Any have the Stillen BBK?
Old Sep 18, 2007 | 06:20 PM
  #41
irish44j's Avatar
retired moderator
Originally Posted by n3985
The Fastbrakes kit says it comes with aluminum adapter brackets, but I'm guessing for the 5th gen we'll need some other ones? (since the kit is made for 6th gen)
Also, the 6 pot kit will probably throw the brake distribution way off and thus decrease stopping distance?
no, the bracket should bolt right up. But you have to use 6th gen rotors, not your stock 5th gen rotors, of course...
if you use 6th gen rotors and calipers, they bolt up with no bracket....meaning that the spindle mounting points are the same for the 5th gen as for the 6th gen.
Old Sep 18, 2007 | 07:33 PM
  #42
MetaOrbit's Avatar
Got Projectors?
The adapter brackets for the 4-piston caliper (caliper only) upgrade are machined to place the caliper in the same position as the stock 6th gen caliper.
Since we can bolt the stock 6th gen caliper and 6th gen rotor up in place without adapter brackets, it follows that the adapter brackets for the wilwood caliper in that kit will bolt on and do the same exact thing on a 5th gen, provided that you're also using 6th gen rotors.
Edit: irish beat me to it...welll in advance.
Old Sep 18, 2007 | 07:35 PM
  #43
n3985's Avatar
大陆弟弟
Haha, ya I'm planning to just run 6th gen Brembo blanks. But what about the 6 pot? Too much for the front?
Old Sep 18, 2007 | 07:37 PM
  #44
irish44j's Avatar
retired moderator
$300 more for what? It won't make any difference for street driving (and might actually mess the brake balance up more). Only worthwhile if you're looking for the "bling."
The 4-pots are sufficient for cars heavier than ours doing track duty. They're plenty for a street-driven maxima.
Old Sep 18, 2007 | 07:41 PM
  #45
n3985's Avatar
大陆弟弟
I figured it would throw the balance off too much.
So irish, did you order the included BP-10 pads or request HPS pads?
Old Sep 18, 2007 | 07:42 PM
  #46
irish44j's Avatar
retired moderator
I didn't request anything. I was told that the HPS was the standard pad that they came with, which is what i wanted anyhow.
Old Sep 18, 2007 | 08:14 PM
  #47
DenimDan's Avatar
I might sound like an idiot but I can just bolt 6th gen rotors and calipers right up to my fifth gen? at all four corners?
Old Sep 18, 2007 | 08:16 PM
  #48
AceofSpds's Avatar
wat
Nope, you gotta take off your stock ones first
/sarcasm
Yes you can
Old Sep 18, 2007 | 08:21 PM
  #49
DenimDan's Avatar
sweet might have to look into that wilwood kit then
Old Sep 18, 2007 | 08:44 PM
  #50
irish44j's Avatar
retired moderator
no, only on the front.
the 6th gen rears have an internal drum-style ebrake, completely different from ours. So the 6th gen rears will NOT work at all on the 5th gen.
Old Sep 18, 2007 | 08:55 PM
  #51
kramarz99
if you decide to go with Cobra rotors, I have brackets for sale...
Old Sep 19, 2007 | 03:31 PM
  #52
ShiftVQ35
Pricebreak down of a wilwood bbk
Calipers-Wil-120-7477 and they are $165.95 each
Pads-WIL-150-8855K and they are $65.95
lines- Wil-220-7686 and they are $40 for both
Fiting A - wil-220-6413 and it is $20 for both ( 1 per side)
Fitting B - wil-220-6412 and it is $40 for both ( 1 per side)
You still need hardware and rotors and brackets.
These prices are from summitracing.com
Old Sep 19, 2007 | 04:36 PM
  #53
irish44j's Avatar
retired moderator
That's about $500 + brackets and hardware...
The fastbrakes kit puts it all together for you for about $590.....and provides the correct brackets and hardware.
Old Oct 23, 2007 | 11:30 AM
  #54
michaelnyden's Avatar
irish...did they fit okay on your matt blehm 2 piece rotors...please let me know if you had to grind these down and how the balance is if you get these
It's driving me crazy to grind down the pads a huge amount each time I get new ones all because of the hats being a few millimeters too large in diameter!
the hawk hps pads also seem to deposit pad layer on the outer half of the rotor which means they have to be machined after every event...I guess the hawk hps pads don't mate well with the type of metal/surface the 2piece rotors are since I never had any problems with my 1 piece ones...
Old Oct 23, 2007 | 09:14 PM
  #55
irish44j's Avatar
retired moderator
I haven't tried them with the 2pc yet, but the swept area on the OEM's is 2" from the outside edge, and the 2pc rotors have about 2 1/2" of face, so they should work no problem.
Old Oct 24, 2007 | 11:42 AM
  #56
irish, have you had the 2 piece rotors turned/machined yet? were you running hawk hps on them? at a recent autocross, I got the dreaded pad deposit transfer which is common amongst two piece race rotors and less than race compound pads (ie. hawk hps), so it looks like I have to get them turned for the first time...
Old Oct 24, 2007 | 03:16 PM
  #57
irish44j's Avatar
retired moderator
I had them turned a while back after I assembled them, just to make sure they were true. I'll turn them again before they go back on the car in the spring. no material transfer problems here....
Old Oct 24, 2007 | 04:10 PM
  #58
MyownNismo's Avatar
Future Camaro SS owner
I have the stillen kit haven't installed yet. Just sandblasted everything to send to powdercoat. Yes it does fit under stock 17's.
Old Oct 26, 2007 | 01:36 AM
  #59
00SEMAX19's Avatar
All you need is 6th gen rotors, at least for the 5.5 gen
Great deal for a bolt on kit
Old Oct 26, 2007 | 06:58 AM
  #60
MetaOrbit's Avatar
Got Projectors?
Way to restate the already stated!
Old Oct 26, 2007 | 12:12 PM
  #61
00SEMAX19's Avatar
Oops, it was late my eyes were heavy and I thought I was at the end of the thread at the end of the first page
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
Stagnet04
Sep 14, 2015 11:28 PM
