'02 6-speed knob fit perfectly..>
Old Sep 27, 2001 | 05:58 AM
Jeff K's Avatar
'02 6-speed **** fit perfectly..>
My anniversary edition **** was not doing so good. The metal center was lifting just enough to cut my hand when shifting so I decided to get the 2002 6-speed shift ****. Theads on perfectly and the only thing I had to do was raise the shift boot about 1 inch to fill in the gap because the new **** is smaller. To raise the center of the shift boot I pulled up the center console and used electrical tape around the shift rod so the boot will not fall. Looks pretty sweet and I'll have some pictures tomorrow if interested.
I ended up getting the **** from Tustin Nissan because they were the only ones that would order it for me. I think it was $75 well spent. I know what you thinking about the 6-speed markings and someone making the mistake of shifting into 6th but no one drives my car so problem solved. :^)
Old Sep 27, 2001 | 06:55 AM
AdamK's Avatar
Re: '02 6-speed **** fit perfectly..>
i was thinking af doing that a few weeks ago so ill buy it when more funds come my way, btw u interested in hooking this poor *** kid up with your old AE shifter I could super glue it and be set, im serious, email me if interested we can talk about mulla webmaster@akpages.com later bro, get some pics up im sure it looks pretty hot...
Old Sep 27, 2001 | 07:23 AM
Ants97SE's Avatar
Yeah, I'd like to see what it looks like, I have the AE **** myself and the finish is all peeling off and stuff. I want a new know, especially if they are smaller.
Old Sep 27, 2001 | 08:27 AM
My 4DSC
COOOOL!!
Does that mean you car has a 6th gear now?!
Old Sep 27, 2001 | 08:35 AM
Jeff K's Avatar
Re: COOOOL!!
Naaa, 6th gear is over rated. If 5th gear is good to 145 plus mph then what's 6th good for? Warp speed? If figure your car is drag limited at the top of 5th gear so why even install a 6th gear? Who truly knows but it's a sales gimmick that seems to be working.
Old Sep 27, 2001 | 09:07 AM
Greg's2kGLE's Avatar
Re: Re: COOOOL!!
Very true. 6th gear is basically just a crusing gear that puts less stress on the engine.
Old Sep 27, 2001 | 09:11 AM
dave's Avatar
Re: Re: COOOOL!!
i would think closer ratios for the lower gears means faster acceleration, and cruising in 6th may offer better gas mileage.
Old Sep 27, 2001 | 09:20 AM
martinf's Avatar
My 5 speed **** is all leather. Isn't the 6 speed part metal? How does that feel better than leather in hot/cold weather?
Old Sep 27, 2001 | 10:03 AM
BriGuyMax's Avatar
Re: Re: Re: COOOOL!!
"most" cars that utilize 6-speed manual transmissions have 4 close ratio gears and two overdrive gears, basically most 6th gears are just for fuel economy and sound deadening. The 6-speed max's first four gears are probably about the same ratios as the old 5-speed, but the bigger engine will eat more gas with only the 5th gear...hence the 6th
Old Sep 27, 2001 | 10:05 AM
RussMaxManiac
Rice boy!! You don't have a 6spd! hahha
Old Sep 27, 2001 | 10:51 AM
My 4DSC
Re: COOOOL!!
that was sarcasm if you didnt catch on.
Old Sep 27, 2001 | 10:56 AM
Jeff92se's Avatar
I'm needing a caw
Re: Re: Re: Re: COOOOL!!
Actually I read that Nissan orignally just wanted to change 4-6th. But they eventually decided to make the maxima 6-sp a true close ratio tranny. So I think the first 5 gears are underdriven and only 6th is overdriven. Since the new maxima is 255hp, it probably has the power to utilize all 5 underdriven gears now.
Old Sep 27, 2001 | 04:00 PM
BriGuyMax's Avatar
Re: Re: Re: Re: Re: COOOOL!!
if that's true....the 6-speed will be a VERY quick car.
Old Sep 27, 2001 | 04:13 PM
Stranger808's Avatar
Re: Re: Re: Re: Re: Re: COOOOL!!
Well the Nissan site dose say Close Ratio six speed transmision
So I would say we ae going to have some fun with this little monster
Old Sep 27, 2001 | 04:30 PM
AdamK's Avatar
Well ya'll betsta not be talkin' junk about the 6-speed....it helps poor and cheap people like me who are so broke that when i drive i start from first and instantly shift to fifth
Old Sep 27, 2001 | 05:07 PM
Ants97SE's Avatar
Rice boy!! You don't have an AE! hahha
Take off that AE badge then!
Old Sep 27, 2001 | 06:05 PM
RussMaxManiac
Mine's a 2001 (20th year.) so its a 20th Anniversary model. Just doesn't have all the goodies Nissan put on it at the factory, I am doing separate!
Old Sep 27, 2001 | 07:50 PM
Ants97SE's Avatar
Bah, look at your VIN Number! RICE ALERT!! Plus you don't have 227 HP.
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
atriuum
Sep 28, 2015 01:19 PM
Pied
Sep 26, 2015 03:29 PM
