Brake light problem
Old Dec 31, 2007 | 03:06 PM
jamyers's Avatar
Brake light problem
I have a question and need help sometimes the light that says brake beside the seat belt light stays on like the e-brake is up but it is not what is wrong 2003 maxima
Old Dec 31, 2007 | 05:04 PM
Maxgig's Avatar
I'm not sure if this applies to the Maxima but on older cars I've owned or driven in the past if this happened it was either one of two things. Either your brake pads needed replacing or your fluid level was low.
Old Jan 1, 2008 | 01:10 PM
NisTech's Avatar
Brake fluid is probably low. That usually means you need new pads unless you have a leak somewhere
Old Jan 1, 2008 | 08:29 PM
impact'sa33's Avatar
just fill that bad boy up with more brake fluid...or it can be that little stainer possibly fell into the tanks all you gotta do is pick at it with your nail and it will pop back up....happened to me after brake changes cuz dumb me forgets to check the fluids
Old Jan 2, 2008 | 09:32 AM
ReauDog's Avatar
hmmm, this just recently happened to me, my brake light has been on like this for about a week. I'm glad someone posted up about it. I'm going to go check my fluid levels asap. thanks folks.
Old Jan 2, 2008 | 01:23 PM
jamyers's Avatar
Old Jan 3, 2008 | 08:19 AM
ReauDog's Avatar
Yep, my fluid was low. added some and the light went off. Thanks Max Org gods.
Old Jan 3, 2008 | 08:50 PM
NisTech's Avatar
I try not to refill all the way. That is one indication other than squal that you need brakes. If you fill it up all the way and you have 30% brakes when you run low you have no indication on dash.
So i try not to top it off too much as most of the times is light comes on when you need pads/discs.
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
