Stillen Intake= Slower Car?
Old Oct 4, 2001 | 10:59 AM
Cisco's Avatar
For some reason, my car seems slower after I installed the intake. Does anyone have any ideas what's going on?
GC
Old Oct 4, 2001 | 11:01 AM
UMD_MaxSE's Avatar
Got Bent?
people have noticed that off-the line performance decreasing wth the cone type intakes. High end should be better, but low-end may suffer a bit.
Old Oct 4, 2001 | 11:06 AM
Cisco's Avatar
When you say "high end" at what speeds are we talking?
GC
Old Oct 4, 2001 | 11:08 AM
Sonic's Avatar
You lie, intake air velocity has nothing to do with this. OH, and high end = >5000 RPM.
Old Oct 4, 2001 | 11:20 AM
Keh mon's Avatar
Originally posted by yo_its_ok
Off the line ... any cone filter will lose low end torque, however when you gun it around your high rpms(4800+) your car will pull alot harder due to less restriction. My CAI now has been improved with a gradual cone shape of the pipe, no pics, cause I want this to be fun secret. Its nothing like any Maxima CAI Kit on the market. Its absolutely ingenious.
-Peace
Hey thanks for sharing JERK
How much of a negitive effect does the non-CAI intake have if it's mated with a Y-pipe. Or does that emphaize it more because it's "less restrictive too."
Old Oct 4, 2001 | 11:21 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
That's what I noticed....
That's what happens when you MESS with a "tuned" factory intake tract. Nissan optimized it for maximum horsepower/torque across the whole powerband. The cone intake supposedly adds peak horsepower on the TOP end, but you usually trade-off some LOW end torque.
For the torque you need a plenum of air like the stock air box provides, but once your intake runners switch over at 5000rpms(??) your airflow is restricted by the air box. Therefore, you need to decide what is more important. Looks, top-end, and most of all sound of the SI or the extra torque of the stock air box.
Old Oct 4, 2001 | 11:37 AM
PhatGuy
Re: Stillen Intake= Slower Car?
Is your car 5spd or auto?
GC
Old Oct 4, 2001 | 11:46 AM
woosh's Avatar
yo_its_ok
Will you eventually share your CAI with the group?
Old Oct 4, 2001 | 11:57 AM
IceY2K1's Avatar
IceY2K1, tuned to a point, however with enough knowledge, and some experimenting. I've created an intake system is essentially a 26" air horn w/ filter, so air velocity is maintained, and ultimately provides excellent low end and awesome high end.
-Peace
So TRUE.
Nissan also has another constraint and that's COST. Nissans' "optimal" tuned intake is not necessarily the BEST because of performance, but a combination of several factors such as performance, noise, manufacturing cost, etc... Which means there is ALWAYS room for improvement and one day I hope to have a business that takes advantage of this market.
Old Oct 4, 2001 | 12:55 PM
emax02's Avatar
Re: Re: yo_its_ok
Next Year....
Need to evaluate over the next few months...maybe a new design.
A CAI that requires no cutting, and will never suck up water...
-Peace
I will be waiting for this .
Old Oct 4, 2001 | 01:14 PM
IceY2K1's Avatar
Re: Re: Re: Re: yo_its_ok
Those that have seen it, have freaked out, but one drive is all it takes.
If it doesn't require cutting and you need an "independent review" let me know. I have a G-tech Pro, OBD-II software, and reasonably cheap access to a dyno to put it to the test.
Old Oct 4, 2001 | 01:53 PM
Jon91SE's Avatar
Pusssseeeehhhh
Run a 1/4 and compare times with stock airbox and SI , i doubt your running slower now with the SI , it may seem slower because of the way the noise builds up as the revs build up. On a hot day it will slow you down a bit off the line, but an intake is increasing air flow and is less restrictive then stock, period. I think some of this low end loss people talk about is exaggerated and not backed by 1/4 times, remember an exhaust dosent help low end performance either, but you dont start going faster until you add these bolt on's................
Old Oct 4, 2001 | 02:47 PM
Cisco's Avatar
Do u guys notice a whining/churning noise at WOT? I also hear a whistle at idle. Is this normal?
GC
its the butt dyno effect....its almost given that if you free up the air coming in, you will increase power, and effieciency of a motor, which is a big air pump, just add fuel and spark and joo hab powerrrrrrrrrrr.....LoL...
-Peace
Old Oct 4, 2001 | 03:13 PM
IceY2K1's Avatar
GC
Yes, the whistle sound is normal for a Stillen or JWT cone intake.
Old Oct 4, 2001 | 03:28 PM
ohboiya's Avatar
H ... why r u being like that?
J/K ... I'll drop u an e-mail .. c wazzup!
Old Oct 4, 2001 | 04:06 PM
nc00max
I have the JWT and have barely noticed any drop at all in low-end, and a definite bump in high-end. I left the front part of the stock air intake on so it would still get outside air at a halfway decent pace. It may not be doing jack for me, but like I said, I barely noticed any difference, except for some sweet gains up high. And yes, that's a different bolt on the front of the air scoop. Where the old one is, I don't know.
Old Oct 4, 2001 | 04:08 PM
UMD_MaxSE's Avatar
Got Bent?
well, you have y-pipe and UDP also, so that may make up for any low-end discrepancies
Old Oct 4, 2001 | 04:15 PM
nc00max
This is true, but the JWT was actually my last mod. Before that was the OSCAI, and everyone said I would lose low-end, but maybe the UDP is doing all the extra work on the low-end. Oh well, as long as it's there, right?
Old Oct 4, 2001 | 04:18 PM
IceY2K1's Avatar
The slush box will make it less noticeable than on a 5-speed.
Old Oct 5, 2001 | 02:39 PM
cobymoby's Avatar
Cisco, are your wheels 17 or 18 SSR's?
Old Oct 5, 2001 | 09:09 PM
Cisco's Avatar
17 x 8
Old Oct 5, 2001 | 10:35 PM
AznWontonboy's Avatar
i knew it. i knew you wuold finally build that dirt devil intake i prototyped. send me the blue prints crediting me for some of the work.
Old Oct 6, 2001 | 06:25 AM
UMD_MaxSE's Avatar
Got Bent?
Re: Re: Re: Re: Re: yo_its_ok
wonton powered intake
Old Oct 6, 2001 | 07:20 AM
costcowholesale's Avatar
this sounds kinda stupid but someone said the airbox is restricting the airflow in highend. What if you drill some holes on the airbox wouldn't that solve the problem?
Old Oct 6, 2001 | 07:46 AM
Sonic's Avatar
That would make you slower.
Old Oct 6, 2001 | 04:04 PM
IceY2K1's Avatar
Actually...
That's an old Sentra trick I learned. Russ knows what I'm talking about. You remove the bottom half of the 2-piece air box and tie the filter to the top half that connects to the intake tract. It's a MEAN growl, but DAMN the filter gets dirty quick.
Since our air box is 1-piece the only worth while air box mod would be to cut off the front side of the air box in FRONT of the filter. The only draw back is that you'll be injesting ALL hot underhood air at low speed, but when your concerned about top end it doesn't matter.
I was considering do something like this so that I could remove the drivers' side headlight and make some kind of ram air tract to the air box for the 1/4.
Old Nov 29, 2001 | 09:33 PM
NZ Max's Avatar
Re: Actually...
Old Nov 29, 2001 | 09:42 PM
NZ Max's Avatar
Re: Actually...
I did this to my Cefiro. The only thing I did different was that I got an angle grinder and chopped the bracket peice off the bottom peice of the cold air box to hold the filter in place. The growl was cool, it also made quite a nice rumble at half throttle over about 3000 rpm. I tried it in 2 positions, 1 facing the bottom of the car and the 2nd with the MAFS rotated 1/4 turn so the filter faced the back of the battery. It was louder in the 2nd position but just a bit slower. It killed low end a bit and gave little mid to high end. I just (2 days ago) set it back to stock (I had to use glue and bog to fix the cold air box) and my low end is back but I admit the mid to high sucks compared to what it was with the modified version. I got sick of the noise and I might be selling soon as well.
My cefiro came from japan and has the same variable intake manifold as roadbeast which gives major boost (in power I mean) at 5k rpm.
Overall, I think Id do this again since Im el-cheapo with my d's but Id hack up my cold air box and get another one to replace it with when I got sick of it again.
Old Nov 30, 2001 | 05:39 AM
2K2DEMAX's Avatar
Pele ain't got nothing on me
Actually, I did. With the JWT intake I was only able to muster a 15 flat consistently. With the OSCAI I got down to 14.8 consistently. Now what I have is the CAI + JWT, meaning the JWT stack clamped onto the CAI tube(I had to get an intake adapter to get on the JWT). Let me tell you, the difference is VERY significant, all throughout the RPM band. BTW, before I put on the JWT onto the CAI tube, I ran with the cylindrical K&N that comes with the PRCAI for about 10 days. Car felt great, MUCH better than the OSCAI or JWT alone. Now when I clamped on the JWT to the PRCAI, it was even better, I would say getting the best of all worlds, so to speak. This WILL be verified at the track soon though, probably in about three weeks. Based on what I've seen, I would definitely recommend anyone changing from JWT/Stillen intake to the PRCAI to try this.
Lakersallday24
Jun 16, 2019 01:35 AM
cheftoo
Aug 20, 2015 05:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
