Knocking and Pinging
Old Oct 29, 2007 | 06:13 PM
Wheelie King's Avatar
My '03 maxima knocks and pings pretty severely at 2K RPM, especially when I am going up hill or giving light throttle. Is this common and is there a common fix? Thanks.
Old Oct 29, 2007 | 06:47 PM
The Hulio's Avatar
Pinging
I fixed it with one heat range colder plugs and Sunoco Ultra '94.
Joe.
Old Oct 29, 2007 | 06:49 PM
wyche89's Avatar
Joe.
new NGK plat spark plugs and premium octane should take care of it
Old Oct 29, 2007 | 06:51 PM
SoonerFan's Avatar
Cletus
take care of your car and use the proper fuel...
Old Oct 29, 2007 | 08:44 PM
NmexMAX's Avatar
dot dot dot ...
On cooler plugs/catch can/91+.
Old Oct 29, 2007 | 10:50 PM
spdfreak's Avatar
Has your car had the 17* timing change? If so this may be the culprit. Should be an easy fix by using prelium gas and colder spark plugs.
Old Oct 30, 2007 | 08:28 AM
SoonerFan's Avatar
Cletus
you should use premium fuel regardless
Old Oct 30, 2007 | 09:46 AM
HotMaxx02's Avatar
I always use premium fuel and the problem was still there.
Did plugs when i installed my headers and its gone now... or maybe i just cant hear it from the loud exhaust??
Old Oct 30, 2007 | 09:48 AM
NmexMAX's Avatar
dot dot dot ...
Did you happen to go to a cooler heat range on the plugs?
Old Oct 30, 2007 | 10:55 AM
HotMaxx02's Avatar
Just Bosh Platinum +2
(yes i know everybody hates Bosch)
Old Oct 30, 2007 | 01:09 PM
Shu2k2's Avatar
I seem to have the same knocking problem. Thinking of going to NGK iridium one step cooler. Trying to get Nissan to talk to me about it but all I get is that they run the fuel very lean and the timing advanced for economy. Any way to use a bit more fuel in the 2k-3k rpm range to cool things off? Nissan tech says we can retard the timing a bit but will loose power that way. What's with the 17* timing update?
Old Oct 30, 2007 | 08:45 PM
spdfreak's Avatar
Search
Old Oct 30, 2007 | 08:47 PM
SoonerFan's Avatar
Cletus
http://forums.maxima.org/showthread.php?t=365289
Old Oct 30, 2007 | 08:58 PM
spdfreak's Avatar
Originally Posted by soonerfan
Your too nice.
Old Oct 30, 2007 | 09:34 PM
SoonerFan's Avatar
Cletus
Your too nice.
i didnt give him the answer...just the link to the proper place to ask the question.
Old Oct 30, 2007 | 10:33 PM
DasYears
weird how its a different experience for everyone. i run my car pretty lean under high throttle (im at -10 on the vafc for everything over 4100) and i dont ever get pinging, even with 17* timing. in fact, the only time ive gotten pinging for the whole life of the car is when the dyno guy went 15.0 on the dyno after like 4 runs
Old Oct 31, 2007 | 12:55 PM
'02_EMILBUS's Avatar
I gotta ticking initially when starting then, it goes away. Low rpm tapping is there and I use premium fuel. I need new plugs and im i need to definitely do the timing advance!
What is the favorable heat range on the cooler plugs that have been mentioned??
If i turn the radio up the problem never seems to be there!
Old Oct 31, 2007 | 03:01 PM
boris's Avatar
What is the drawback using colder plugs? Power loss, mileage, etc.?
Old Oct 31, 2007 | 03:33 PM
That Girl's Avatar
Not new, I re-registered.
Originally Posted by Wheelie King
My '03 maxim knocks and pings pretty severely at 2K RPM, especially when I am going up hill or giving light throttle. Is this common and is there a common fix? Thanks.
Same thing happened to me after I put in a couple (maybe more) tanks of 87 octane gas. It went away as soon as I put in the higher octane.
Old Oct 31, 2007 | 04:00 PM
z00york145's Avatar
I agree with the getting better octane gas, I'd replace the stock spark plugs while your at it.
Old Oct 31, 2007 | 04:45 PM
wyche89's Avatar
i thought NGK plats were the best option for us
Old Oct 31, 2007 | 05:09 PM
maximadave's Avatar
detailerdaveb@gmail.com
Search
there are way too many discussions on this subject
Old Oct 31, 2007 | 05:26 PM
spdfreak's Avatar
I know. I clicked the link for the hell of it.
I was being sarcastic.
Old Oct 31, 2007 | 06:00 PM
I use super unleaded/93 octane gas.
I checked my plugs this evening. I currently am using NGK R PLFR5A 11. I think NGK PLFR5A 11 are stock. I'm not sure what difference the "R" makes. I don't think it's a colder plug. As I understand plugs, a colder one is NGK LFR6AIX 11. Is that what people are using for colder plugs in their maximas?
Old Oct 31, 2007 | 06:16 PM
NmexMAX's Avatar
dot dot dot ...
LFR6AIX
I would use LFR6A's. Maybe add a catch can
I'm bored and the ToT's are a little lean this evening, so here you go:
IX = Iridium. Use this chart and plug a 6 in where the 5 is and you will have the equivalent plug in a colder heat range.
http://forums.maxima.org/showpost.ph...&postcount=120
A little background on heat range:
http://www.ngk.de/Spark_plugs.649.0.html
More background on catch cans:
http://forums.maxima.org/showthread.php?t=312377
http://forums.maxima.org/showthread.php?t=357109
http://forums.maxima.org/showthread.php?t=351891
Old Nov 3, 2007 | 09:29 AM
aksansai's Avatar
01 Maxima SE, 5-spd
My 01 had the pinging problem (but no knocking) and it was totally unrelated to plugs/coils/fuel. Mine was a MAF (but I don't know 5.5 gen's behavior with their faulty MAF).
Old Nov 3, 2007 | 08:31 PM
I added an oil catch can and changed my front 3 plugs. I'll change the other 3 next week. I also added some oil, a bottle of injector cleaner and reset the ECU. I'm driving it hard thinking that thousands of miles of highway driving in 6th gear may have resulted in weak ECU signals. From what I can tell, the pinging is a little better. We'll see once I replace the rest of the plugs run the car for a while.
Old Jun 12, 2008 | 11:37 PM
MADMAX2003's Avatar
Solution to 02/03 Maxima Engine ping at 1800-2000rpm
Guys...the problem that causes the ping under load really lies with fuel delivery and carbon buildup in cylinders. To fix these problems you need to replace your in-tank fuel filter every two years/40,000km(cost is $8.90). I know that Nissan says that it's a lifetime filter because of it's location in the gas tank and the filter is built into the fuel pump, but the filter itself is made with regular paper that develops sediment/gunk buildup as the mileage rolls on and therefore there is a slight slow down of fuel delivery to the engine under load with light acceleration(2000rpm). This causes a lean fuel mixture in the cylinders and the pinging starts. Under heavier throttle, the fuel pump kicks up the pressure and sends more fuel, so therefore no pinging. To keep the cylinders carbon-free, use seafoam motor treatment every 5000km. Carbon buildup contributes to engine ping under loads.
Old Jun 12, 2008 | 11:44 PM
PTNR's Avatar
i'll second this.... i also had to replace the MAF on my 2k to get rid of pinging that came on suddenly. If was pinging only under load and usually if i backed off the throttle it would stop. New MAF fixed it.
Old Jun 13, 2008 | 12:17 AM
SoonerFan's Avatar
Cletus
MADMAX2003
how many threads are you going to bump with posts about a "solution"???
Old Jun 13, 2008 | 10:18 AM
maximadave's Avatar
My '02 Max has been pinging since I bought it new with 7 miles on it, explain that
Old Jun 13, 2008 | 11:53 AM
MADMAX2003's Avatar
My '03 Maxima also had a slight pinging from when it was brand new, but the pinging got louder and more constant when it went over 40,000km. I changed the fuel filter and the pinging reduced, but was still not exactly like when it was new. I then did a series of seafoam decarbonizing treatments and then it came back to normal. Remember, that it is normal for all high compression engines to exhibit slight ping under load because of the high cylinder temperatures.
Old Jun 13, 2008 | 08:02 PM
NmexMAX's Avatar
dot dot dot ...
My car never pings audibly and has the came CR as yours.
Old Jun 13, 2008 | 08:47 PM
SoonerFan's Avatar
Cletus
MADMAX2003 is the expert and discovered the cause of a problem.....we should all listen to him...
Old Jun 13, 2008 | 10:08 PM
MADMAX2003's Avatar
Read page 9-4 of owner's manual. It says to expect pinging under loads for greatest fuel benefit..Nissan wouldn't make these things up. Other high compression engines like the viper, corvette, ferrari..just to name a few..also experience pinging under load. If your engine is ping free, it means that it's running rich.
Old Jun 13, 2008 | 10:12 PM
MADMAX2003's Avatar
Yo sooner...I got the feeling you jealous that I found the solution and you didn't...lol...hahahaha
Old Jun 13, 2008 | 10:38 PM
SoonerFan's Avatar
Cletus
Old Jun 13, 2008 | 10:41 PM
SoonerFan's Avatar
Cletus
Old Jun 13, 2008 | 10:42 PM
SoonerFan's Avatar
Cletus
so MADMAX2003 thinks the pinging is the same as a timing chain rattle....nice
Old Jun 14, 2008 | 11:59 PM
MADMAX2003's Avatar
Hey sooner...might be a really good idea to go check out a shrink
