squeaking sound from the front please help :(
Old Oct 6, 2007 | 07:14 PM
imported_D_Roc's Avatar
couple of months ago had this sound but didn't happen often and the sound was not that lout (had to listen very carefully) my dad took the wheels off and checked but nothing was wrong, and it was ok for a couple of months untill last week it started again. now its getting louder. it only happens when i'm taking a left sharp turn (only when the car is moving) any one have any idea why
thanks
D
Old Oct 7, 2007 | 01:31 PM
anyone ??
Old Oct 7, 2007 | 01:53 PM
CoolMax's Avatar
is invisible
pmub
Old Oct 7, 2007 | 01:54 PM
jasonmax's Avatar
Originally Posted by CoolMax
pmub
eerga
Old Oct 7, 2007 | 02:20 PM
jaymemaurice's Avatar
Sway bar link ends?
Old Oct 7, 2007 | 07:31 PM
CaTalyst.X's Avatar
Wheel Bearing FTW. Lots of max have problems with them. I would venture to say that is the case. Sway bar link ends probably wouldnt happen only on a turn, rather over bumps etc.
Old Oct 8, 2007 | 02:23 AM
knight_yyz's Avatar
Toolie
+1 wheel bearing, just had mine fixed on passenger side. Fix it soon or the tech will not be able to remove it. I left mine too long and labour was expensive
Old Oct 8, 2007 | 07:49 AM
o0zarkawater2's Avatar
If it is the wheel bearing it isn't all that hard to fix yourself, with the exception of pressing it out of the knuckle. I took on doing mine myself with limited experience under my belt. I bought a 12ton shop press from Harbor Freight to do the job (Cheap and easy to return when I was done with it).
Even with the press I was not able to get the bearing out of the knuckle. I eventually just took it with the new bearing and new hub to Pep Boys and paid them 45$ to press the old one out and the new one in. Mine was so bad that I also had to replace the hub, it was all chewed up.
Ended up costing me ~250$ to do it myself ordering parts from Dave B.(The shops I called wanted 350-450$ not including replacing the hub).
Old Oct 8, 2007 | 02:06 PM
knight_yyz's Avatar
Toolie
cost me 250 at the dealer in Canada
Old Oct 8, 2007 | 02:12 PM
BLACKKILA.GTR's Avatar
if its the swaybar end links wat can u do to stop the sqeak??
Old Oct 8, 2007 | 02:28 PM
knight_yyz's Avatar
Toolie
buy new ones
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
dvcamp
Sep 18, 2015 10:17 AM
TheMafia
Sep 4, 2015 08:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
