5th SE Gauges
Old Oct 4, 2001 | 10:14 AM
Kal's Avatar
Kal
5th SE Gauges
Hey i have a 2001 I30t, and i like the Se guages. Is it possible 2 switch them over?
Old Oct 5, 2001 | 03:34 PM
irvine78's Avatar
Re: 5th SE Gauges
whhhyyyyy????
yours is much nicer...except they're black....
Old Oct 5, 2001 | 04:59 PM
Kal's Avatar
Kal
Re: Re: 5th SE Gauges
Originally posted by irvine78
whhhyyyyy????
mine are kinda boring. i jus went outside and took a pic so u can see. its always lit up and sometimes hard 2 see in the sun. but i like the different color effect in the SE gauges. I used 2 own a 98 Se and i loved those gauges. any word on indeglow for the 5th gen max??
thanks
Old Oct 5, 2001 | 05:52 PM
JKiMaxAC's Avatar
i like that but i think i know wut u mean, about not seeing them during the day tym.. that can b a pain in the a$$.. but i'm not sure if it will work.. i mean they look just alike, so u can give it try.. but i wanna know if we can put them needels on our 5th gens?? do u think that will work???
Old Oct 5, 2001 | 08:22 PM
mdeal's Avatar
When I installed my gauge rings, I removed the entire gauge cluster. The gauge faces are a paper material. So, granted the Maxima and Infiniti gauges are the same size, you could theoretically take the gauge material stuff, the face, and apply it to your Infiniti. I am not sure how the lighting will work on the Infiniti. But, as long as the size is the same, and you can purchase just the face, it should work. I do not know how the gauge face is attached to the unit. I just know I felt the material and it felt "papery" and was somewhat loose, meaning it was an "insert".
Old Oct 5, 2001 | 08:29 PM
Kal's Avatar
Kal
Thanks, maybe i will be the first to do this kind of change. I'll mess around and explore mine first jus to make sure i can do it and so on. anyone know how much it might run me?? thanks.
Old Oct 5, 2001 | 11:40 PM
Ludacris's Avatar
I thought Infinitis had electroflourecent (sp?) gauges. I don't really understand the way they work but I don't get how you could just switch the face plate...
Old Oct 6, 2001 | 12:24 AM
Max2000's Avatar
I thought
I30 have those special dash...(where you can't see the gauge unless you start the car) so I don't think it will work... dunno...
Old Oct 6, 2001 | 12:31 AM
Ludacris's Avatar
Re: I thought
Exactly. I don't think it's anything like swapping plastic faceplates..
Old Oct 6, 2001 | 12:35 AM
BigDogJonx's Avatar
Here is the GOOD news and the BAD NEWS.
GOOD NEWS..............
The gauges are exactly the same and would fit perfectly.
BAD NEWS..............
In order to get that Gauge sheet off, you need to pull off the NEEDLE on all four gauges, and from past experience, YOU DONT want to do that, cause (A), it is a pain in the A$$ to get off, (B), they will never go back on in the EXACT location you took them off, and because of that, you joint and reading will ALWAYS be off.
Old Oct 6, 2001 | 06:31 AM
UMD_MaxSE's Avatar
Got Bent?
if you ask me, I think the I30 gauges are nice
Old Oct 6, 2001 | 08:30 AM
irvine78's Avatar
yup..theirs is laser...
unless you do a core swap...changing out the face only won't work..
James92SE
142
Jan 2, 2024 09:23 AM
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
