Spacer question... maybe bushings.
Old Oct 3, 2001 | 12:28 PM
ReprEsenTin NY's Avatar
Guys, I lowered my car, with OBX springs and it makes a lot of freaking noise. I posted a question up before and I didn't get the answers I needed to help me. I was thinking of getting aftermarket bushings, do you think it'll help? Only reason I'm asking is because I won't be able to take much more of the squeeking. Is it a spacer problem or bushing problem? If it's either or, can you tell me EXACTLY which bushing or spacer I may need to purchase? Thanks again.
Old Oct 3, 2001 | 12:39 PM
irvine78's Avatar
Re: Spacer question... maybe bushings.
bushing's going to help you handle little bit better but they will not make your noises go away..
the exact way of lowering a car is when you lower your car, you loosen up all the bolts and joints underneath the car and retighten them afterwards.. this is because once you lower your car, your suspension geometry changes(the car is sitting lower but the bushings and joints are sitting at wrong angle..causing more wear and tear)...but people generally don't do this cuz it's expensive..another $150-$200 depending on shops to do this.
anywayz...when you do stuff to your car, noise will become part of your daily drives...yeah, it sucks i know...
Old Oct 3, 2001 | 01:00 PM
bangster2k's Avatar
Solution
So what is the solution if there is any? I'd pay an extra $200 to stop that noise...but then again I'm a squeak freak that would **** me off.
Old Oct 8, 2001 | 06:28 AM
Lime's Avatar
I am having this problem in my 4th gen...trying to find a solution!
incubusjohnny
Nov 3, 2015 05:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Lowered_a33
Sep 10, 2015 09:41 PM
Maxboy23
Sep 4, 2015 06:04 PM
Maxboy23
Aug 11, 2015 11:59 AM
