Hyperground Impressions
Old Nov 30, 2007 | 11:57 AM
Armon's Avatar
I installed a 6 wire custom hyperground yesterday using black 6 awg wire from Home Depot. I used Irish44j's write up which I found in this thread. According to the write up, I did wires A, B, C, E, F, and G. I'll go through detailed explanations of my impressions as they occurred to me. For the short version, read the bolded parts.
Note: I did not ground the transmission (automatic). I was planning on doing it today, but after driving around, I'm not sure I need to (see below).
Impressions:
1) "Are my lights brighter?" It was just beginning to get dark, and I could swear my gage cluster was brighter. I don't know how that's even possible, considering the relatively small amount of power the gage cluster takes to illuminate. The reflection of my headlights in the sliding glass door in front of my parking spot also suggested that the headlights and foglights were brighter. But, it might have just been in my head. It would be too subjective to decide either way. Verdict: No clear conclusion.
2) Window roll up/down speed. Before --> My front passenger window has always been a lot slower than the front driver side window, and recently has been making a groaning noise. The noise sort of made me feel like the window was having trouble getting enough power to roll up, so much so that I was expecting it to stop working within the next year. After --> it still isn't as fast as the driver side window. But it's a lot faster than it was before, and the groaning noise is gone. Verdict: Improved front passenger roll up/down speed; groaning noise eliminated
3) A/C on/off effects. Before --> when I had the car in park and would turn on the A/C, I would hear a click under the hood, a slight RPM adjustment and dimming of lights, and then the engine would settle down into a slighty louder and less smooth state until the A/C was turned off. After --> same click when the A/C is turned on. Smaller RPM adjustment. Less dimming of lights. Engine settles back to original state rather than the slightly louder, rougher state. Verdict: Quieter, smoother engine operation with A/C on.
4) Throttle Response / Gear Shifts. This was the biggest change. I first noticed the smoothness of the throttle response when starting from a stop. No jerks, just smooth power. I'm talking about city driving here, using less than 50% throttle. Later, I noticed this carried over into smoother, quicker gear shifts. It seems like the throttle is simply more precise. I don't think the transmission has changed any, considering I didn't ground it directly, but I think the improved throttle response has contributed to the better shifting. There is definitely a difference in the shifting. Before, a small stomp on the gas at about 10mph would induce a second of hesitation followed by a nice big jerk. Now it just downshifts and goes. Verdict: Smoother, more precise throttle response and quicker, smoother gear shifts (especially downshifts).
The wiring was fairly easy. I used it as my warm up for HID headlight installation. Highly recommended do-it-yourself mod.
Materials:
20 feet of 6awg wire (2 feet left over)
3/8" terminal connectors for 6awg wire
Heat shrink wrap (used a lighter to shrink)
Wire cutters (hope yours are bigger than mine - small ones are a real pain)
Old Nov 30, 2007 | 12:12 PM
SoonerFan's Avatar
Cletus
yes...the grounding makes a difference
Old Nov 30, 2007 | 12:26 PM
Armon's Avatar
Are you referring to the transmission ground specifically? In addition to the difference I've already noticed?
Old Nov 30, 2007 | 02:56 PM
Scottwax's Avatar
That's Mr. Detail to you
Interesting that just improving engine grounding would make a noticable difference. You'd think with the plethora of electronics and computers in newer cars, the manufacturers would incorporate better grounding into the cars from the factory.
Old Nov 30, 2007 | 02:59 PM
SoonerFan's Avatar
Cletus
FYI, there are a few long threads with write-ups and impressions from the first few people that did this 2 years ago (me, josh, and a few others).
bottomline: it makes a difference
Old Nov 30, 2007 | 03:07 PM
GigEmAgs07's Avatar
hell i'm bored, i may give this a shot tonight with a friend who has an i30. irish's site doens't have a pic of the transmission ground. anyone (coughcoughsooner) wanna post one up?
Old Nov 30, 2007 | 03:37 PM
SoonerFan's Avatar
Cletus
irish is 5-speed and didnt need it.
i did it on my 00 (auto). it was connected to one of the bolts on the tranny. just look for one
Old Nov 30, 2007 | 04:46 PM
cefiro80's Avatar
I have been meaning to do this for a while just havent gotten to it. I will do it this weekend. How much did materials cost?
Old Nov 30, 2007 | 05:01 PM
bigjoe87865's Avatar
wow... never even heard of this..... definatly gonna give it a try after some more reserch.
Old Nov 30, 2007 | 05:13 PM
Armon's Avatar
Total cost was about 35 bucks. I didn't have any of the materials to start with.
I actually went and added a 7th wire to the transmission today. Not sure if it did anything more, but I do know that overall it shifts much smoother now.
Definitely look into this mod, especially if you have an auto. I recommend 6 gage wire as it allows you to make tighter turns than 4 gage. I attempted to go for a "stealthy" look.
Old Nov 30, 2007 | 06:38 PM
ZIPPIN's Avatar
Mauja He Mauja
PICS????
Old Nov 30, 2007 | 09:15 PM
Scottwax's Avatar
Originally Posted by ZIPPIN
PICS????
Yeah, pics.
Old Nov 30, 2007 | 09:48 PM
Armon's Avatar
Okay, okay... pics coming tomorrow
Old Nov 30, 2007 | 10:23 PM
Scottwax's Avatar
Gracias, Amigo.
Old Nov 30, 2007 | 11:24 PM
NmexMAX's Avatar
dot dot dot ...
LRMAF + AFC + WBO2 > *
Old Nov 30, 2007 | 11:35 PM
AceofSpds's Avatar
wat
I did the big 3 and it worked fine for me
nitrous oxide?
Old Dec 1, 2007 | 12:17 AM
SoonerFan's Avatar
Cletus
i understand your code
summer 08
Old Dec 1, 2007 | 12:18 AM
AceofSpds's Avatar
wat
summer 08
pfft in your case its Built 3.5 >*
Old Dec 1, 2007 | 12:19 AM
NmexMAX's Avatar
dot dot dot ...
No, No Boost/not N2O.
Old Dec 1, 2007 | 12:20 AM
SoonerFan's Avatar
Cletus
silly novices
Old Dec 1, 2007 | 12:21 AM
SoonerFan's Avatar
Cletus
in my case - Built 3.5 + headers + LRMAF + AFC + WBO2
Old Dec 1, 2007 | 12:22 AM
NmexMAX's Avatar
dot dot dot ...
Hmm, I think, you know what I think, HR/DE = FTMFW. That's what my spic asz is doing
Old Dec 1, 2007 | 12:23 AM
SoonerFan's Avatar
Cletus
agreed
HR/DE + headers + LRMAF + AFC + WBO2
Old Dec 1, 2007 | 07:36 AM
nismowolfe's Avatar
this mod works great did it on quite a few of my other cars with nice results havent did the max yet but its on the list jus kinda cold lately here.
Old Dec 1, 2007 | 10:15 AM
Armon's Avatar
Well apparently some folks got drunk late last night and whored up my thread
Here are some pics:
1) Three ground wires off of the negative battery terminal
2) Ground that is directly behind the battery
3) Transmission ground
The left most wire in pic 1 goes to the point in pic 2. Another wire goes from the point in pic 2 to the tranny in pic 3
Old Dec 1, 2007 | 12:11 PM
ChromeSE5's Avatar
Is there a huge difference in using a daisy chain set-up versus having all the ground points connected to the negative terminal? I know I read that someone else had a daisy chain set-up but wasn't sure if the difference would be nominal.
Old Dec 1, 2007 | 12:31 PM
n3985's Avatar
大陆弟弟
Big 3 wires > all grounding kits
Old Dec 1, 2007 | 12:45 PM
ShIft_uR FacE's Avatar
Big 3 + extra grounds =
Old Dec 1, 2007 | 02:39 PM
ZIPPIN's Avatar
Mauja He Mauja
I did it on my 00 and really did not feel much of a difference, other than smooth idle..
Old Dec 1, 2007 | 03:00 PM
redmaxpa007's Avatar
i SeE what you did therE
grounding......good.......
hypergrounding prices......bad!!
Old Dec 1, 2007 | 03:24 PM
SoonerFan's Avatar
Cletus
"hyperground" = "grounding" with a fancy name so companies convince you that you need it. like its somehow fancier than a "normal grounding kit"
you make your own...call it a grounding kit
Old Dec 1, 2007 | 03:25 PM
20-30 $$ or 40$$ if you want some bling connectors...
Old Dec 1, 2007 | 03:30 PM
Armon's Avatar
For me it came down to the practical limitations of hooking up more than 3 connectors to the battery terminal. I'm not sure what the theoretical difference between those two methods are.
Old Dec 1, 2007 | 03:31 PM
Armon's Avatar
My total cost was just over 30 bucks.
Old Dec 1, 2007 | 03:38 PM
SoonerFan's Avatar
Cletus
but stillen has it for..... $134.16
Old Dec 1, 2007 | 04:25 PM
Scottwax's Avatar
What about connecting the ground wires to the main engine ground off the battery instead of the negative terminal of the battery itself? It would probably be a cleaner looking installation, but would it be as effective?
Old Dec 1, 2007 | 04:30 PM
SoonerFan's Avatar
Cletus
the negative is the ground of the electrical system. it leaves the battery and goes to a ground...
i think havent seen my car in 150 days
i do know that all grounding kits are done that way
Old Dec 1, 2007 | 04:57 PM
Scottwax's Avatar
I know that, I am just wondering if it would be as effective connecting to the main ground the negative terminal does...maybe run 0 gauge from the negative terminal to the main ground, then attach the other wires there. If it won't be as effective, no biggie, but if so, it would be a cleaner looking install.
Just thinking out loud, I guess.
Old Dec 1, 2007 | 05:16 PM
Prophecy99's Avatar
this is a great mod, I am going to do this on every car I ever own.
Old Dec 13, 2007 | 05:09 PM
GigEmAgs07's Avatar
can someone tell me if this is the right bolt to use, doing it the way irish did?
