How do i clean an apexi power intake? Please read.
Hi,
I have a injen cold air intake on my infiniti i35 and i used the apexi power intake as the filter. since i brought the filter i have yet to clean it. How do i clean the filter. Do i buy the k&n filter cleaner or do i have to buy another filter which i do not think i have to. I proably put like 10k on the filter. any help would be great. Also, the only reason i did not stick with the injen air filter is becasue i have to apply oil on it. I did try the aem dryflow which was a great product but the apexi makes a nice deep sound. thanks
Yeah, I would just get a K&N to be honest with you. The difference is nominal, but it costs a lot less, and you can clean it. I had an Apexi when they first came out, and noticed no change when I switched.
Yea I blow mine out from the inside when im at my uncles shop, and you do see dirt flying off of it
I wanna say on cardomain.com in the parts section they had the filters for like $50, but now I see that they dont even carry apexi line of products
Yea, i'd stick with the A'pexi. The A'pexi does flow more air than a K&N. it's also interesting to note the A'pexi creates a unique vortex effect, espcially above 3k RPM. (although it flows air smoother, the throttle body and plenum negate any effect). Keep in mind to that if you switch to a "cleanable" filter that over oiling it will ruin an MAF.
Don't hold me to it, but I also believe it saved my engine. i drove into too big of a puddle, and the filter was able to keep the engine from sucking water. It actually got so wet the engine bogged b/c of a lack of air, but I didn't even ruin my MAF.
i agree that the Apexi is better but...be careful with that statement. there is no proof that a properly oiled filter harms the MAF.
i heard apexi, as many have said here, has the one of the best filtration, and the best airflow. depending on the price, you might be able to justify the cost. i would personally get a K&n cuz of the price.
I you have big pieces of debris in between the pleats use a painters brush and brush them out. I wouldn't reccomend using air to blow from the inside unless it's low pressure cause you could damage the filter.
FYI guys, I don't know from personal experience, but I have researched the APEXI vortex filters (power intakes) quite a bit. They are expensive, but they certainly look worth every penny. In fact I have an Injen intake and when it's time to replace the filter, I'm going to see if I can get an adapter to put one of the Apexi filters on.
"The dual funnel Power Intake evolved from the highly successful Super Intake. Subtle refinements in the design and filter element resulted in a 10% reduction in pressure drop. Utilizing an upper and lower funnel, the Power Intake reduces air turbulence within the filter and creates smooth air flow into the throttle body. The Power Intake is a maintenance-free dry-type air filter and will alleviate the problem of filter oil from wet air cleaners interfering with the air-flow meter. Accept no imitations."
lowpost99
Oct 26, 2025 06:53 PM
lux97Max
Sep 4, 2015 05:42 PM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
