What is BEST Spring & Shock Setup for 5th Gen?
Old Oct 10, 2001 | 02:23 PM
DMan_2KMax's Avatar
Hey guys I would like to know what the best spring and shock setup is for our 5th gen. I want good performance but not a jarring ride under normal driving situations. I've decided to keep my max and make it a project car and wait to get my BMW 330i next summer when my options vest. Thanks in advance.
Old Oct 10, 2001 | 03:02 PM
MOBOY's Avatar
Hmmm
I know this has been hashed and rehashed a hundred times...but here are my two cents.
Go with the progress or B&G springs. They are less harsh. Go with koni shocks.
Old Oct 10, 2001 | 03:21 PM
PhatGuy
I personally like the H&R best. Excellent springs....keeps a nice comfortable ride but improves handling big time and high speed stability!
Old Oct 10, 2001 | 07:11 PM
DMan_2KMax's Avatar
What should I expect to pay?
What will the H&R springs and Koni shocks run me? Where is the best place to buy them and what does the install cost? How much will they drop my car? I don't want much more than a 1-1.5 inch drop.
Old Oct 10, 2001 | 07:36 PM
yongjun's Avatar
Re: What should I expect to pay?
Slam it man.
Sprint springs with Koni shocks
Old Oct 10, 2001 | 08:15 PM
hawk's Avatar
That just shows there are lots of "best" and it's personal choice? I am going to have to add shocks and springs and brakes and corners and pipes and intakes when I have the time (and money).
Old Oct 10, 2001 | 08:29 PM
Keh mon's Avatar
Re: Re: What should I expect to pay?
Originally posted by yongjun
Slam it man.
Except you'll still have the larger gap in the front.
Old Oct 10, 2001 | 08:45 PM
PhatGuy
H&R F=1.4" R=1.3" There is a little wheel gap in the front still but no biggie. They are very well balanced between comfort and performance with a half decent drop IMO. I left mine stock since my car was so new but I would go with Koni once my stock ones die. With a FSTB, RSB and some nice tires you will be flying in corners. Assuming you go to that 3.25" midget.
Old Oct 10, 2001 | 09:43 PM
AznWontonboy's Avatar
Slam it man.
ditto.
keh mon, how will you have a gap? its a lower drop than eibach and H&R
Old Oct 10, 2001 | 09:53 PM
maddmaxx's Avatar
SPRINGS AND SHOCKS
YOU WANT ADVISE ON SPRINGS AND SHOCKS??????????????? Well what ever you do don't listen to MOBOY,I think he should go and drink some tea with Gwen,and leave his 2 cents at the bar.He doesn't even check his air filter,or oil for that matter.
Old Oct 11, 2001 | 05:26 AM
ru4real's Avatar
Originally posted by AznWontonboy
ditto.
I think he means that the front gap is larger than the rear gap to start with, and the Sprints will give a uniform drop, leaving the front larger than the rear.
Old Oct 11, 2001 | 05:46 AM
doublea's Avatar
Re: What is BEST Spring & Shock Setup for 5th Gen?
Hey DMan_2KMax, I am glad that you keep your max, I think you have a hell of a car. I personally will go with Eibach & Koni very soon.
cheers
doublea
Old Oct 11, 2001 | 09:05 AM
Keh mon's Avatar
Exactly my thought
Old Oct 11, 2001 | 09:18 AM
PhatGuy
I say H&R and Koni. The Eibachs are lil too rough and the H&R are a lil lower. I still like my Max to be comfortable.
Old Oct 11, 2001 | 01:10 PM
cobymoby's Avatar
Which would giev a better ride,
H&R/Koni or H&R/Tokico?
Wouldn't the Koni's give a little more stiff ride?
Old Oct 11, 2001 | 01:18 PM
UMD_MaxSE's Avatar
Got Bent?
Konis are stiffer than Tokico
but Koni lasts much longer
Old Oct 11, 2001 | 01:52 PM
matt calder's Avatar
Coilovers are the best. Just ask Keving
Old Oct 11, 2001 | 02:00 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
He doesn't want a harsh ride.
Old Oct 11, 2001 | 03:42 PM
doublea's Avatar
Hey PhatGuy, I believe you live in Ottawa area right ? Watch out for winter with the H&R, might just be too low and cause you some problem.
cheers
doublea
Old Oct 11, 2001 | 03:44 PM
2001SE's Avatar
how bout GC...i know there are the roughest but performencewise there are one of the best
Old Oct 11, 2001 | 04:00 PM
PhatGuy
Ya I should be ok. The H&R are low but not that low. I just bought some nice rims for winter and getting some H rated winter tires. If I didn't live here I would have the Stillen Body Kit already installed! The Max would then be the fly looking snow plow.
cheers
doublea
Old Oct 11, 2001 | 09:23 PM
MaxedOut2g's Avatar
if u dont mind losing a lil ride quality, i say go w/ Progress...they look better than both h&r and eibachs, but dont ride as stiff as eibachs but are not as comfortable as h&r, supposedly....i didnt change my shocks/struts but i would prolly go w/ konis
atw
Old Oct 15, 2001 | 01:14 AM
ChillWill2000's Avatar
Im not sure about shocks/struts but I went with Progress springs..If you go w/ eibach or H&Rs you will probly NOT be happy w/ the drop.I would suggest sprint but Ive been hearin once you go to 2in or more your more likely to need a camber kit. and also I hear the sprints are a little more harsh. you can get the progress for about 150 shipped from pmpdesings@aol.com...by the way the progress drop is 1.7
Old Oct 15, 2001 | 03:04 PM
Raf2kMax's Avatar
2K Supercharged Max SE Auto
-Stillen V2 Supercharger
Bro, i see you're running an auto Max. Hows it feel with the supercharger and all?? cause i heard that its hard as hell on the tranny.
MAXSE5SPD
Sep 17, 2022 04:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
AcuraLegend
Sep 22, 2015 04:22 PM
Lowered_a33
Sep 1, 2015 07:49 PM
