i think my tranny is done
Old Nov 29, 2007 | 05:07 PM
opanick's Avatar
I have a 2002 GLE with a 120k and the tranny has gone to hell!!!!!!
First I was getting hard 1-2 shifts which lasted a few days, then hard shifts and slipping going from 2-3, now it feels like its shifting out of 4th when taking off from a stop, and my reverse totally went out, im sure I left out a few other things it has been doing, its just been pissing me off so much
could this be a fluid problem, something electrical, or just plain old wear and tear??????
Old Nov 29, 2007 | 05:58 PM
ShiftVQ35
nissan trannies were never the best. are you the original owner of the car?
Old Nov 29, 2007 | 06:08 PM
wyche89's Avatar
good question.. the answer and maintenance history could give us some insight into why it happened.. if you are the original owner, how did you care for the transmission... any regular fluid changes or flushes?
Old Nov 29, 2007 | 06:09 PM
DrunkieTheBear's Avatar
Turbo'd Saab
time for a manual swap, thats what I am doing.
Old Nov 29, 2007 | 06:15 PM
SoonerFan's Avatar
Cletus
bad TCM and/or solenoid...you didnt fix the problem...now your tranny IS probably bad
Old Nov 29, 2007 | 06:18 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
TCM.. for sure... price $472.00 from DaveB.. also this price is for an 01...... so give him a call to see how much $$$$ for yours
Old Nov 29, 2007 | 10:19 PM
hotstartup's Avatar
whats the TCM? and how do i know if its bad? I just picked up an 03 GLE, tranny fluid is dirty but i was debating on doing a flush (i have read that this can be deadly) or just replacing the fluid. tranny shifts perfectly right now.
sorry for the thread hijack! but i cant post questions yet.
Old Nov 29, 2007 | 11:08 PM
SoonerFan's Avatar
Cletus
you cant start a thread because you need to read rules, stickies, and FAQs.
it shifts fine...it is fine
Old Nov 29, 2007 | 11:09 PM
DasYears
i have a used TCM from a 2k2 auto if you need one. pm me
Old Nov 30, 2007 | 12:22 AM
hotstartup's Avatar
yea i know i need 15+ posts, waiting till i get there.
How safe is a tranny flush on the maximas? i know on older acura's its not recommended as the dirt gets stuck on the screen and can cause premature failure.
my car is at 70k miles.
Old Nov 30, 2007 | 12:48 AM
Child_uv_KoRn's Avatar
Bad *** Newb
you're cruising for a ban, just fyi (they told you to read the rules and you didn't listen)
****, now I'm comment abusing!!!
Old Nov 30, 2007 | 01:22 AM
hotstartup's Avatar
sorry man, the rules thread linked me here
http://forums.maxima.org/showthread.php?t=301611
I read through the DIY section, but the threads seem to be mismatched with the subject. the tranny flush thread i read was linked to Ksport suspension review. lol
Old Nov 30, 2007 | 06:01 AM
TheSupe87's Avatar
I hate tranny problems. On Supras, I know a lot of times it has to do with either a bad TPS or the kickdown cable adjustment has gone out of whack. Not sure if Maximas have a cable, or if it's electronically controlled.
Last thing I had to replace on my auto was the solenoids - I fortunately found someone online that gave me all 3 for just $25 from a used, low-mileage tranny he had laying around. From the dealer it would have been over $200 for just one of them, and there are three. My tranny was skipping 2nd or 3rd gear, runnin in"limp"mode. Maybe there is a diagnosis procedure from the Maxima factory repair manual - one of the other guys on here might be more familiar with it.
Old Nov 30, 2007 | 06:24 AM
cefiro80's Avatar
I had similar problems and replaced the TCM and everything has been fine for 15k now.
Old Nov 30, 2007 | 06:32 AM
TheSupe87's Avatar
That sounds about right. On other cars it's called TPS or throttle position sensor, TCM must be throttle control module or something. Correct me if I'm wrong.
Old Nov 30, 2007 | 09:18 AM
hotstartup's Avatar
so im guessing this part is an extension of the throttle body? does the entire throttle body need to be replaced or can the TCM simply be replaced
Old Nov 30, 2007 | 09:44 AM
SoonerFan's Avatar
Cletus
has nothing to do with the throttle body...keep researching
Old Nov 30, 2007 | 10:26 AM
opanick's Avatar
well im having it looked at right now by my buddy at nissan for free so cant go wrong there, hopefully its just a TCM, and didnt put any damage on the tranny while driving around the past few days
Old Nov 30, 2007 | 10:31 AM
SoonerFan's Avatar
Cletus
my old 00
had tranny problems
nissan replaced tranny under warranty (but failed to replace TCM)
within a year, started having problems again
replaced TCM
never had the problem again.
realized that the original tranny actually went bad because of the TCM
Old Nov 30, 2007 | 10:33 AM
DasYears
TCM-transmission control module
Old Nov 30, 2007 | 11:00 AM
Scottwax's Avatar
That's Mr. Detail to you
Did the dealership explain specifically why a bad TCM would trash a tranny? Reduced line pressure not letting the clutch packs grab properly perhaps?
Old Nov 30, 2007 | 11:06 AM
SoonerFan's Avatar
Cletus
bad TCM causes hard shifts
TCM receives thousands of inputs. it compares all that with stored values. when it meets the values, it sends signal to solenoids which changes the gear.
when the TCM is bad, it has problems processing the inputs and delays the shifts.
Old Dec 2, 2007 | 03:24 PM
kukx30de's Avatar
What is the service history on the car?
Have you regularly done a fluid change at every 30K miles?
What are your driving habits like?
My 01 gle has 157k miles and no transmission issues yet.
Old Dec 2, 2007 | 03:46 PM
Aaron92SE's Avatar
NWP Engineering.com
What condition is the fluid in right now? Is it brown and burnt smelling? It should always be in brand new condition, bright red and smells like tranny fluid fresh out of the bottle.
When was the last time you had a drain and fill or a flush? Just trying to get a little base info so everybody can learn from this if it isn't TCM related.
If the tranny fluid is in perfect condition right now, I'd just do a drain and fill. You don't get all the fluid out. But it definitely helps.
If the fluid is not in brand new condition, then do a flush. The MYTH is that by doing a flush on a really old transmission, that it can remove gunk that is preventing leaks. But I believe this is a myth. You should always maintain your tranny fluid. Don't let this keep you from doing a flush. I've never read any real stories about a flush killing a tranny. You'll be fine, don't worry.
Old Dec 2, 2007 | 04:06 PM
Scottwax's Avatar
Think you have tranny troubles? Eddie Murphy had tranny troubles.
Old Dec 3, 2007 | 05:40 PM
opanick's Avatar
Yes the fluid is brown and does have a smell to it. The previous owner never had it flushed and I never got around to it.
Well the Nissan tech said it wasnt my TCM and wanted to perform other test, but I havent got a chance to take it back. I really just want to take it somewhere else and actually pay to have em check it out. My buddy didnt charge me anything so I dont know if they took the time to check it throughly as if I would paid them.
I really just find the hard shifting and slipping, and my reverse gear locking up something electrical. Well if worst comes to worst I can get a used tranny with under 50k for $550 and installed for another $300 plus cost of fluid and what not.
Old Dec 3, 2007 | 06:26 PM
DasYears
any aamco will give you a pretty extensive free check, but i can almost guarantee they will tell you you need a minor rebuild with the possibility of an extensive rebuild
Old Dec 3, 2007 | 08:01 PM
Scottwax's Avatar
All
Automatics
Must
Come
Out
Old Dec 8, 2007 | 05:46 PM
CBRworm's Avatar
To the second poster, not the one with no reverse, mine had an output shaft speed sensor go out which was causing all kinds of crazy shifting and getting stuck in 2nd. Aamco said it needed to be rebuilt. I bought a code scanner and pulled the code - said Rev sensor. Replaced it (speed sensor) and have been good for the last 20K.
What did your code read?
Old Dec 8, 2007 | 06:11 PM
wyche89's Avatar
you can scan for tranny problem codes when you dont have a check engine light? mine is slipping in high rpms on the 1-2 shift, and i would LOVE to know what that is
Old Dec 8, 2007 | 08:51 PM
Scottwax's Avatar
Probably the clutch packs are going out. Typically, you only pop a code if there is an electrical/sensor/solenoid problem with the transmission. Try manually shifting at higher rpms on the 1-2 shift and see if that helps. That usually increases line pressure so the clutch packs will grab more quickly.
Old Dec 8, 2007 | 11:32 PM
wyche89's Avatar
clutch packs are different from the solenoid packs?
Old Dec 9, 2007 | 12:09 AM
Scottwax's Avatar
Solenoids control the transmission electronically, while each gear has a clutch pack that consists of clutches and steel rings that provided the clamping force in each gear (sort of like a clutch in a manual).
Here is a pretty good overview of how an automatic works and the parts they consist of.
http://www.familycar.com/Transmission.htm
Old Dec 9, 2007 | 04:35 AM
doc2278's Avatar
Doctor D I presume???
I have the same problem, hard shifts 1-2 3 ok if manual shift o/d Shot to just rpm no speed increase, seems like no line pressure there. + no codes= I figure valve body ( boosted max BTW) waiting for vb mod to come back.
Old Dec 9, 2007 | 07:25 AM
wyche89's Avatar
ohh ok... maybe i used the wrong term... "Slipping is when an engine races briefly when the transmission shifts from one gear to the next." mine doesn't do that.. nor does it have the problem where the rpms shoot up and theres no speed increase like doc was talking about.. mine just takes a second to shift over to 2nd gear in higher rpms.... lower rpms are fine though
Old Dec 9, 2007 | 07:55 AM
Scottwax's Avatar
Could be one of the shift solenoids or possibly dirty ATF not flowing properly through the valve body.
Old Dec 9, 2007 | 08:15 AM
wyche89's Avatar
it started happening a couple thousand miles after i flushed it with mobil 1 synthetic atf.. before that the dyno fluid was brown... after the flush, it was noticably redder, but still wasn't quite that bright red as i saw in other cars
Old Dec 9, 2007 | 08:29 AM
bricks342133's Avatar
Yeah! I have an 02 max and mine is doing the same thing. 1-2 slow change. And I keep up very well on fluids. Had a recent flush this summer and had a check for winterization. I am going to look into the clutch packs.Hmmmm
Old Dec 9, 2007 | 10:16 AM
wyche89's Avatar
does yours do it at high rpms, or during normal driving?
Old Dec 9, 2007 | 05:47 PM
It does it at high rpms
