How do I "ground" myself??
Old Oct 19, 2001 | 08:14 PM
2kseman's Avatar
got a company car, Ford Contour w/cloth interior. I would get this little f*ckn nasty zap of electricity when I touch any metal part of the door to close it. I now close the door with the soles of my shoe..problem is, when I get to the house door ****, Zap!!! I hate that!! Anyone how to get rid of this annoyance? thanks.
Old Oct 19, 2001 | 08:32 PM
LaXor's Avatar
Static Guard
Use a little BOUNTY in you dryer when you are drying you clothes!
Old Oct 19, 2001 | 08:34 PM
Rob'sAE's Avatar
You're Faster, I'm Better
Re: How do I "ground" myself??
I have the same thing happen to me, just get used to it.... or touch your wife first
Old Oct 19, 2001 | 08:53 PM
Mike2000SE's Avatar
Set feet on the ground first, then touch some metal part while getting up. Then you should be grounded.
Old Oct 19, 2001 | 09:07 PM
TimW's Avatar
The silent but deadly Moderator
I say...
run a thin elastic metallic wire to tether you to the car at all time...
actually, I've heard you can spray some anti-static stuff for clothes on your cloth seats.
Old Oct 19, 2001 | 10:48 PM
2kseman's Avatar
Humm....I'll try that Monday since I drive my Max in the weekends...thanks!
Old Oct 20, 2001 | 12:02 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
1) Close the door by touching only the window.
or
2) Use the key and touch a metal part once you're outside the car.
or
3) By a anti-static antenna
Old Oct 20, 2001 | 12:08 AM
irvine78's Avatar
nah..that leaves nasty hand print on your freshly washed car..
nah..that's like keying your own car
rice...
how about wearing suede gloves?
Old Oct 20, 2001 | 12:12 AM
adman's Avatar
Well, first, do something REALLY naughty!!!
Then, go sit in the corner for a little while...
ADMAN
Old Oct 20, 2001 | 12:17 AM
Y2KevSE's Avatar
I use my knuckles, so no nasty hand print.
You're not touching the outside door... just any metal part (b-pillar)
rice...:cheese
Like you're not.
how about wearing suede gloves? :cheese
Everytime?
Old Oct 20, 2001 | 12:18 AM
irvine78's Avatar
rice...:cheese
Like you're not.
Everytime?
no comment...especially on number 3...
Old Oct 20, 2001 | 12:50 AM
d_98SE's Avatar
When you get out of the car let the calf of your leg touch the door sill while your heel rest's on the ground. You should feel it flow to the ground.
Old Oct 20, 2001 | 01:02 AM
d_98SE's Avatar
Old Oct 20, 2001 | 02:59 AM
20th maxstyle's Avatar
It could be the cloth on your seats. If the car is new, all you need to do is give it some time. It'll go away. I had the same problem. after a good month or so, Never More. I like the comment about touching your wife, maybe she'll like it.
Old Oct 20, 2001 | 08:12 AM
woosh's Avatar
Get a ground strap for the car. You've probly seen them on huge trucks. Its a nylon strap that attaches, usually to the rear axle and the other end drags on the ground.
Old Oct 20, 2001 | 11:45 AM
areX's Avatar
that'd be a funny sight to see... you chasing your wife around the car trying to zap her...
Old Oct 20, 2001 | 11:54 AM
NuJerseyDrive's Avatar
Man, I've had my car for over a year now with 28K miles. This still happens to me 85% of the time. I guess I'm used to it already, it's just the big one that go ZZZZZZAPPP that get to me..only becuase peeps look at me like WTF?!?
My girlie chuckles everytime.
Old Oct 22, 2001 | 12:51 AM
2kseman's Avatar
thanks for the replies, here's a funky one....find an old flame, girlfriend, boyfriend or who ever tickle your fancies....sneek up on the them and Zzzap!! Then just say, there's still sparks between us!
D*mn, it must be late, laughing ol at my own comments...
Old Oct 22, 2001 | 03:34 AM
ToYLeT902's Avatar
JET Speed Lab
do those rubber things that hang from your car and drag on the ground reallly work? or is that just a rip off...
Old Oct 22, 2001 | 10:54 AM
I'm Lost's Avatar
hahaha I like that one...except the girl might be going through pms or something along that line, turns around and slap you in the face :P
Old Oct 22, 2001 | 08:19 PM
woosh's Avatar
Don't know about the rubber ones but it may work (its an insulator). They are usually nylon (same kinda stuff used on gym bag handles)
Old Oct 23, 2001 | 08:14 AM
Newman's Avatar
that would probably be your best choice...especially if it DOESNT EVEN WORK
this happened to me when i had my explorer (maybe its a ford thing?) it was a 95 so it didnt go away after a few months. also, if i remember correctly it happened more in the winter than in the warmer months. i dont think i ever solved it i just closed the door with my forearm as i was usually wearing long sleeves so it didnt shock as much. try the idea of spraying your seats with static guard or something that Timmeh mentioned.
Old Oct 23, 2001 | 08:24 AM
Y2KevSE's Avatar
Oops.. misspelling. I meant "buy"
Yeah, anti-static antenna will not work (at least mine doesn't work).
ZAP! ZAP! ZAP!
Old Oct 23, 2001 | 04:29 PM
speedtrip's Avatar
I used to work for a company that dealt with static elimination in industrial enviroments. What's happening is when you are getting out of the car the friction between the car's seat and your clothing generates a static charge. Since your body is insulated from ground you absorb the charge. Then you touch the metal door, ground yourself, and get a nasty shock. The suggestion of using a fabric softener is a good one. Spray down the cars seat with it and see if it helps. Just be aware that surface coatings will wear off.
Static discharges occur more frequently in fall and winter because humidity levels go down. When you see that blue spark that's atleast a 50,000 volt discharge. The reason we only get shocked and not fried is that there is minimal amperage.
What I do to limit the shock is to open the door latch, touch some metal then proceed to get out of the car. Since I am in constant contact with ground I don't build up a large charge and get the nasty shock.
When I forget to ground myself getting out of my max and have to bite the bullet I make a fist and close the door with my fist so the discharge is spread out over a larger surface area. When you use your fingers to close the car's door you are focusing a large charge to a single point and you get a concentrated discharge.
