ABS question plz
Old Nov 14, 2007 | 03:42 PM
bkmax96's Avatar
ABS question plz
abs light comes on...then ill stop driving turn the car back on and the light goes off? idk is the system fukin with me or do i have a problem?
Old Nov 14, 2007 | 03:43 PM
upstatemax's Avatar
check the sensors...
Old Nov 14, 2007 | 03:45 PM
bkmax96's Avatar
check them for what? like splits in the wires etc... i did that they seem fine
Old Nov 14, 2007 | 03:55 PM
upstatemax's Avatar
Exactly that, I had this problem when my front ABS wires were rubbing on my control arm and they would short out when they touched the metal (rubbed off the wire insulation)... Once the car was turned off and back on, the light was gone.
Also check to make sure they are not being pulled out of the fittings, you can also have the code read and that will tell you what wheel the problem is coming from.
Old Nov 14, 2007 | 04:01 PM
merlin2375's Avatar
Take off each wheel and look you'll find a ring with teeth on it (looks like a big gear). Carefully clean it off along with the sensor itself.
Check this link out, should give a general idea
http://www.vr4stealth.com/abs_speed_sensor_cleaning.htm
Also, check your brake fluid level
Old Nov 14, 2007 | 05:15 PM
A33 VQ30DEK's Avatar
new abs sensor time
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
