2000 Maxima Motor Mounts
Old Jan 4, 2008 | 09:49 AM
RIC4044's Avatar
Hey, while doing some work on the max I noticed that the engine has a lot of play when put in drive and hitting the gas with your foot on the brake. Moves a little bit when put in reverse, but not as much as when you put it in drive... I looked at the mounts, didn't see anything wrong on a quick visual.. How can i determine if the mounts are bad, and which mount exactly would need to be replaced? My Max has 200k miles, what's the life expectancy on these things? I have a slight knocking/tapping sound coming from under the hood, similar problem on my wife's ford turned out to be a bad motor mount...Please help, any advice is welcome... And does anyone have a link on how to replace the motor mounts?
Old Jan 4, 2008 | 01:03 PM
L.M.L.
if those have gone for 200k without a change, they are shot. most likely.
Old Jan 4, 2008 | 01:10 PM
DrKlop's Avatar
Driving is the next best thing
I'm not sure if it's a proper way for checking the motor mounts, but here's how I do this:
Put the e-brake all the way up. Put the car in gear and try to get it to move. At the same time someone should look at the engine block. If it looks like the engine is about to jump out, you need new mounts.
Old Jan 4, 2008 | 06:08 PM
RIC4044's Avatar
yeah, it looks like it wants to jump out... do i need to replace all of them, i think there's 4 total... Where's a good place other than the dealership to buy them... And again, is there a link on how to install the mounts..?
Old Jan 4, 2008 | 08:04 PM
irish44j's Avatar
retired moderator
www.suspesion.com you can get energy suspension mounts.
edit: maybe not for autotragic....
Old Jan 4, 2008 | 09:28 PM
Stardust's Avatar
F---ing Kangaroos
Have you forgotten about our favorite org sponsor?
http://forums.maxima.org/showthread.php?t=547174
Old Jan 5, 2008 | 07:03 AM
knight_yyz's Avatar
Toolie
forget about the two on the sides. just do the 2 lower mounts
Old Jan 5, 2008 | 05:35 PM
RIC4044's Avatar
OK. Thanks for the advice guys. I will try to replace the bottom 2 first.... but again... does anyone have a link on how to do this?
Old Jan 5, 2008 | 05:44 PM
SoonerFan's Avatar
Cletus
there are stickies that have all the info you need. do yourself a favor and looks for the info...its avaliable.
Old Jan 5, 2008 | 10:14 PM
RacerX1320's Avatar
Do it, tis well worth it. ES has pdf on it as well.
Old Mar 12, 2008 | 08:15 PM
kss's Avatar
kss
My 2000 maxima makes a buzzing noise 5 or 6 times when i shut the car off. I have read that it is the motor mounts because they are electronic. Is this correct and do I need to replace them now or is it just another noise I'm going to have to live with? Thanks
KSS
Old May 16, 2011 | 02:13 PM
revaredneck's Avatar
lash it round and round 10-12 times with 1/16th stainless steel wire and insert a long nail and twist it till she's tight it lasts long time for front motor mount tie downs. actually over 5 years now on my 89 max beater.
Old May 16, 2011 | 02:29 PM
djfrestyl's Avatar
Suspension Yoda
KSS
Unplug immediately. Prolonged shot motor mounts can fry your ECU.
Then replace them with manual ones. They are cheaper and you do not have to use electronic mounts.
djfrestyl's Avatar
Suspension Yoda
No.
schmellyfart
Sep 25, 2015 04:47 PM
jholley
Aug 11, 2015 09:38 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
niZ
Aug 7, 2015 10:18 PM
laparka66
Aug 6, 2015 09:36 AM
