Headlight Cleaning--PLASTX-Pics inside.
Old Dec 28, 2007 | 06:08 PM
ZIPPIN's Avatar
Mauja He Mauja
This will probably be moved to detailing. I posted it here so that you can see that for nominal haze, you don't need to wet-sand.
These lights had haze on them. I purchased Meguiars's PLASTX. Used: Applicator Pad/Bug remover pad/Microfiber cloth.
Step 1: Used the MF cloth to wipe off dirt-DAMP
Step 2: Applied PLASTIX to the Applicator Pad and scrubbed hard for 5 minutes
Step 3: Applied PLASTIX to the BUG removing pad and scrubbed hard for 3 minutes
Step 4: Rinsed the BUG removing pad, applied PLASTIX scrubbed hard for 5 minutes
Step 5: Wiped down with a clean MFC.
Old Dec 28, 2007 | 06:10 PM
ZIPPIN's Avatar
Mauja He Mauja
Please note that PLASTX will not remove deep pitting. The lights look very nice and shiny. The haze and embedded bugs are out.
Results:
Old Dec 28, 2007 | 06:22 PM
wyche89's Avatar
plastic-x worked for me too.. but i heard it didn't last long and the haze comes back if you don't use wet sanding whatever.. my headlights look good now, and i'm happy
Old Dec 28, 2007 | 06:26 PM
ZIPPIN's Avatar
Mauja He Mauja
I am going to smear some good wax on them as well. I read many posts that suggested that good wax will keep them shinning for a long time. Specially after wet-sanding.
Old Dec 28, 2007 | 06:54 PM
playboi21617's Avatar
are your upper headlight clips where there screw into the frame cracked in at the top cause mine are and if your are to did you have any probs getting them back on because iam scared that mine will not screw back down. thanks
Old Dec 28, 2007 | 06:56 PM
jasonmax's Avatar
PlastX is really good. I did it twice, no more cloudy headlighs.
I think if you clay your headlights befor using plastx, it will be even better...I will try.
Old Dec 28, 2007 | 06:58 PM
ZIPPIN's Avatar
Mauja He Mauja
They have hairline cracks, cause I over tightened them. They will not cause any issues with fitting.
Old Dec 28, 2007 | 07:07 PM
ZIPPIN's Avatar
Mauja He Mauja
Will try on my wifes CRV..Thanks for the tip
Old Dec 28, 2007 | 07:10 PM
00MaxSE's Avatar
Pointy Elbows
Looks good Jay. Nice job.
Old Dec 28, 2007 | 07:25 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I'm going to do both the HID's and the fogs tomorrow...
Old Dec 28, 2007 | 07:34 PM
ZIPPIN's Avatar
Mauja He Mauja
It is worth it and easier than you would think. I read a lot of posts from different websites that recommended using PLASTX, prior to wet-sanding. I am glad I did not wet-sand. I will take more pics of them installed, once its sunny outside.
Old Dec 28, 2007 | 07:43 PM
jasonmax's Avatar
It's really good.
This is my car, it has been more than two months since I use plastx.
Old Dec 28, 2007 | 07:52 PM
ZIPPIN's Avatar
Mauja He Mauja
It's really good.
Did you coat with wax? If so, what brand/kind?
Old Dec 28, 2007 | 07:55 PM
jasonmax's Avatar
I use Meguiar's Liquid Wax, and the last waxing was one months ago.
Old Dec 28, 2007 | 08:05 PM
aventerav's Avatar
Yup I bought some a few weeks back, it made a huge difference for me.
BTW jasonmax, very clean max above. ^^
Old Dec 28, 2007 | 09:28 PM
Scottwax's Avatar
That's Mr. Detail to you
Good choice. Sometimes wetsanding is necessary but always try the least aggressive method first. No sense squirrel hunting with a howitzer, right?
From now on, every time you wax your car (which should be 4 times a year), polish the headlights again. Pretty much every G35 I detail needs the headlights polished every time I wax it since the plastic is very prone to hazing.
Tondeuse's Avatar
You got me. Going to buy some PlastX tomorrow. Sucks to live in Canada, 11$/bottle
Old Dec 28, 2007 | 09:38 PM
ZIPPIN's Avatar
Mauja He Mauja
BTW, the pics were taken from my BB curve. Lights look a lot better than the pics. My wife is in London and took the digi with her...I will post better pics when she returns.
Old Dec 28, 2007 | 09:42 PM
ZIPPIN's Avatar
Mauja He Mauja
I read your thread in the detailing section. Obviously you know your stuff. I decided not to wet-sand after reading your posts. Thanks for all the tips.
Old Dec 29, 2007 | 02:19 AM
VQHP's Avatar
Sunglasses required..
You should try Eagle One nano wax. Results are very good as you can see...... That's all I use, from start to finish.
Old Dec 29, 2007 | 04:26 AM
maxximaa's Avatar
can i use PLASTX to wax my car?
Old Dec 29, 2007 | 08:14 AM
sascuderi's Avatar
Where can you find PLASTX?????
Old Dec 29, 2007 | 10:06 AM
paulpearl's Avatar
Lookin good....I use the 3M professional grade plastic cleaner/polish on my headlights/fogs about every 2 months to keep the headlights looking new...Just keep up on the headlights every few months and they will look new for a long time...Also apply a paste wax to them after polishing...
Old Dec 29, 2007 | 04:46 PM
00MaxSE's Avatar
Pointy Elbows
I have the same stuff.
Old Dec 29, 2007 | 05:19 PM
spdfreak's Avatar
Looks good.
Old Dec 29, 2007 | 06:30 PM
ZIPPIN's Avatar
Mauja He Mauja
J, make sure you do the same on your pimp'n JEEP with 22's
Old Dec 29, 2007 | 06:35 PM
00MaxSE's Avatar
Pointy Elbows
lol Actually it could really use it. They're all yellowish.
O/T,
Just changed a headlight bulb. Had to take the damn battery out just to get in there. And for some reason the bulb wont sit flush in there, so I couldn't get the locking cap on. Screw it, if it comes loose, it comes loose.
Old Dec 29, 2007 | 08:41 PM
lowincash's Avatar
No More Maxipad
after reading this i went out to do mine too since i had a bottle of plastix sitting in my trunk for a while now lol man the headlights are so clear now and the light cutoff is not as blurry as before
Old Dec 29, 2007 | 08:54 PM
ZIPPIN's Avatar
Mauja He Mauja
pics please
Old Dec 29, 2007 | 09:29 PM
Double0GLE's Avatar
I just buffed mine with a soft polish pad and polish/light cut compound... I did it about 3 months ago and they haven't fogged up yet...
Old Dec 29, 2007 | 10:09 PM
Maxgig's Avatar
Good info zippin, I'm doing mine tomorrow, thanks.
update: The Max looks sweet, I did my son's Volvo as well but since his lights have the wipers I used RainX instead of wax afterwards just to see if it makes a difference.
Old Dec 30, 2007 | 08:18 AM
Lontar1's Avatar
done... wow what a difference.. the Fogs were all shi_tty and now they look brand new......took me 20 minutes to do them..... I only used the 800 and 2000.....
Old Dec 30, 2007 | 08:31 AM
lowincash's Avatar
No More Maxipad
i was going to do my fogs too but i have a clear vinyl cover on it so dont' think i should polish that.
but here's a couple pics i took last night...
it's definitely better than before and the cutoff got a lot clearer too
Old Dec 30, 2007 | 11:28 AM
00MaxSE's Avatar
Pointy Elbows
^ Very nice.
Old Dec 30, 2007 | 01:16 PM
Tondeuse's Avatar
I went to my local Canadian Tire but they were all sold out... but right now I'm out of town and I'll go see if they have any. I will post pics before/after once it's done
Old Dec 30, 2007 | 03:50 PM
Tippy Toes's Avatar
Where can you purchase some plasticx..?
Old Dec 30, 2007 | 03:51 PM
jasonmax's Avatar
I got mine at Autozone
I also found it at Target.
Old Apr 28, 2008 | 06:43 AM
maxdriver10's Avatar
I also went to autozone, its somewhere around $7 for a bottle. It worked wonders for my headlights though, definately worth it
Old Apr 28, 2008 | 10:02 AM
kjchevy3's Avatar
I tried PlastX a while back, did OK, but not great. After reading this I'mthinking I may not have rubbed long enough. I think I'll try again.
Old Apr 28, 2008 | 11:02 AM
sublime258's Avatar
Just bought some PlastX too for my hazy headlights...gonna do them up and put in my new PIAA Xtreme White Plus fogs at the same time...
