Neepa Monstas
Old Sep 28, 2001 | 11:43 PM
Maximus baby's Avatar
Neepa Monstas
will an 18X9 rim fit on the 2000 maxima with tires and what size would they have to be
Old Sep 28, 2001 | 11:51 PM
BigDogJonx's Avatar
Re: Neepa Monstas
They will fit, but i believe it might rub, most poeple got 18x8.... 18x9 is kinda too wide and it will most likely rub the inside wheel well on a hard turn. It "maybe" able to be corrected with offset, but still aint recommended, cause then it will stick out more than normal and it will run the outer upper end of the wheel well on speedbumps and potholes.
See if you can get a 18x8, neeper makes them.... for all types of wheels, cause you might be looking at a truck wheel or a vette wide wheel.
Old Sep 29, 2001 | 07:36 AM
rocketshipon19"'s Avatar
Re: Neepa Monstas
They will fit if you have a +38mm offset and a 245/40 tire. That is the only tire that will mount properly on a 9" wheel.
Old Sep 29, 2001 | 09:38 AM
so how much you lettin your momos go for
Old Oct 1, 2001 | 03:34 PM
2500.00 for 5 wheels and four tires.
Old Oct 1, 2001 | 03:58 PM
[QUOTE]Originally posted by rocketshipon19"
[B]2500.00 for 5 wheels and four tires.
how much tread and how many miles r on the tires
xtantmaxima
19
Jun 7, 2001 09:27 PM
