nissan's. Maxima's, right?
Keh mon's Avatar
What I said was that you guys are a bunch of postwhores
Old Sep 26, 2001 | 10:13 PM
Keh mon's Avatar
Is postwhores one word or two? Postwhores? or Post ******.
hmmm.... that's a tough one
Old Sep 26, 2001 | 10:15 PM
Keh mon's Avatar
Ok could someone please tell me how one "postwhores"
I think I'm confused on how to do it.
hehe ok I'll stop.
Old Sep 26, 2001 | 11:05 PM
mbcp_tdogg's Avatar
Three replies!
Old Sep 27, 2001 | 01:12 AM
ToYLeT902's Avatar
JET Speed Lab
keh mon
Old Sep 27, 2001 | 08:39 AM
Keh mon's Avatar
keh mon
what?
Old Sep 27, 2001 | 01:51 PM
UMD_MaxSE's Avatar
Got Bent?
Originally posted by Keh mon
what?
a new guy
Old Sep 27, 2001 | 02:00 PM
ToYLeT902's Avatar
JET Speed Lab
a new guy
BkGreen97
Apr 2, 2016 05:47 AM
Violator
Sep 9, 2015 10:14 AM
Samedi
Sep 3, 2015 01:07 PM
