Going From 5th Gen Auto to 5.5 gen 6 speed... Questions...
Old Dec 15, 2007 | 06:41 PM
  #41
wyche89's Avatar
Originally Posted by wyche89
how the hell do u check the transmission fluid level on those things? i was reading and saw this one process where a dude was changing his transmission fluid, and he filled it until it started overflowing! is that correct? i notice theres no dipstick on maual trannies.. how do i keep tabs on the level?
does anybody have an answer for this one?
Old Dec 15, 2007 | 07:07 PM
  #42
boris's Avatar
"he filled it until it started overflowing! is that correct?"
That 's right, it's correct.
Old Dec 15, 2007 | 07:30 PM
  #43
cefiro80's Avatar
Originally Posted by merlin2375
Newer cars are usually more forgiving. Just take your time, after a few drives it'll be like you've been doing it for years.
You don't have to fully release the gas, but why waste the gas by keeping your foot down. It's very unlikely you'll stall in any gear other than first, so save the gas. Before you bring the car back into gear you may want to "stab" the gas so you can rev-match and make it more smooth.
You could potentially do some damage if you misshift. But you won't be able to get into first once you're really moving. The tranny won't let you (you'll know it'd be too hard).
I would disagree that newer cars are a little easier. Driving stick a33 is a lot more unforgiving then driving our 68 camaro ss. It really all depends on the clutch etc but dont be intimidated with driving stick it isnt that bad.
Old Dec 15, 2007 | 07:53 PM
  #44
wyche89's Avatar
so there's no way to monitor the fluid level on a manual tranny? that seems weird.. lol
Old Dec 17, 2007 | 05:17 PM
  #45
wyche89's Avatar
Originally Posted by Bluesbrekr
IMO the 2k2 is a hard car to learn with if someone has not driven a MT before. Here's a good away to learn:
Put the car in 1st gear, then without pressing the gas pedal s-l-o-w-ly release the clutch. The object is to get the car moving without using the gas. This does put a bit of stress on the clutch, but it's no worse than stalling the car a bunch of times. Once you know where the friction point is with the clutch you ought to be able to start using the gas when starting out.
Originally Posted by Armon
The purpose of that exercise is to learn where the friction point is.. i.e. where does the clutch "catch." On a daily basis, however, you want to be giving the engine a little gas right before you let the clutch catch.
how do i know when the clutch catches? will i feel something in the pedal or something like that?
Old Dec 17, 2007 | 08:17 PM
  #46
telmohd's Avatar
BEST way to learn is through practice and experimenting with ur clutch...i bought mine and i didnt know how to drive stick...i stalled out a couple of times but it only took me like 2 days to get it down. word of advice (i learned this way), practice moving from a stop...just go then stop then go again....ull get used to ur clutch and u will get better at accelerating smoothly...ull be fine...its easy =)
Old Dec 18, 2007 | 05:54 AM
  #47
kukx30de's Avatar
Subconsiously watch the rpm guage.
As soon as your clutch catches, your rpms will dip and you will feel a slight vibration in the steering wheel as the idle drops. At that point you will also start to see the car begin moving. Yeah a couple of things happening together but you'll get the hang of it really quick.
good luck!
Old Dec 19, 2007 | 07:41 PM
  #48
wyche89's Avatar
alright guys.. picked up the car today.. a nice 03 6 speed TE with 49,000 miles on it.. now just gotta learn to drive the sucker! lol
i drove for about 20 minutes around the dealer parking lot trying to get the clutch thing down, and it went ok.. i stalled a few times of course, but i think im getting it.. i practiced some more with my mom when i got home.. i noticed that sometimes the stick feels like it doesnt go into gear smoothly... like sometimes it clicks right in, and other times it goes into gear kinda roughly on the 1-2 shift and 2-3 shift... is that normal, or am i doing something wrong?
also.. i tried that letting the clutch so slowly, and that worked pretty well.. what i did was, i let the clutch up, then when i saw the car start to move, i gave it a little gas and got going.. is that the good way to do it?
Old Dec 19, 2007 | 07:43 PM
  #49
jasonmax's Avatar
you didn't press clutch far enough.
yeah, that's right. release clutch slowly when 1st and 2nd gear.
Old Dec 19, 2007 | 07:44 PM
  #50
wyche89's Avatar
i swore i was pressing it all the way down... but i'll try again tomorrow.. is it normal to hear a clicking sound everytime you press the clutch in?
Old Dec 19, 2007 | 07:54 PM
  #51
SoonerFan's Avatar
Cletus
as ive said before, its all about finding the clutch engagement point so you know exactly when to apply the proper amount of throttle. thats very important in these cars.
sit in a parking lot and slowly let out the clutch (no gas). as soon as it starts to catch, push the clutch back in and do it again. then do it when you are sitting at lights. after a few days/weeks, you will have muscle memory and know the engagement point. makes starting and shifts quick and smooth.
Old Dec 19, 2007 | 07:55 PM
  #52
SoonerFan's Avatar
Cletus
thats the spring at the top of the clutch pedal...its normal
Old Dec 19, 2007 | 07:56 PM
  #53
SoonerFan's Avatar
Cletus
as far as the shifter...the shift linkage isnt the best. lose and notchy. a STS and ES bushing help a lot.
Old Dec 20, 2007 | 08:14 PM
  #54
wyche89's Avatar
i'm gettin better fellas!!!!!! i can now start out on a hill without ANY rollback.. i thought that you had to let the clutch out and push the gas in at the same rate, but i figured out a new way (probably old news to all of you, but new to me) --thanx to all of those who told me about the catch point thing, because that exercise helped me devise this method-- so after some practicing of letting the clutch out and back in (thank you sooner), i got a feel for the catch point.. and i was doing this exercise in a driveway where theres a nice incline... what i did was, i kept my foot on the brake and brought the clutch up just to the point where it was about to catch, let off the brake, and i was slowly moving forward without even using any gas!! i was like holy crap... this makes things so much easier.. now i can start on a hill without rolling back... i'm so proud of myself.. lol.. that was the main issue i was worried about, but thats no sweat now.. i just gotta do it slowly.. but i do still have an issue though...
my upshifts are still kinda rough most times.. but sometimes they're smooth as an automoatic.. and i have yet to figure out what it is i'm doing to get these smooth shifts.. my ultimate goal is to drive, and have it feel like an automatic to my passengers.. do i have to give it a little gas after i shift before i let the clutch out? or not touch the gas at all until the clutch is completely out? or let the clutch out and the same speed i get on the gas after the shift? i cant figure this out yet...
Old Dec 20, 2007 | 08:17 PM
  #55
SoonerFan's Avatar
Cletus
glad the advice helped.
for smooth upshift, its all dependent on the RPMs. low RPMs, you can shift slowly and it wont matter. higher RPMs, you have to shift faster. just takes practice and learning YOUR car.
after the learn all that, come back and learn about rev-matching for down shifts (really needed on these cars).
Old Dec 20, 2007 | 08:29 PM
  #56
wyche89's Avatar
yeah, i tried to downshift to 2nd gear at around 40mph... wasnt pretty.. lol.. it was really jerky.. i think i need to learn to drive slowly before i can downshift to accelerate quickly... so in higher rpms, i can press clutch in quickly, shift quickly, and let off the slutch quickly, and it'll be smooth regardless of when i get on the gas after the shift?
Old Dec 21, 2007 | 12:35 AM
  #57
boris's Avatar
The safest way to start out on a hill without ANY rollback is using your hand break. Try it, it's easy.
Old Dec 21, 2007 | 02:23 PM
  #58
wyche89's Avatar
one thing that sucked.. i upshifted to 2nd going around a turn in the rain... yeah... it shifted roughly and definitely slid a little bit mental note.. don't upshift going around a corner in the rain until i get good.. lol
Old Dec 21, 2007 | 05:55 PM
  #59
wyche89's Avatar
hey... WHAT IS THE DEAL WITH THE TURN RADIUS ON THESE THINGS? i went to make my everyday u-turn at the end of my block and i damn near hit a parked car! the turn radius on the 5.5 gens is apparently larger than the 5th gens... i was highly upset.. i thought everything was the same besides engine/tranny/headlights, etc...
Old Dec 21, 2007 | 06:46 PM
  #60
pbn85's Avatar
good luck with the car man...you'll have lots of fun with it
the turn radius does suck...A LOT! It pisses me off
Old Dec 22, 2007 | 06:27 AM
  #61
wyche89's Avatar
so does anybody have any tips for smoother upshifts in higher rpms? because i'm scared all these rough shifts might damage my car.. will it do any serious damage, besides maybe killing my motor mounts, clutch, and front tires?
Old Dec 22, 2007 | 01:05 PM
  #62
SoonerFan's Avatar
Cletus
practice.
the shift has to be quick and smooth
Old Dec 22, 2007 | 04:10 PM
  #63
wyche89's Avatar
ok... i'm trying to be patient and get better, but it's hard.. lol.. i guess it's pretty good though considering i've only been driving a few days.. but will this time period f' my car up though?
Old Dec 22, 2007 | 04:14 PM
  #64
wirelessdude04's Avatar
your left foot and right foot gotta work in a pattern.... Let of one give the other some more pressure....
Old Dec 24, 2007 | 03:16 AM
  #65
wyche89's Avatar
ok.. i'm re-defining the hardest part of learning to drive a stick.. its not starting from a stop.. nor is it even starting from a stop on the hill.. i'm did both of those in 2 days.. it's up-shifting smoothly.. i think i figured out that after you shift and push the clutch in, you have to rev the engine to the point that it will be in the next gear before you let the clutch out to make the changeover smooth.. and if you do it quickly, then it should be smoother cause the rpms dont get a chance to drop as much when ur foot is off the gas while the clutch is in... does that sound about right?
Old Dec 24, 2007 | 02:24 PM
  #66
boris's Avatar
Right, and they call it rev matching
Old Dec 24, 2007 | 09:07 PM
  #67
godlyone's Avatar
ahhh! cliMAX!
dude, when are you shifting.. .you're not waiting until redline are you? you should shift btwn 2.5-3k rpm for daily driving.
off gas, clutch down <-- simultaneously
shift, clutch up and on gas <- also simulataneously
Old Dec 25, 2007 | 12:01 PM
  #68
wyche89's Avatar
no, im not shifting at redline.. or anywhere near it.. lol.. the highest i went was 4k so far.. but it's still kinda jerky sometimes when i let off the clutch and get back on the gas
Old Dec 25, 2007 | 01:47 PM
  #69
Tippy Toes's Avatar
you need to push the clutch in more at higher rivs, and catch it by pressing the gas quicker at that speed. only try to drop it 700 rpm at most. This is using more clutch but it wont jerk as much...dont let the clutch out fast at that rpm, press more gas and use more clutch to engage.
Old Dec 26, 2007 | 12:09 PM
  #70
ouzo99max's Avatar
just keep driving man eventually you'll get the hang of it.
the first day i got my maxima my bro-in law drove it home for me. I drove it around the street in first + second gear, then i just went and drove on the street and highway 10 minutes later. I was a little nervous but you have to learn somehow. Do what you have to do to not let the car roll on hills, then just master it.
On that first day I got my car, I was at a stop sign by my friends house which was at a little incline, needless to say i couldn't get the car to move for a couple minutes lol. I finally just floored it or something and took off. Just don't ride the clutch!
Old Dec 27, 2007 | 08:21 AM
  #71
wyche89's Avatar
ok.. is there a reason why anytime i lift off the gas or get on the gas in certain gears at certain speeds that the car has a slight jerk? if i'm cruising and i lift off of the gas in second gear at about 20mph, the car jerks ever so slightly.. then when i give it even the slightest amount of gas, it does the same thing.. it's not a big jerk, but it's so annoying... is there a reason why it does this?
Old Dec 27, 2007 | 08:56 AM
  #72
02Maximan's Avatar
Drive by wire...
Old Dec 27, 2007 | 09:38 AM
  #73
wyche89's Avatar
i heard of the drive by wire throttle thing.. what does that mean?
Old Dec 27, 2007 | 10:23 PM
  #74
boris's Avatar
It means, the throttle is driven by the signal from ECU, not by the cable mechanically linked to the gas pedal. When you hit gas, the ECU sends a signal to tiny servo motor, and it moves the butterfly plate. However, the effect you experienced is not caused by DBW, rather this is the drawback of the majority of manual trannies. I drove many cars w/manual trannies, most of them didn't have DBW, but all of them did have this behavior. I heard the stiffer engine mounts can reduce the effect, but i may be wrong.
Old Dec 27, 2007 | 10:35 PM
  #75
wyche89's Avatar
oh ok.. thanx for the info.. i didnt even notice there was no throttle cable.. it's not a huge deal anyway.. just annoying.. but on a side note...
HOLY **** this car is fast! i took it on the highway and did a full throttle run from a stop up to like 3rd gear.. whew.. lemme tell you.. lol.. FAST.. i chirped 2nd gear and all that fun stuff.. i heard people talk about that, and i dont know if it's a good thing or not but.. yeah.. my tires definitely chirped on the 1-2 changeover.. i looked down at the speedometer, and it was climing so fast... so much faster than my 01 auto with intake and y-pipe.. now i can do that thing where you roll back and forth at a light, and still be in control.. i felt so cool and my upshifts are smoothing out now.. still not perfect but getting there.. the only thing i really still have trouble with is backing up hills.. my girlfriend lives on a hill street and i have to parallel park while backing up the incline, trying not to go too fast, go too slow, stall, hit the curb, or any parked cars, and get in at the right angle.. it's quite challenging.. lol.. but it's no big deal
Old Jan 7, 2008 | 02:13 PM
  #76
wyche89's Avatar
this clicking sound went away when i press the clutch in.. now it's completely silent when i'm pressing it in and letting it out... is there something wrong?
Old Jan 7, 2008 | 03:00 PM
  #77
crazy97's Avatar
You mean when you ride the clutch? That's putting extra wear on the clutch which is not really cool. Glad you are haing a good time with the car though.
Old Jan 7, 2008 | 05:29 PM
  #78
wyche89's Avatar
no, not when i'm riding the clutch... when i was at a stop with either the car in neutral or 1st gear, it used to make a clicking sound when i pushed it in, and now it doesn't do it anymore.. i was just wondering if anything was wrong
p.s... are these behaviors considered riding the clutch?:
1. pressing it in as your coasting to a stop
2. holding it down in while stopped at a traffic light in 1st gear
3. holding it in while going at extremely low speeds (1-10mph) in 1st or 2nd gear to prevent the car from bucking when i'm off the gas
Old Jan 9, 2008 | 09:31 PM
  #79
wyche89's Avatar
anybody?
Old Jan 21, 2008 | 08:15 AM
  #80
wyche89's Avatar
ok i'm back... what's the deal with this rev-matching stuff on the VQ? i tried it a couple times last night and it was still kinda jery (though not as bad as when i let the clutch out without giving ANY gas)
